Datum velden optellen in excel
masarada
6 nov 2007
Hoi Allemaal
*My NL is not good, hope there would be some answers to this query :)
My sheet looks pretty much like this
I just want to add the 'occurrences' of the dates, for example in the image above -the red arrows shows the occurrences , and there are thus 4 of them ( 4 occurrences with red arrows).
what is a formula to calculate all the date occurrences on this sheet.
I tried:
1) =COUNT(A1:A76) , will give the total number , but then its also including the timestamps.
2) also tried : =COUNTIF(range, if_date()) , but no joy ( =COUNTIF(A1: A76, if_date()) ; where A1 to A76 is my range
would love to hear some suggestions here , if possible.
Thx.!
Try this one:
=COUNTIF(A:A;">"&1)
Try this:
=COUNTIF(A1:A76,">=1/1/00")
Please note that the value in A1 is not a real date but a text string.
Try this:
Thanks,
I tried the above, but somehow it will not accept it . ( I have excluded A1 from the range, since its a text string)
Thx. for any assistance.
Cheers
=COUNTIF(A1:A76[COLOR="#FF0000"];[/COLOR]">=1/1/00")
Try this
Excellent !:thumb:
Bedankt ! opgelost :) & Thanks to All !
Ecrire la prochaine fois en Hollande et poser la question comme réglée.
Thanks,
Cheers
You might need to replace the , for a ;
But your problem is already solved :)
