Hieronder een PDF document met een PDF generator er in. Dit is afkomstig van een Prestashop site.
Het gaat om het genereren van de factuur en pakbon. En dan gaat het om de factuur/pakbon datum.
Ik heb geen idee hoe ik dit moet veranderen. Iemand een idee?
PHP:
<?php
* 2007-2012 PrestaShop
* NOTICE OF LICENSE
* This source file is subject to the Open Software License (OSL 3.0)
* that is bundled with this package in the file LICENSE.txt.
* It is also available through the world-wide-web at this URL:
* http://opensource.org/licenses/osl-3.0.php
* If you did not receive a copy of the license and are unable to
* obtain it through the world-wide-web, please send an email
* to license@prestashop.com so we can send you a copy immediately.
* DISCLAIMER
* Do not edit or add to this file if you wish to upgrade PrestaShop to newer
* versions in the future. If you wish to customize PrestaShop for your
* needs please refer to http://www.prestashop.com for more information.
* @author PrestaShop SA <contact@prestashop.com>
* @copyright 2007-2012 PrestaShop SA
* @version Release: $Revision: 14055 $
* @license http://opensource.org/licenses/osl-3.0.php Open Software License (OSL 3.0)
* International Registered Trademark & Property of PrestaShop SA
include_once(_PS_FPDF_PATH_.'fpdf.php');
class PDF_PageGroupCore extends FPDF
var $NewPageGroup; // variable indicating whether a new group was requested
var $PageGroups; // variable containing the number of pages of the groups
var $CurrPageGroup; // variable containing the alias of the current page group
// create a new page group; call this before calling AddPage()
function StartPageGroup()
$this->NewPageGroup=true;
// current page in the group
function GroupPageNo()
return $this->PageGroups[$this->CurrPageGroup];
// alias of the current page group -- will be replaced by the total number of pages in this group
function PageGroupAlias()
return $this->CurrPageGroup;
function _beginpage($orientation, $arg2)
parent::_beginpage($orientation, $arg2);
if ($this->NewPageGroup)
// start a new group
$n = sizeof($this->PageGroups)+1;
$alias = "{nb$n}";
$this->PageGroups[$alias] = 1;
$this->CurrPageGroup = $alias;
$this->NewPageGroup=false;
elseif ($this->CurrPageGroup)
$this->PageGroups[$this->CurrPageGroup]++;
function _putpages()
$nb = $this->page;
if (!empty($this->PageGroups))
// do page number replacement
foreach ($this->PageGroups as $k => $v)
for ($n = 1; $n <= $nb; $n++)
$this->pages[$n]=str_replace($k, $v, $this->pages[$n]);
parent::_putpages();
class PDFCore extends PDF_PageGroupCore
protected static $order = NULL;
protected static $orderReturn = NULL;
protected static $orderSlip = NULL;
protected static $delivery = NULL;
protected static $_priceDisplayMethod;
/** @var object Order currency object */
protected static $currency = NULL;
protected static $_iso;
/** @var array Special PDF params such encoding and font */
protected static $_pdfparams = array();
protected static $_fpdf_core_fonts = array('courier', 'helvetica', 'helveticab', 'helveticabi', 'helveticai', 'symbol', 'times', 'timesb', 'timesbi', 'timesi', 'zapfdingbats');
* Constructor
public function __construct($orientation = 'P', $unit = 'mm', $format = 'A4')
global $cookie;
if (!isset($cookie) OR !is_object($cookie))
$cookie->id_lang = (int)(Configuration::get('PS_LANG_DEFAULT'));
self::$_iso = strtoupper(Language::getIsoById($cookie->id_lang));
FPDF::FPDF($orientation, $unit, $format);
$this->_initPDFFonts();
protected function _initPDFFonts()
if (!$languages = Language::getLanguages())
die(Tools::displayError());
foreach ($languages AS $language)
$isoCode = strtoupper($language['iso_code']);
$conf = Configuration::getMultiple(array('PS_PDF_ENCODING_'.$isoCode, 'PS_PDF_FONT_'.$isoCode));
self::$_pdfparams[$isoCode] = array(
'encoding' => (isset($conf['PS_PDF_ENCODING_'.$isoCode]) AND $conf['PS_PDF_ENCODING_'.$isoCode] == true) ? $conf['PS_PDF_ENCODING_'.$isoCode] : 'iso-8859-1',
'font' => (isset($conf['PS_PDF_FONT_'.$isoCode]) AND $conf['PS_PDF_FONT_'.$isoCode] == true) ? $conf['PS_PDF_FONT_'.$isoCode] : 'helvetica'
if ($font = self::embedfont())
$this->AddFont($font);
$this->AddFont($font, 'B');
/* If the user is using a ISO code no present in the languages, use the first language available instead */
if (!isset(self::$_pdfparams[self::$_iso]) && isset($languages[0]['iso_code']))
self::$_iso = strtoupper($languages[0]['iso_code']);
* Invoice header
public function Header()
global $cookie;
$conf = Configuration::getMultiple(array('PS_SHOP_NAME', 'PS_SHOP_ADDR1', 'PS_SHOP_CODE', 'PS_SHOP_CITY', 'PS_SHOP_COUNTRY', 'PS_SHOP_STATE'));
$conf['PS_SHOP_NAME'] = isset($conf['PS_SHOP_NAME']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_NAME']) : 'Your company';
$conf['PS_SHOP_ADDR1'] = isset($conf['PS_SHOP_ADDR1']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_ADDR1']) : 'Your company';
$conf['PS_SHOP_CODE'] = isset($conf['PS_SHOP_CODE']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_CODE']) : 'Postcode';
$conf['PS_SHOP_CITY'] = isset($conf['PS_SHOP_CITY']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_CITY']) : 'City';
$conf['PS_SHOP_COUNTRY'] = isset($conf['PS_SHOP_COUNTRY']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_COUNTRY']) : 'Country';
$conf['PS_SHOP_STATE'] = isset($conf['PS_SHOP_STATE']) ? Tools::iconv('utf-8', self::encoding(), $conf['PS_SHOP_STATE']) : '';
if (file_exists(_PS_IMG_DIR_.'/logo_invoice.jpg'))
if ($this->_isPngFile(_PS_IMG_DIR_.'/logo_invoice.jpg'))
$this->Image(_PS_IMG_DIR_.'/logo_invoice.jpg', 151, 8, 30, 30, 'PNG');
else
$this->Image(_PS_IMG_DIR_.'/logo_invoice.jpg', 151, 8, 30, 30);
elseif (file_exists(_PS_IMG_DIR_.'/logo.jpg'))
if ($this->_isPngFile(_PS_IMG_DIR_.'/logo.jpg'))
$this->Image(_PS_IMG_DIR_.'/logo.jpg', 151, 8, 30, 30, 'PNG');
else
$this->Image(_PS_IMG_DIR_.'/logo.jpg', 151, 8, 30, 30);
$this->SetFont(self::fontname(), '', 15);
$this->Cell(115);
* Detect if the file header match a PNG file
* @param string $file Filename to check (include full path)
* @return boolean True if the file is a PNG file
private function _isPngFile($file)
$pngReferenceHeader = array(137, 80, 78, 71, 13, 10, 26, 10);
$fp = fopen($file, 'r');
if ($fp)
for ($n = 0; $n < 8; $n++)
if (ord(fread($fp, 1)) !== $pngReferenceHeader[$n])
fclose($fp);
return false;
else
return false;
return true;
* Return the complete Address format
private function _getCompleteUSAddressFormat($conf)
$shopCity = (isset($conf['PS_SHOP_CITY']) && !empty($conf['PS_SHOP_CITY'])) ? $conf['PS_SHOP_CITY'] : '';
$shopState = ((isset($conf['PS_SHOP_STATE']) && !empty($conf['PS_SHOP_STATE'])) ? $conf['PS_SHOP_STATE'] : '');
$shopZipcode = (isset($conf['PS_SHOP_CODE']) && !empty($conf['PS_SHOP_CODE'])) ? $conf['PS_SHOP_CODE'] : '';
// Build the complete address with good separators
$completeAddressShop = $shopCity.
((!empty($shopState) && !empty($shopCity)) ? ', '.$shopState.((!empty($shopZipcode)) ? ' ' : '') :
((!empty($shopState)) ? $shopState. ((!empty($shopZipcode)) ? ' ' : '') :
((!empty($shopCity) && !empty($shopZipcode)) ? ' ' : ''))).
$shopZipcode;
// Clean the string
return ($completeAddressShop = trim($completeAddressShop, ' '));
* Build the the detailed footer of the merchant
private function _builMerchantFooterDetail($conf)
$footerText;
// If the country is USA
if (Country::getIsoById(Configuration::get('PS_COUNTRY_DEFAULT')) == 'US')
$completeAddressShop = $this->_getCompleteUSAddressFormat($conf);
$footerText = self::l('Headquarters:')."\n".
$conf['PS_SHOP_NAME_UPPER']."\n".
(isset($conf['PS_SHOP_ADDR1']) && !empty($conf['PS_SHOP_ADDR1']) ? $conf['PS_SHOP_ADDR1']."\n" : '').
(isset($conf['PS_SHOP_ADDR2']) && !empty($conf['PS_SHOP_ADDR2']) ? $conf['PS_SHOP_ADDR2']."\n" : '').
(!empty($completeAddressShop) ? $completeAddressShop."\n" : '').
(isset($conf['PS_SHOP_COUNTRY']) && !empty($conf['PS_SHOP_COUNTRY']) ? $conf['PS_SHOP_COUNTRY']."\n" : '').
((isset($conf['PS_SHOP_PHONE']) && !empty($conf['PS_SHOP_PHONE'])) ? self::l('PHONE:').' '.$conf['PS_SHOP_PHONE'] : '');
else
$footerText = $conf['PS_SHOP_NAME_UPPER'].(!empty($conf['PS_SHOP_ADDR1']) ? ' - '.self::l('Headquarters:').' '.$conf['PS_SHOP_ADDR1'].
(!empty($conf['PS_SHOP_ADDR2']) ? ' '.$conf['PS_SHOP_ADDR2'] : '').' '.$conf['PS_SHOP_CODE'].' '.$conf['PS_SHOP_CITY'].
((isset($conf['PS_SHOP_STATE']) AND !empty($conf['PS_SHOP_STATE'])) ? (', '.$conf['PS_SHOP_STATE']) : '').' '.$conf['PS_SHOP_COUNTRY'] : '').
"\n".(!empty($conf['PS_SHOP_DETAILS']) ? self::l('Details:').' '.$conf['PS_SHOP_DETAILS'].' - ' : '').
(!empty($conf['PS_SHOP_PHONE']) ? self::l('PHONE:').' '.$conf['PS_SHOP_PHONE'] : '');
return $footerText;
* Invoice footer
public function Footer()
$this->Image('http://styleyourkids.nl/img/footer_new.jpg',10,270,190,0,'JPG');
public static function multipleInvoices($invoices)
$pdf = new PDF('P', 'mm', 'A4');
foreach ($invoices AS $id_order)
$orderObj = new Order((int)$id_order);
if (Validate::isLoadedObject($orderObj))
PDF::invoice($orderObj, 'D', true, $pdf);
return $pdf->Output('invoices.pdf', 'D');
public static function multipleOrderSlips($orderSlips)
foreach ($orderSlips AS $id_order_slip)
$orderSlip = new OrderSlip((int)$id_order_slip);
$order = new Order((int)$orderSlip->id_order);
$order->products = OrderSlip::getOrdersSlipProducts($orderSlip->id, $order);
if (Validate::isLoadedObject($orderSlip) AND Validate::isLoadedObject($order))
PDF::invoice($order, 'D', true, $pdf, $orderSlip);
return $pdf->Output('order_slips.pdf', 'D');
public static function multipleDelivery($slips)
foreach ($slips AS $id_order)
PDF::invoice($orderObj, 'D', true, $pdf, false, $orderObj->delivery_number);
public static function orderReturn($orderReturn, $mode = 'D', $multiple = false, &$pdf = NULL)
self::$orderReturn = $orderReturn;
$order = new Order($orderReturn->id_order);
self::$order = $order;
$pdf->SetAutoPageBreak(true, 35);
$pdf->StartPageGroup();
$pdf->AliasNbPages();
$pdf->AddPage();
/* Display address information */
$arrayConf = array('PS_SHOP_NAME', 'PS_SHOP_ADDR1', 'PS_SHOP_ADDR2', 'PS_SHOP_CODE', 'PS_SHOP_CITY', 'PS_SHOP_COUNTRY', 'PS_SHOP_DETAILS', 'PS_SHOP_PHONE', 'PS_SHOP_STATE');
$conf = Configuration::getMultiple($arrayConf);
foreach ($conf as $key => $value)
$conf[$key] = Tools::iconv('utf-8', self::encoding(), $value);
foreach ($arrayConf as $key)
if (!isset($conf[$key]))
$conf[$key] = '';
$width = 100;
$pdf->SetX(10);
$pdf->SetY(25);
$pdf->SetFont(self::fontname(), '', 8);
$addressType = array(
'invoice' => array(),
'delivery' => array());
$patternRules = array(
'avoid' => array(
'address2',
'company',
'phone',
'phone_mobile'));
$addressType = self::generateHeaderAddresses($pdf, $order, $addressType, $patternRules, $width);
* display order information
$pdf->Ln(12);
$pdf->SetFillColor(240, 240, 240);
$pdf->SetTextColor(0, 0, 0);
$pdf->SetFont(self::fontname(), '', 9);
$pdf->Cell(0, 6, self::l('RETURN #').sprintf('%06d', self::$orderReturn->id).' '.self::l('from') . ' ' .Tools::displayDate(self::$orderReturn->date_upd, self::$order->id_lang), 1, 2, 'L');
$pdf->Cell(0, 6, self::l('We have logged your return request.'), 'TRL', 2, 'L');
$pdf->Cell(0, 6, self::l('Your package must be returned to us within').' '.Configuration::get('PS_ORDER_RETURN_NB_DAYS').' '.self::l('days of receiving your order.'), 'BRL', 2, 'L');
$pdf->Ln(5);
$pdf->Cell(0, 6, self::l('List of items marked as returned :'), 0, 2, 'L');
$pdf->Ln(5);
$pdf->ProdReturnTab();
$pdf->Ln(5);
$pdf->SetFont(self::fontname(), 'B', 10);
$pdf->Cell(0, 6, self::l('Return reference:').' '.self::l('RET').sprintf('%06d', self::$order->id), 0, 2, 'C');
$pdf->Cell(0, 6, self::l('Please include this number on your return package.'), 0, 2, 'C');
$pdf->Ln(5);
$pdf->SetFont(self::fontname(), 'B', 9);
$pdf->Cell(0, 6, self::l('REMINDER:'), 0, 2, 'L');
$pdf->Cell(0, 6, self::l('- All products must be returned in their original packaging without damage or wear.'), 0, 2, 'L');
$pdf->Cell(0, 6, self::l('- Please print out this document and slip it into your package.'), 0, 2, 'L');
$pdf->Cell(0, 6, self::l('- The package should be sent to the following address:'), 0, 2, 'L');
$pdf->Ln(5);
$pdf->Cell(0, 5, Tools::strtoupper($conf['PS_SHOP_NAME']), 0, 1, 'C', 1);
$pdf->Cell(0, 5, (!empty($conf['PS_SHOP_ADDR1']) ? self::l('Headquarters:').' '.$conf['PS_SHOP_ADDR1'].(!empty($conf['PS_SHOP_ADDR2']) ? ' '.$conf['PS_SHOP_ADDR2'] : '').' '.$conf['PS_SHOP_CODE'].' '.$conf['PS_SHOP_CITY'].' '.$conf['PS_SHOP_COUNTRY'].((isset($conf['PS_SHOP_STATE']) AND !empty($conf['PS_SHOP_STATE'])) ? (', '.$conf['PS_SHOP_STATE']) : '') : ''), 0, 1, 'C', 1);
$pdf->Ln(5);
$pdf->Cell(0, 6, self::l('Upon receiving your package, we will notify you by e-mail. We will then begin processing the reimbursement of your order total.'), 0, 2, 'L');
$pdf->Cell(0, 6, self::l('Let us know if you have any questions.'), 0, 2, 'L');
$pdf->Ln(5);
$pdf->Cell(0, 6, self::l('If the conditions of return listed above are not respected,'), 'TRL', 2, 'C');
$pdf->Cell(0, 6, self::l('we reserve the right to refuse your package and/or reimbursement.'), 'BRL', 2, 'C');
return $pdf->Output(sprintf('%06d', self::$order->id).'.pdf', $mode);
* Product table with references, quantities...
public function ProdReturnTab()
$header = array(
array(self::l('Description'), 'L'),
array(self::l('Reference'), 'L'),
array(self::l('Qty'), 'C')
$w = array(110, 25, 20);
$this->SetFont(self::fontname(), 'B', 8);
$this->SetFillColor(240, 240, 240);
for ($i = 0; $i < sizeof($header); $i++)
$this->Cell($w[$i], 5, $header[$i][0], 'T', 0, $header[$i][1], 1);
$this->Ln();
$this->SetFont(self::fontname(), '', 7);
$products = OrderReturn::getOrdersReturnProducts(self::$orderReturn->id, self::$order);
foreach ($products AS $product)
$before = $this->GetY();
$this->MultiCell($w[0], 5, Tools::iconv('utf-8', self::encoding(), $product['product_name']), 'B');
$lineSize = $this->GetY() - $before;
$this->SetXY($this->GetX() + $w[0], $this->GetY() - $lineSize);
$this->Cell($w[1], $lineSize, ($product['product_reference'] != '' ? Tools::iconv('utf-8', self::encoding(), $product['product_reference']) : '---'), 'B');
$this->Cell($w[2], $lineSize, $product['product_quantity'], 'B', 0, 'C');
$this->Ln();
* Generate the header addresses for pdf File
public static function generateHeaderAddresses(&$pdf, $order, $addressType, $patternRules, $width)
$maxY = 0;
$pdf->setY($pdf->GetY() + 5);
foreach(array_keys($addressType) as $type)
$currentY = $pdf->GetY();
$attributeName = 'id_address_'.$type;
$addressType['delivery']['displayed'] = '';
$addressType['delivery']['addressObject'] = new Address((int)($order->$attributeName));
$addressType['delivery']['addressFields'] = AddressFormat::getOrderedAddressFields($addressType[$type]['addressObject']->id_country);
$addressType['delivery']['addressFormatedValues'] = AddressFormat::getFormattedAddressFieldsValues(
$addressType['delivery']['addressObject'],
$addressType['delivery']['addressFields']);
foreach ($addressType[$type]['addressFields'] as $line)
if (($patternsList = explode(' ', $line)))
$tmp = '';
foreach($patternsList as $pattern)
if (!in_array($pattern, $patternRules['avoid']))
if ($pattern == 'State:name' &&
$state_name = &$addressType[$type]['addressFormatedValues'][$pattern];
$state = new State((int)State::getIdByName($state_name));
if (Validate::isLoadedObject($state))
$state_name = $state->iso_code;
else
$state_name = strtoupper(substr($state_name, 0, 2));
$tmp .= ((isset($addressType['delivery']['addressFormatedValues'][$pattern]) &&
!empty($addressType['delivery']['addressFormatedValues'][$pattern])) ?
(Tools::iconv('utf-8', self::encoding(), $addressType['delivery']['addressFormatedValues'][$pattern]).' ') : '');
$tmp = trim($tmp);
$addressType['delivery']['displayed'] .= (!empty($tmp)) ? $tmp."\n" : '';
$pdf->MultiCell($width, 6.0, $addressType['delivery']['displayed'], 0, 'L', 0);
if ($pdf->GetY() > $maxY)
$maxY = $pdf->GetY();
$pdf->SetY($currentY);
$pdf->SetX($width + 10);
$pdf->Multicell(30, 5.0,"STYLE YOUR KIDS\nBosven 35\n5464 NA VEGHEL");
//$pdf->MultiCell(30, 6.0, 'STYLE YOUR KIDS Bosven 35 5464-NA Veghel', 0, 'L', 0);
$pdf->SetY($maxY);
if ($maxY)
$pdf->Ln(5);
return $addressType;
* Main
* @param object $order Order
* @param string $mode Download or display (optional)
public static function invoice($order, $mode = 'D', $multiple = false, &$pdf = NULL, $slip = false, $delivery = false)
global $cookie;
if (!Validate::isLoadedObject($order) OR (!$cookie->id_employee AND (!OrderState::invoiceAvailable($order->getCurrentState()) AND !$order->invoice_number)))
die('Invalid order or invalid order state');
self::$orderSlip = $slip;
self::$delivery = $delivery;
self::$_iso = strtoupper(Language::getIsoById((int)(self::$order->id_lang)));
if ((self::$_priceDisplayMethod = $order->getTaxCalculationMethod()) === false)
die(self::l('No price display method defined for the customer group'));
if (!$multiple)
self::$currency = Currency::getCurrencyInstance((int)(self::$order->id_currency));
$pdf->AddPage();
$width = 140;
$pdf->SetX(10);
$pdf->SetY(40);
'delivery' => array(),
'optional' => array(
'address2',
'company'),
'avoid' => array(
'State:iso_code'));
if (Configuration::get('VATNUMBER_MANAGEMENT') AND !empty($addressType['invoice']['addressObject']->vat_number))
$vat_delivery = '';
if ($addressType['invoice']['addressObject']->id != $addressType['delivery']['addressObject']->id)
$vat_delivery = $addressType['delivery']['addressObject']->vat_number;
$pdf->Cell($width, 10, Tools::iconv('utf-8', self::encoding(), $vat_delivery), 0, 'L');
$pdf->Cell($width, 10, Tools::iconv('utf-8', self::encoding(), $addressType['invoice']['addressObject']->vat_number), 0, 'L');
$pdf->Ln(5);
if ($addressType['invoice']['addressObject']->dni != NULL)
self::l('Tax ID number:').' '.Tools::iconv('utf-8', self::encoding(),
$addressType['invoice']['addressObject']->dni), 0, 'L');
$carrier = new Carrier(self::$order->id_carrier);
if ($carrier->name == '0')
$carrier->name = Configuration::get('PS_SHOP_NAME');
$history = self::$order->getHistory(self::$order->id_lang);
foreach($history as $h)
if ($h['id_order_state'] == Configuration::get('PS_OS_SHIPPING'))
$shipping_date = $h['date_add'];
$pdf->Ln(12);
$pdf->SetFillColor(255, 255, 255);
if (self::$orderSlip)
$pdf->Cell(0, 6, self::l('SLIP #').' '.sprintf('%06d', self::$orderSlip->id).' '.self::l('from') . ' ' .Tools::displayDate(self::$orderSlip->date_upd, self::$order->id_lang), 0, 2, 'L', 1);
elseif (self::$delivery)
$pdf->Cell(0, 6, self::l('DELIVERY SLIP #').Tools::iconv('utf-8', self::encoding(), Configuration::get('PS_DELIVERY_PREFIX', (int)($cookie->id_lang))).sprintf('%06d', self::$delivery).' '.self::l('from') . ' ' .Tools::displayDate(self::$order->delivery_date, self::$order->id_lang), 0, 2, 'L', 1);
elseif ((int)self::$order->invoice_date)
$pdf->SetFont(self::fontname(), 'B', 8);
$pdf->Cell(0, 6, self::l('FACTUUR'), 0, 2, 'L', 1);
$pdf->Cell(0, 6, self::l('Datum:'). ' ' .Tools::displayDate(self::$order->invoice_date, self::$order->id_lang), 0, 2, 'L', 1);
$pdf->Cell(0, 6, self::l('Klantnummer:'). ' ' .$order->id_customer, 0, 2, 'L', 1);
$pdf->Cell(0, 6, self::l('Factuurnummer:').' '.Tools::iconv('utf-8', self::encoding(), Configuration::get('PS_INVOICE_PREFIX', (int)($cookie->id_lang))).sprintf('%06d', self::$order->invoice_number), 0, 2, 'L', 1);
/*$pdf->Cell(0, 6, self::l('FACTUR #').' '.Tools::iconv('utf-8', self::encoding(), Configuration::get('PS_INVOICE_PREFIX', (int)($cookie->id_lang))).sprintf('%06d', self::$order->invoice_number).' '.self::l('from') . ' ' .Tools::displayDate(self::$order->invoice_date, self::$order->id_lang), 0, 2, 'L', 1);*/
else{
$pdf->Cell(0, 6, self::l('Invoice draft'), 0, 2, 'L', 1);
$pdf->Cell(0, 6, self::l('Bestelnunmmer: ').' '.sprintf('%06d', self::$order->id), 0, 2, 'L', 1);
/*$pdf->Cell(70, 6, self::l('Carrier:').($order->gift ? ' '.Tools::iconv('utf-8', self::encoding(), $carrier->name) : ''), 'L');
$pdf->Cell(0, 6, self::l('Payment method:'), 'LR');*/
$pdf->Ln(5);
$pdf->ProdTab((self::$delivery ? true : ''));
/* Canada */
$taxable_address = new Address((int)self::$order->{Configuration::get('PS_TAX_ADDRESS_TYPE')});
if (!self::$delivery && strtoupper(Country::getIsoById((int)$taxable_address->id_country)) == 'CA')
$pdf->Ln(15);
$taxToDisplay = Db::getInstance()->ExecuteS('SELECT * FROM '._DB_PREFIX_.'order_tax WHERE id_order = '.(int)self::$order->id);
foreach ($taxToDisplay AS $t)
$pdf->Cell(0, 6, utf8_decode($t['tax_name']).' ('.number_format($t['tax_rate'], 2, '.', '').'%) '.self::convertSign(Tools::displayPrice($t['amount'], self::$currency, true)), 0, 0, 'R');
$pdf->Ln(5);
/* End */
/* Exit if delivery */
if (!self::$delivery)
if (!self::$orderSlip)
$pdf->DiscTab();
$priceBreakDown = array();
$pdf->priceBreakDownCalculation($priceBreakDown);
if (!self::$orderSlip OR (self::$orderSlip AND self::$orderSlip->shipping_cost))
$priceBreakDown['totalWithoutTax'] += Tools::ps_round($priceBreakDown['shippingCostWithoutTax'], 2) + Tools::ps_round($priceBreakDown['wrappingCostWithoutTax'], 2);
$priceBreakDown['totalWithTax'] += self::$order->total_shipping + self::$order->total_wrapping;
$taxDiscount = self::$order->getTaxesAverageUsed();
if ($taxDiscount != 0)
$priceBreakDown['totalWithoutTax'] -= Tools::ps_round(self::$order->total_discounts / (1 + self::$order->getTaxesAverageUsed() * 0.01), 2);
else
$priceBreakDown['totalWithoutTax'] -= self::$order->total_discounts;
// The discount is already applied in Tax Incl mode
if (self::$_priceDisplayMethod == PS_TAX_EXC)
$priceBreakDown['totalWithTax'] -= self::$order->total_discounts;
* Display price summation
if (Configuration::get('PS_TAX') OR $order->total_products_wt != $order->total_products)
$pdf->Ln(5);
$width = 165;
$pdf->Cell($width, 0, self::l('Subtotaal').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice($priceBreakDown['totalProductsWithoutTax'], self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
$width = 165;
/*$pdf->Cell($width, 0, self::l('Total products (tax incl.)').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice($priceBreakDown['totalProductsWithTax'], self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);*/
else
$pdf->Ln(5);
$width = 165;
$pdf->Cell($width, 0, self::l('Total products ').' : ', 0, 0, 'R');
$pdf->Ln(4);
if (!self::$orderSlip AND self::$order->total_discounts != '0.00')
$pdf->Cell($width, 0, self::l('Total discounts (tax incl.)').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (!self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(self::$order->total_discounts, self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
if (isset(self::$order->total_wrapping) and ((float)(self::$order->total_wrapping) > 0))
$pdf->Cell($width, 0, self::l('Total gift-wrapping').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice($priceBreakDown['wrappingCostWithoutTax'], self::$currency, true)), 0, 0, 'R');
else
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(self::$order->total_wrapping, self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
if (self::$order->total_shipping != '0.00' AND (!self::$orderSlip OR (self::$orderSlip AND self::$orderSlip->shipping_cost)))
$pdf->Cell($width, 0, self::l('Total shipping (tax excl.)').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(Tools::ps_round($priceBreakDown['shippingCostWithoutTax'], 2), self::$currency, true)), 0, 0, 'R');
else
$pdf->Cell($width, 0, self::l('verzendkosten').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(self::$order->total_shipping, self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
/*$pdf->Cell($width, 0, self::l('Totaal ').' '.(self::$_priceDisplayMethod == PS_TAX_EXC ? self::l(' (tax incl.)') : self::l(' (tax excl.)')).' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice((self::$_priceDisplayMethod == PS_TAX_EXC ? $priceBreakDown['totalWithTax'] : $priceBreakDown['totalWithoutTax']), self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);*/
$VAT= $priceBreakDown['totalProductsWithTax']-$priceBreakDown['totalProductsWithoutTax'];
$pdf->Cell($width, 0, self::l('BTW').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(Tools::ps_round($VAT, 2), self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
$pdf->Cell($width, 0, self::l('Total').' '.(self::$_priceDisplayMethod == PS_TAX_EXC ? self::l(' (BTW excl.)') : self::l(' (incl.BTW )')).' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice((self::$_priceDisplayMethod == PS_TAX_EXC ? $priceBreakDown['totalWithoutTax'] : $priceBreakDown['totalWithTax']), self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
else
$pdf->Cell($width, 0, self::l('Total').' : ', 0, 0, 'R');
$pdf->Cell(0, 0, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice(($priceBreakDown['totalWithoutTax']), self::$currency, true)), 0, 0, 'R');
$pdf->Ln(4);
$pdf->TaxTab($priceBreakDown);
Hook::PDFInvoice($pdf, self::$order->id);
if (!$multiple)
public function ProdTabHeader($delivery = false)
if (!$delivery)
$header = array(
array(self::l('Artikel beschrijving'), 'L'),
array(self::l('Referentie'), 'L'),
array(self::l('Aantal'), 'C'),
array(self::l('BTW'), 'C'),
array(self::l('Prijs (incl. BTW)'), 'R')
$w = array(100, 15, 30, 15, 30);
else
$header = array(
array(self::l('Qty'), 'C'),
$w = array(120, 30, 10);
$this->SetFillColor(255, 255, 255);
if ($delivery)
$this->SetX(10);
$this->Cell($w[$i], 5, $header[$i][0], '0', 0, $header[$i][1], 1);
$this->Ln();
$this->SetFont(self::fontname(), '', 8);
* Product table with price, quantities...
public function ProdTab($delivery = false)
if (!$delivery)
else
self::ProdTabHeader($delivery);
if (isset(self::$order->products) AND sizeof(self::$order->products))
$products = self::$order->products;
else
$products = self::$order->getProducts();
else
$products = self::$orderSlip->getOrdersSlipProducts(self::$orderSlip->id, self::$order);
$customizedDatas = Product::getAllCustomizedDatas((int)(self::$order->id_cart));
Product::addCustomizationPrice($products, $customizedDatas);
$counter = 0;
$lines = 25;
$lineSize = 0;
$line = 0;
foreach($products AS $product)
if (!$delivery OR ((int)($product['product_quantity']) - (int)($product['product_quantity_refunded']) > 0))
if ($counter >= $lines)
$this->AddPage();
$this->Ln();
$lineSize = 0;
$counter = 0;
$lines = 40;
$line++;
$counter = $counter + ($lineSize / 5) ;
$i = -1;
// Unit vars
$unit_without_tax = $product['product_price'] + $product['ecotax'];
$unit_with_tax = $product['product_price_wt'];
$unit_price = &$unit_without_tax;
else
$unit_price = &$unit_with_tax;
$productQuantity = $delivery ? ((int)($product['product_quantity']) - (int)($product['product_quantity_refunded'])) : (int)($product['product_quantity']);
if ($productQuantity <= 0)
continue ;
// Total prices
$total_with_tax = $unit_with_tax * $productQuantity;
$total_without_tax = $unit_without_tax * $productQuantity;
// Spec
$final_price = &$total_without_tax;
else
$final_price = &$total_with_tax;
// End Spec
if (isset($customizedDatas[$product['product_id']][$product['product_attribute_id']]))
$custoLabel = '';
foreach($customizedDatas[$product['product_id']][$product['product_attribute_id']] as $customizedData)
$customizationGroup = $customizedData['datas'];
$nb_images = 0;
if (array_key_exists(_CUSTOMIZE_FILE_, $customizationGroup))
$nb_images = sizeof($customizationGroup[_CUSTOMIZE_FILE_]);
if (array_key_exists(_CUSTOMIZE_TEXTFIELD_, $customizationGroup))
foreach($customizationGroup[_CUSTOMIZE_TEXTFIELD_] as $customization)
if (!empty($customization['name'])) $custoLabel .= '- '.$customization['name'].': '.$customization['value']."\n";
if ($nb_images > 0)
$custoLabel .= '- '.$nb_images. ' '. self::l('image(s)')."\n";
$custoLabel .= "---\n";
$custoLabel = rtrim($custoLabel, "---\n");
$productQuantity = (int)($product['product_quantity']) - (int)($product['customizationQuantityTotal']);
if ($delivery)
$this->SetX(25);
$this->MultiCell($w[++$i], 5, Tools::iconv('utf-8', self::encoding(), $product['product_name']).' - '.self::l('Customized')." \n".Tools::iconv('utf-8', self::encoding(), $custoLabel), '0');
$this->SetXY($this->GetX() + $w[0] + ($delivery ? 15 : 0), $this->GetY() - $lineSize);
$this->Cell($w[++$i], $lineSize, $product['product_reference'], '0');
if (!$delivery)
$this->Cell($w[++$i], $lineSize, (int)($product['customizationQuantityTotal']), '0', 0, 'C');
if (!$delivery)
$this->Cell($w[++$i], $lineSize, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice($unit_price * (int)($product['customizationQuantityTotal']), self::$currency, true)), '0', 0, 'R');
$this->Ln();
$i = -1;
if ($delivery)
$this->SetX(10);
if ($productQuantity)
$this->MultiCell($w[++$i], 5, Tools::iconv('utf-8', self::encoding(), $product['product_name']), '');
$this->SetXY($this->GetX() + $w[0] + ($delivery ? 0 : 0), $this->GetY() - $lineSize);
$this->Cell($w[++$i], $lineSize, ($product['product_reference'] ? Tools::iconv('utf-8', self::encoding(), $product['product_reference']) : '--'), '');
if (!$delivery)
$this->Cell($w[++$i], $lineSize, $productQuantity, '', 0, 'C');
$this->Cell($w[++$i], $lineSize,self::l(' '), '', 0, 'R');
if ($delivery)
if (!$delivery)
$this->Cell($w[++$i], $lineSize, (self::$orderSlip ? '-' : '').self::convertSign(Tools::displayPrice($final_price, self::$currency, true)), '', 0, 'R');
$this->Ln();
if (!sizeof(self::$order->getDiscounts()) AND !$delivery)
$this->Cell(array_sum($w), 0, '');
* Discount table with value, quantities...
public function DiscTab()
$w = array(90, 25, 15, 10, 25, 25);
$this->SetFont(self::fontname(), 'B', 7);
$discounts = self::$order->getDiscounts();
foreach($discounts AS $discount)
$this->Cell($w[0], 6, self::l('Discount:').' '.$discount['name'], 'B');
$this->Cell($w[1], 6, '', 'B');
$this->Cell($w[2], 6, '', 'B');
$this->Cell($w[3], 6, '', 'B', 0, 'R');
$this->Cell($w[4], 6, '1', 'B', 0, 'C');
$discount_value = $discount['value'];
$tax_rate_discount = 0;
$tax_rate_discount = self::$order->getTaxesAverageUsed();
$discount_value = $discount_value / (1 + $tax_rate_discount / 100);
$this->Cell($w[5], 6, ((!self::$orderSlip && ($discount['value'] != 0.00)) ? '-' : '').self::convertSign(Tools::displayPrice($discount_value, self::$currency, true)), 'B', 0, 'R');
$this->Ln();
if (sizeof($discounts))
public function priceBreakDownCalculation(&$priceBreakDown)
$priceBreakDown['totalsWithoutTax'] = array();
$priceBreakDown['totalsWithTax'] = array();
$priceBreakDown['totalsEcotax'] = array();
$priceBreakDown['wrappingCostWithoutTax'] = 0;
$priceBreakDown['shippingCostWithoutTax'] = 0;
$priceBreakDown['totalWithoutTax'] = 0;
$priceBreakDown['totalWithTax'] = 0;
$priceBreakDown['totalProductsWithoutTax'] = 0;
$priceBreakDown['totalProductsWithTax'] = 0;
$priceBreakDown['hasEcotax'] = 0;
$priceBreakDown['totalsProductsWithTaxAndReduction'] = array();
if (self::$order->total_paid == '0.00' AND self::$order->total_discounts == 0)
return ;
// Setting products tax
else
$amountWithoutTax = 0;
$taxes = array();
/* Firstly calculate all prices */
foreach ($products AS &$product)
if (!isset($priceBreakDown['totalsWithTax'][$product['tax_rate']]))
$priceBreakDown['totalsWithTax'][$product['tax_rate']] = 0;
if (!isset($priceBreakDown['totalsEcotax'][$product['tax_rate']]))
$priceBreakDown['totalsEcotax'][$product['tax_rate']] = 0;
if (!isset($priceBreakDown['totalsEcotaxWithTax'][$product['tax_rate']]))
$priceBreakDown['totalsEcotaxWithTax'][$product['tax_rate']] = 0;
if (!isset($priceBreakDown['totalsWithoutTax'][$product['tax_rate']]))
$priceBreakDown['totalsWithoutTax'][$product['tax_rate']] = 0;
if (!isset($taxes[$product['tax_rate']]))
$taxes[$product['tax_rate']] = 0;
if (!isset($priceBreakDown['totalsProductsWithTaxAndReduction'][$product['tax_rate']]))
$priceBreakDown['totalsProductsWithTaxAndReduction'][$product['tax_rate']] = 0;
if (!isset($priceBreakDown['totalsProductsWithoutTaxAndReduction'][$product['tax_rate']]))
$priceBreakDown['totalsProductsWithoutTaxAndReduction'][$product['tax_rate']] = 0;
/* Without tax */
$product['priceWithoutTax'] = Tools::ps_round((float)($product['product_price']) + (float)$product['ecotax'], 2);
else
$product['priceWithoutTax'] = ($product['product_price_wt_but_ecotax'] / (1 + $product['tax_rate'] / 100)) + (float)$product['ecotax'];
$product['priceWithoutTax'] = $product['priceWithoutTax'] * (int)($product['product_quantity']);
$amountWithoutTax += $product['priceWithoutTax'];
/* With tax */
$product['priceWithTax'] = (float)($product['product_price_wt']) * (int)($product['product_quantity']);
$product['priceEcotax'] = $product['ecotax'] * (1 + $product['ecotax_tax_rate'] / 100);
$priceBreakDown['totalsProductsWithoutTax'] = $priceBreakDown['totalsWithoutTax'];
$priceBreakDown['totalsProductsWithTax'] = $priceBreakDown['totalsWithTax'];
$tmp = 0;
$product = &$tmp;
/* And secondly assign to each tax its own reduction part */
$discountAmount = 0;
$discountAmount = (float)(self::$order->total_discounts);
foreach ($products as $product)
$ratio = $amountWithoutTax == 0 ? 0 : $product['priceWithoutTax'] / $amountWithoutTax;
$priceWithTaxAndReduction = $product['priceWithTax'] - $discountAmount * $ratio;
$discountAmountWithoutTax = ($discountAmount * $ratio) / (1 + ($product['tax_rate'] / 100));
$vat = $priceWithTaxAndReduction - Tools::ps_round($priceWithTaxAndReduction / $product['product_quantity'] / (((float)($product['tax_rate']) / 100) + 1), 2) * $product['product_quantity'];
$priceBreakDown['totalsWithoutTax'][$product['tax_rate']] += $product['priceWithoutTax'] ;
$priceBreakDown['totalsProductsWithoutTax'][$product['tax_rate']] += $product['priceWithoutTax'];
$total_ecotax = ($product['priceEcotax'] * $product['product_quantity']);
$priceBreakDown['totalsProductsWithTax'][$product['tax_rate']] += Tools::ps_round((($product['priceWithoutTax'] - $total_ecotax) * (1 + $product['tax_rate'] / 100)) + $total_ecotax, 2);
$price_tax_excl_with_reduction = Tools::ps_round($product['priceWithoutTax'] - (float)$discountAmountWithoutTax, 2);
$priceBreakDown['totalsProductsWithoutTaxAndReduction'][$product['tax_rate']] += $price_tax_excl_with_reduction;
$priceBreakDown['totalsProductsWithTaxAndReduction'][$product['tax_rate']] += Tools::ps_round(($price_tax_excl_with_reduction - $total_ecotax) * (1 + $product['tax_rate'] / 100) + $total_ecotax, 2);
else
$vat = (float)($product['priceWithoutTax']) * ((float)($product['tax_rate']) / 100) * $product['product_quantity'];
$priceBreakDown['totalsWithTax'][$product['tax_rate']] += $product['priceWithTax'];
$priceBreakDown['totalsProductsWithTax'][$product['tax_rate']] += $product['priceWithTax'];
$priceBreakDown['totalsProductsWithTaxAndReduction'][$product['tax_rate']] += $priceWithTaxAndReduction;
$priceBreakDown['totalsEcotax'][$product['tax_rate']] += ($product['priceEcotax'] * $product['product_quantity']);
$priceBreakDown['totalsEcotaxWithTax'][$product['tax_rate']] += ($product['priceEcotax'] * (1 + ($product['ecotax_tax_rate'] / 100)) * $product['product_quantity']);
if ($priceBreakDown['totalsEcotax'][$product['tax_rate']])
$priceBreakDown['hasEcotax'] = 1;
$taxes[$product['tax_rate']] += $vat;
$carrier_tax_rate = (float)self::$order->carrier_tax_rate;
if (($priceBreakDown['totalsWithoutTax'] == $priceBreakDown['totalsWithTax']) AND (!$carrier_tax_rate OR $carrier_tax_rate == '0.00') AND (!self::$order->total_wrapping OR self::$order->total_wrapping == '0.00'))
return ;
foreach ($taxes AS $tax_rate => &$vat)
$priceBreakDown['totalsWithoutTax'][$tax_rate] = Tools::ps_round($priceBreakDown['totalsWithoutTax'][$tax_rate], 2);
$priceBreakDown['totalsProductsWithoutTax'][$tax_rate] = Tools::ps_round($priceBreakDown['totalsWithoutTax'][$tax_rate], 2);
//$total_with_tax = Tools::ps_round(($priceBreakDown['totalsWithoutTax'][$tax_rate]- $priceBreakDown['totalsEcotax'][$tax_rate]) * (1 + $tax_rate / 100) + $priceBreakDown['totalsEcotaxWithTax'][$tax_rate], 2);
$priceBreakDown['totalsWithTax'][$tax_rate] = $priceBreakDown['totalsProductsWithTax'][$tax_rate];
$priceBreakDown['totalWithTax'] += $priceBreakDown['totalsProductsWithTax'][$tax_rate];
else
$priceBreakDown['totalsWithoutTax'][$tax_rate] = $priceBreakDown['totalsProductsWithoutTax'][$tax_rate];
$priceBreakDown['totalsProductsWithoutTax'][$tax_rate] = Tools::ps_round($priceBreakDown['totalsProductsWithoutTax'][$tax_rate], 2);
$priceBreakDown['totalsProductsWithoutTaxAndReduction'][$tax_rate] = $priceBreakDown['totalsProductsWithTaxAndReduction'][$tax_rate] / (1 + ($tax_rate / 100));
$priceBreakDown['totalWithTax'] += $priceBreakDown['totalsProductsWithTaxAndReduction'][$tax_rate];
$priceBreakDown['totalWithoutTax'] += $priceBreakDown['totalsWithoutTax'][$tax_rate];
$priceBreakDown['totalProductsWithoutTax'] += $priceBreakDown['totalsProductsWithoutTax'][$tax_rate];
$priceBreakDown['totalProductsWithTax'] += $priceBreakDown['totalsProductsWithTax'][$tax_rate];
$priceBreakDown['taxes'] = $taxes;
$priceBreakDown['shippingCostWithoutTax'] = ($carrier_tax_rate AND $carrier_tax_rate != '0.00') ? (self::$order->total_shipping / (1 + ($carrier_tax_rate / 100))) : self::$order->total_shipping;
if (self::$order->total_wrapping AND self::$order->total_wrapping != '0.00')
$wrappingTax = new Tax(Configuration::get('PS_GIFT_WRAPPING_TAX'));
$priceBreakDown['wrappingCostWithoutTax'] = self::$order->total_wrapping / (1 + ((float)($wrappingTax->rate) / 100));
* Tax table
public function TaxTab(&$priceBreakDown)
$nb_tax = 0;
// Display product tax
foreach (array_keys($priceBreakDown['taxes']) AS $tax_rate)
if ($tax_rate != '0.00' AND $priceBreakDown['totalsProductsWithTax'][$tax_rate] != '0.00')
$nb_tax++;
$this->Cell(158, -47,number_format($tax_rate,0, ',', ' ').' %', 0, 0, 'R');
if (!$nb_tax)
$this->Cell(190, 10, self::l('No tax'), 0, 0, 'C');
static protected function convertSign($s)
$arr['before'] = array('€', '£', '¥');
$arr['after'] = array(chr(128), chr(163), chr(165));
return str_replace($arr['before'], $arr['after'], $s);
static protected function l($string)
global $cookie;
$iso = Language::getIsoById((isset($cookie->id_lang) AND Validate::isUnsignedId($cookie->id_lang)) ? $cookie->id_lang : Configuration::get('PS_LANG_DEFAULT'));
if (@!include(_PS_TRANSLATIONS_DIR_.$iso.'/pdf.php'))
die('Cannot include PDF translation language file : '._PS_TRANSLATIONS_DIR_.$iso.'/pdf.php');
if (!isset($_LANGPDF) OR !is_array($_LANGPDF))
return str_replace('"', '"', $string);
$key = md5(str_replace('\'', '\\\'', $string));
$str = (key_exists('PDF_invoice'.$key, $_LANGPDF) ? $_LANGPDF['PDF_invoice'.$key] : $string);
return (Tools::iconv('utf-8', self::encoding(), $str));
public static function encoding()
return (isset(self::$_pdfparams[self::$_iso]) AND is_array(self::$_pdfparams[self::$_iso]) AND self::$_pdfparams[self::$_iso]['encoding']) ? self::$_pdfparams[self::$_iso]['encoding'] : 'iso-8859-1';
public static function embedfont()
return (((isset(self::$_pdfparams[self::$_iso]) AND is_array(self::$_pdfparams[self::$_iso]) AND self::$_pdfparams[self::$_iso]['font']) AND !in_array(self::$_pdfparams[self::$_iso]['font'], self::$_fpdf_core_fonts)) ? self::$_pdfparams[self::$_iso]['font'] : false);
public static function fontname()
$font = self::embedfont();
if (in_array(self::$_pdfparams[self::$_iso]['font'], self::$_fpdf_core_fonts))
$font = self::$_pdfparams[self::$_iso]['font'];
return $font ? $font : 'Trebuchet MS';
