Deep Freeze WIE begrijpt de ENGELSTALIGE woorden aub ?
Calimero007
7 jul 2008
Boot Frozen --------------------------- (begrijp ik zelf)
BOOT Thawed on next ...
Boot Thawed
WIE begrijpt de ENGELS-talige uitleg a.u.b. (gaag enkele woordjes in
het nederlands voor mij a.u.b.
1. Deep Freeze is installed on my machine. I would like to uninstall it. How is this done?
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Run the installation file (DF5Std.exe or DF6Std.exe).
Select the option to "Uninstall"
The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
2. How do I enable or disable Deep Freeze?
One or more methods can be employed to disable/enable (Thaw/Freeze) Deep Freeze depending on the edition being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
Hold down the shift button and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at: http://www.faronics.com/doc/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
Select the workstations you would like to Thaw/Freeze.
Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
DANK = DANK : zij je uitleg begrijp ik alles zo'n beetje VEEL beter : Dus hartelijk dank.
oa: De rest gaat erover g=dat je deepfreeze dus onwerkzaa maakt met thawned boot en weer inschakeld met frozen boot.
Dit werkt pas weer na een herstart van de pc. . . .
Dit gaat over het verwijderen van deepfreeze
deepfreeze moet eerst uitgeschakeld.
Dubbelklik op het deepfreeze icon terwijl je shift ingedrukt houdt.
Vul je wachtwoord in (of laat het vak leeg als je geen ww hebt opgegeven) en klik ok.
Kies "boot thawed" om deepfreeze voor de volgene opstart uit te schakelen.
Laat vervolgens de pc opnieuw opstarten.
Verwijder nu deepfreeze als volgt
Zoek het bestand (de download) wat je gebruikte om deepfreeze te installeren.
Dat heet standaad "DF6Std.exe" voor de nieuwste versie tenzij je zelf de naam hebt aangepast.
Voer dit uit door er op te dubbelklikken en kies oor de optie uninstall.
Asl het goed is gaat de pc hierna herstarten en ben je van deepfreeze af.
(remotely is op afstand via het netwerken gaat met een script, dat deel laat ik voor wat het is)
mvg leo
