default font ECDC label creator
Dick Borstlap
8 sep 2000
Weet iemand hoe ik het default font van ECDC label creator kan wijzigen?
Heb gezocht in het register, niet kunnen vinden.
Gevonden:
OK - we're talking about ECDC Platinum 5.3.2.
Try this:
Go to directory
Program Files/Common Files/Adaptec Shared/Label Creator/Style Files
Find the .jws file with the name of the "theme" you want to change.
Open it in Notepad
You will see the default font specified in there - along with lots of other spec's for that theme.
What I've done is take one of these, make some changes and save it under a different name, so I don't make a mess of themes which came with the program.
Be sure to give your modified theme a unique .jws name and use the same name INSIDE the .jws file also, so you'll be able to identify it inside Label Maker when you choose a theme to apply.
You be careful out there now . . . . :-)
