ik krijg de melding bij het runnen van een query "division by zero".
zie onderstaande UNION query.
het grappige is dat ie deze melding niet geeft als ik de SELECT statements apart draai.
[SQL]SELECT * INTO SpadeFeed
FROM (SELECT Assignaties.[Project description] AS Opportunity,
Assignaties.[Project closing date] AS [CTT Sign Date],
"EUR" AS [Currency],
Assignaties.[Customer name] AS Account,
Assignaties.[Sales Person] AS [Sales Team],
"7" AS [Sales stage],
"ITS Benelux" AS [Selling BU],
"A1..G3" AS Groupskillpractice,
"A1..G3" AS Skillpractice,
Format(IIf([FTE].[Betaaltijd] Is Null,(AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end])*8*([Rate]*([Assign %]/100))),(AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end])*8*([Rate]*([Assign %]/100)))*([FTE]![Betaaltijd]/100)),"Currency") AS Bookings,
Format(IIf(([Rate] Is Not Null Or Str([Rate])<>"0" Or Str([RATE])<>"0.00" Or Str([rate])<>"0,00"),(([Rate]-[DKM])/[Rate]),0),"0.0%") AS [Margin %], IIf([DeliveryUnit]="Subcontractor GDC","Mumbay","No") AS DistributedDelivery,
Assignaties.[Assign start] AS [Start Date],
AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end]) AS Duration,
"None" AS Alliance,
IIf(Len([Empl practice])=6,Right([Empl practice],3),[Empl practice]) AS DeliveryUnit,
"GOU ITS" AS SLOrganization, 1 AS CCSBooking,
1 AS CCSDays,
Assignaties.[Project Code],
Assignaties.[Prj practice],
(Format$(CDate(DateSerial(Year(Date()),Month(Date()),1)),"mm/yyyy")) AS [Month],
Assignaties.[Assign start],
Assignaties.[Assign end]
FROM DKM RIGHT JOIN (FTE RIGHT JOIN Assignaties ON FTE.Persnr = Assignaties.Number) ON DKM.level = FTE.level
WHERE
(([Assignaties]![Assign start])<DateSerial(Year(Date()),Month(Date()),1)
AND (([Assignaties]![Assign end])>DateSerial(Year(Date()),Month(Date()),0)))
OR
AND (([Assignaties]![Assign end]) Between DateSerial(Year(Date()),Month(Date()),0) And DateSerial(Year(Date()),Month(Date())+1,0)))
OR
(([Assignaties]![Assign start]) Between DateSerial(Year(Date()),Month(Date()),1)
And (DateSerial(Year(Date()),Month(Date())+1,0))) AND (([Assignaties]![Assign end])>DateSerial(Year(Date()),Month(Date()),0))
OR
(([Assignaties]![Assign start]) Between DateSerial(Year(Date()),Month(Date()),1) And DateSerial(Year(Date()),Month(Date())+1,0)
AND (([Assignaties]![Assign end]) Between DateSerial(Year(Date()),Month(Date())+1,0) And DateSerial(Year(Date()),Month(Date()),0)))
UNION SELECT
Assignaties.[Project description] AS Opportunity, Assignaties.[Project closing date] AS [CTT Sign Date], "EUR" AS [Currency], Assignaties.[Customer name] AS Account, Assignaties.[Sales Person] AS [Sales Team], "7" AS [Sales stage], "ITS Benelux" AS [Selling BU], "A1..G3" AS Groupskillpractice, "A1..G3" AS Skillpractice, Format(IIf([FTE].[Betaaltijd] Is Null,(AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end])*8*([Rate]*([Assign %]/100))),(AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end])*8*([Rate]*([Assign %]/100)))*([FTE]![Betaaltijd]/100)),"Currency") AS Bookings, Format(IIf(([Rate] Is Not Null Or Str([Rate])<>"0" Or Str([RATE])<>"0.00" Or Str([rate])<>"0,00"),(([Rate]-[DKM])/[Rate]),0),"0.0%") AS [Margin %], IIf([DeliveryUnit]="Subcontractor GDC","Mumbay","No") AS DistributedDelivery, Assignaties.[Assign start] AS [Start Date], AantalWerkdagen([Assignaties]![Assign start],[Assignaties]![Assign end]) AS Duration, "None" AS Alliance, IIf(Len([Empl practice])=6,Right([Empl practice],3),[Empl practice]) AS DeliveryUnit, "GOU ITS" AS SLOrganization, 1 AS CCSBooking, 1 AS CCSDays, Assignaties.[Project Code], Assignaties.[Prj practice], (Format$(CDate(DateSerial(Year(Date()),Month(Date())+1,1)),"mm/yyyy")) AS [Month],Assignaties.[Assign start],
WHERE
(([Assignaties]![Assign start])<DateSerial(Year(Date()),Month(Date())+1,1)
AND (([Assignaties]![Assign end])>DateSerial(Year(Date()),Month(Date())+2,0)))
OR
AND (([Assignaties]![Assign end]) Between DateSerial(Year(Date()),Month(Date())+2,0) And DateSerial(Year(Date()),Month(Date()),0)))
OR
(([Assignaties]![Assign start]) Between DateSerial(Year(Date()),Month(Date())+1,1)
And (DateSerial(Year(Date()),Month(Date())+2,0)) AND (([Assignaties]![Assign end])>DateSerial(Year(Date()),Month(Date())+2,0)))
OR
(([Assignaties]![Assign start]) Between DateSerial(Year(Date()),Month(Date())+1,1) And DateSerial(Year(Date()),Month(Date())+2,0)
AND (([Assignaties]![Assign end]) Between DateSerial(Year(Date()),Month(Date()),0) And DateSerial(Year(Date()),Month(Date())+2,0) ))) AS [%$##@_Alias];[/SQL]
Gaarne hulp
"None" AS Alliance,
1 AS CCSDays,
WHERE
OR
OR
OR
UNION SELECT
WHERE
OR
OR
OR
Gaarne hulp
