BlackHawkRobbo
- 8 okt 2006
Heey allemaal!
Ik heb net een andere videokaart in mn PC gepropt, en de drivers geinstelleerd. Alles werkt goed, op Direct-3D na. Ik heb directx 9.0c (van oktober 2006) geinstelaaerd.
Dit is het DXDIAG logje:
System Information
Time of this report: 11/27/2006, 16:27:57
Machine name: timkamer
Operating System: Windows Me (4.90, Build 3000)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: Dynabyte
System Model: MS-6309
BIOS: Award
Processor: Intel Pentium III, ~730MHz
Memory: 192MB RAM
Page File: 0MB used, 1856MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 4.09.0000.0904 32bit
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nvdisp.drv is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. DirectDraw test results: All tests were successful. Direct3D 7 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x887602eb (error code) Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086a (3D not available) Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086a (3D not available)
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: All tests were successful.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX 4000
Manufacturer: NVIDIA
Chip type:
DAC type:
Device Key: Enum\PCI\VEN_10DE&DEV_0185&SUBSYS_00000000&REV_C1\000800
Display Memory: 2074.5 MB
Current Mode: 1280 x 1024 (16 bit)(optimal refresh rate)
Monitor: PHILIPS 107E
Monitor Max Res: 1600,1200
Driver Name: nvdisp.drv
Driver Version: 4.14.0010.7772 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/15/2005 17:20:00, 131488 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: *vdd
Mini VDD: nvmini.vxd
Mini VDD Date: , 0 bytes
Device Identifier: {D7B71E3E-42C5-11CF-EC7D-0A2060C2C935}
Vendor ID: 0x10DE
Device ID: 0x0185
SubSys ID: 0x00000000
Revision ID: 0x00C1
Revision ID: 0x00C1
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x887602eb (error code)
D3D8 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086a (3D not available)
D3D9 Test Result: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086a (3D not available)
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_1371&SUBSYS_30901462&REV_07\BUS_00&DEV_0C&FUNC_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 4.90.2490.0000 (English)
WHQL Logo'd: Yes
Date and Size: 6/8/2000 17:00:00, 41584 bytes
Other Files: es1371mp.sys
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\system32\drivers\gm.dls
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
MIDI Mapper, Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth, Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative MPU401, Hardware (Not Kernel Mode), Output, No DLS, External
Creative MPU401, Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech WingMan Extreme
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: Yes
Registry: OK
USB Devices
Gameport Devices
PS/2 Devices
DirectPlay Service Providers
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0904)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: All tests were successful.
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: 1
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Motocross Madness 2 (DX7) - Registry: OK, ExeFile: mcm2.ICD (20.13.0004.2901)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 3.7 GB
Total Space: 4.9 GB
File System: FAT32
Model: n/a
Drive: D:
Model: n/a
Drive: E:
Free Space: 49.1 GB
Total Space: 50.0 GB
File System: FAT32
Model: n/a
Drive: F:
Free Space: 1.0 GB
Total Space: 1.0 GB
File System: FAT
Model: n/a
Drive: G:
Free Space: 0.5 GB
Total Space: 0.5 GB
File System: FAT
Model: n/a
Drive: H:
Free Space: 40.0 GB
Total Space: 40.0 GB
File System: FAT32
Model: n/a
Drive: I:
Free Space: 10.0 GB
Total Space: 10.0 GB
File System: FAT32
Model: n/a
Drive: J:
Free Space: 19.7 GB
Total Space: 20.0 GB
File System: FAT32
Model: n/a
Drive: K:
Free Space: 4.6 GB
Total Space: 4.6 GB
File System: FAT32
Model: n/a
Drive: L:
Model: LITEON CD-ROM LTN485S
DirectX Components
ddraw.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 399872 bytes
ddraw16.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 28496 bytes
ddrawex.dll: 4.87.0000.0700 English Final Retail 6/8/2000 17:00:00 36864 bytes
ddraw.vxd: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 30469 bytes
ddhelp.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dxapi.sys: 4.87.0000.0700 English Final Retail 6/8/2000 17:00:00 2416 bytes
d3d8.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 1234944 bytes
d3d9.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 1660928 bytes
d3dim.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 638976 bytes
d3dim700.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 892416 bytes
d3dref.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 155648 bytes
d3dramp.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 606208 bytes
d3drm.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 446464 bytes
d3dxof.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 118784 bytes
d3dpmesh.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 102400 bytes
dplay.dll: 4.03.0000.1096 Dutch Final Retail 6/8/2000 17:00:00 57344 bytes
dplayx.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 241664 bytes
dpmodemx.dll: 4.09.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 90112 bytes
dpwsock.dll: 4.03.0000.1096 English Final Retail 6/8/2000 17:00:00 40960 bytes
dpwsockx.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 90112 bytes
dplaysvr.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 40960 bytes
dpnsvr.exe: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 28672 bytes
dpnet.dll: 4.09.0000.0900 Dutch Final Retail 3/24/2003 09:00:02 720896 bytes
dpnlobby.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 16384 bytes
dpnaddr.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 16384 bytes
dpvoice.dll: 4.09.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 385024 bytes
dpvsetup.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes
dpvvox.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 122880 bytes
dpvacm.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dpnhpast.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 45056 bytes
dpnhupnp.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 73728 bytes
dpvhelp.exe: 4.07.0001.3000 Dutch Final Retail 6/8/2000 17:00:00 85264 bytes
dpserial.dll: 4.03.0000.1096 Dutch Final Retail 6/8/2000 17:00:00 49152 bytes
dinput.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 667648 bytes
dinput8.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 692224 bytes
dinput.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 10874 bytes
dimap.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 94208 bytes
diactfrm.dll: 4.08.0001.0881 Dutch Final Retail 10/30/2001 08:10:00 466944 bytes
vjoyd.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 33882 bytes
joyhid.vxd: 4.88.0001.0881 English Final Retail 12/12/2002 00:14:32 13067 bytes
joy.cpl: 4.08.0001.0881 Dutch Final Retail 10/30/2001 08:10:00 442368 bytes
gcdef.dll: 4.08.0001.0881 Dutch Final Retail 10/30/2001 08:10:00 491520 bytes
gchand.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 6656 bytes
pid.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 40960 bytes
gameenum.sys: 4.07.0001.3000 English Final Retail 6/8/2000 17:00:00 10608 bytes
hidgame.sys: 4.07.0001.3000 English Final Retail 6/8/2000 17:00:00 8912 bytes
msanalog.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 12745 bytes
msjstick.drv: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 2352 bytes
dsound.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 509440 bytes
dsound3d.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1331200 bytes
dsound.vxd: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 49666 bytes
dswave.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 17920 bytes
dsdmo.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 4.09.0000.0900 Dutch Final Retail 12/12/2002 00:14:32 489984 bytes
dmusic.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 122880 bytes
dmusic16.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 10992 bytes
dmusic32.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 28672 bytes
dmband.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 26624 bytes
dmcompos.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 57856 bytes
dmime.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 180736 bytes
dmloader.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dmstyle.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 98304 bytes
dmsynth.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 100352 bytes
dmscript.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 76288 bytes
dx7vb.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 602112 bytes
dx8vb.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 4.09.0000.0904 Dutch Final Retail 7/9/2004 04:27:28 1720320 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 6/8/2000 17:00:00 933888 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 6/8/2000 17:00:00 995383 bytes
wsock32.dll: 4.90.0000.3000 Dutch Final Retail 11/25/2006 11:50:42 36864 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 65024 bytes
devenum.dll: 6.05.0001.0902 Dutch Final Retail 5/30/2003 09:00:02 134656 bytes
dxmasf.dll: 6.04.0007.1112 Dutch Final Retail 6/8/2000 17:00:00 512000 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 12/12/2002 00:14:32 11776 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 135168 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 12800 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 445952 bytes
qedit.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 1795584 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 Dutch Final Retail 5/30/2003 09:00:02 1845248 bytes
quartz.vxd: 4.00.0000.0501 English Final Retail 12/12/2002 00:14:32 5672 bytes
strmdll.dll: 4.01.0000.3857 Dutch Final Retail 6/8/2000 17:00:00 252736 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 12/12/2002 00:14:32 10240 bytes
iac25_32.ax: 2.00.0005.0050 English Final Retail 6/8/2000 17:00:00 198656 bytes
ir41_32.ax: 4.31.0016.0002 Dutch Final Retail 6/8/2000 17:00:00 859136 bytes
ir41_qc.dll: 0.00.0000.0000 English Final Retail 6/8/2000 17:00:00 135168 bytes
ir41_qcx.dll: 0.00.0000.0000 English Final Retail 6/8/2000 17:00:00 352256 bytes
ir50_32.dll: 5.1026.0015.0041 Dutch Final Retail 6/8/2000 17:00:00 757760 bytes
ir50_qc.dll: 5.00.0063.0038 English Final Retail 6/8/2000 17:00:00 212992 bytes
ir50_qcx.dll: 5.00.0064.0038 English Final Retail 6/8/2000 17:00:00 196608 bytes
ivfsrc.ax: 5.03.0002.0038 English Final Retail 6/8/2000 17:00:00 139264 bytes
mswebdvd.dll: 6.05.0001.0900 Dutch Final Retail 12/12/2002 00:14:32 324608 bytes
msdvdopt.dll: 4.90.3000.0000 Dutch Final Retail 6/8/2000 17:00:00 76048 bytes
ks.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 126976 bytes
ksproxy.ax: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 117760 bytes
ksuser.dll: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 46080 bytes
mspclock.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 4.90.3000.0000 Dutch Final Retail 6/8/2000 17:00:00 4848 bytes
mskssrv.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 4.90.3010.0900 Dutch Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 Dutch Final Retail 7/9/2004 02:58:08 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:10 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:54 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:22 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:30 30208 bytes
ipsink.ax: 5.03.0000.0900 Dutch Final Retail 7/9/2004 02:58:14 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:40 56832 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:14 8448 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:34 14464 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:06 481792 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:32 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:12 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:12 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:36 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:10 16896 bytes
kstvtune.ax: 5.03.0000.0900 Dutch Final Retail 7/9/2004 03:00:24 274432 bytes
ksxbar.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:34 39936 bytes
kswdmcap.ax: 5.03.0000.0900 Dutch Final Retail 7/9/2004 03:00:24 226304 bytes
vfwwdm32.dll: 4.90.0000.3000 Dutch Final Retail 6/8/2000 17:00:00 69632 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:42 47104 bytes
msdv.sys: 4.90.3010.0900 English Final Retail 7/9/2004 02:58:50 46080 bytes
Inactive Display Entries in Registry
Card name: NVIDIA RIVA TNT2 Model 64
Driver: nvdisp.drv
Inactive Sound Entries in Registry
Card name: Creative AudioPCI (ES1370), SB PCI 64/128 (WDM)
Driver: wdmaud.drv
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Indeo(R) audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0050
WIA Stream Snapshot Filter,0x00200000,1,1,WIASF.AX,1.00.0000.0000
Indeo® video 5.04 - Decompressiefilter,0x00640000,1,1,IR50_32.DLL,5.1026.0015.0041
Indeo® video 5.04 - Compressiefilter,0x00200000,1,1,IR50_32.DLL,5.1026.0015.0041
IVF source filter,0x00600000,0,1,IVFSRC.AX,5.03.0002.0038
Cutlist File Source,0x00200000,0,1,QCUT.DLL,6.02.0011.0608
Lyric Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
XML Graphbuilder,0x00400000,0,0,QUARTZ.DLL,6.05.0001.0902
XTL Loader,0x00400000,0,0,QEDIT.DLL,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,ACELPDEC.AX,1.04.0000.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,MPG4DS32.AX,4.01.0000.3857
ClearVideo® Decompression Filter,0x00800000,1,1,CLRAMD.AX,2.00.0000.0001
TrueMotion 2.0 Decompressor,0x00600001,1,1,TM20DEC.AX,2.00.0006.0006
VIVO Audio Decoder Filter,0x00800002,1,1,VVAUDFLT.AX,3.00.0000.0001
VIVO Video Decoder Filter,0x00600001,1,1,VVVIDFLT.AX,3.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,MSADDS32.AX,7.00.0000.1440
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.DLL,6.01.0005.0124
URL StreamRenderer,0x00600000,1,0,LMRTREND.DLL,6.01.0005.0124
ShotBoundaryDet,0x00200000,1,1,WMMFILT.DLL,1.00.1376.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,WMMFILT.DLL,1.00.1376.0000
Windows Media source filter,0x00600000,0,2,WMPASF.DLL,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASX file Parser,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,WMPASF.DLL,9.00.0000.2980
XML Playlist,0x00400000,1,0,WMPASF.DLL,9.00.0000.2980
.RAM file Parser,0x00600000,1,0,WMPASF.DLL,9.00.0000.2980
NSC file Parser,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980
File Source (Netshow URL),0x00400000,0,1,WMPASF.DLL,9.00.0000.2980
Windows Media Update Filter,0x00400000,1,0,WMPASF.DLL,9.00.0000.2980
Windows Media Video Decoder,0x00800000,1,1,WMVDS32.AX,7.00.0000.1440
Microsoft Screen Video Decompressor,0x00800000,1,1,MSSCDS32.AX,7.00.0000.1440
WM ASF Reader,0x00400000,0,0,QASF.DLL,9.00.0000.2980
WM ASF Writer,0x00400000,0,0,QASF.DLL,9.00.0000.2980
AVI Mux,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
File writer,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
Infinite Pin Tee Filter,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Smart Tee,0x00200000,1,2,QCAP.DLL,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,QDV.DLL,6.05.0001.0900
DV Muxer,0x00400000,0,0,QDV.DLL,6.05.0001.0900
DV Splitter,0x00600000,1,2,QDV.DLL,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,QDVD.DLL,6.05.0001.0900
Overlay Mixer2,0x00400000,1,1,QDVD.DLL,6.05.0001.0900
Line 21 Decoder,0x00600000,1,1,QDVD.DLL,6.05.0001.0900
DVD Navigator,0x00200000,0,2,QDVD.DLL,6.05.0001.0900
SampleGrabber,0x00200000,1,1,QEDIT.DLL,6.05.0001.0900
Null Renderer,0x00200000,1,0,QEDIT.DLL,6.05.0001.0900
AVI/WAV File Source,0x00400000,0,2,QUARTZ.DLL,6.05.0001.0902
AVI Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Draw,0x00600064,9,1,QUARTZ.DLL,6.05.0001.0902
Color Space Converter,0x00400001,1,1,QUARTZ.DLL,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Full Screen Renderer,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Renderer,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Mixing Renderer 9,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Video Decoder,0x40000001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG-I Stream Splitter,0x00600000,1,2,QUARTZ.DLL,6.05.0001.0902
File Source (Async.),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
QT Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Splitter,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Wave Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
ACM Wrapper,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
MIDI Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Internal Script Command Renderer,0x00800001,1,0,QUARTZ.DLL,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File stream renderer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File Source (URL),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
MJPEG Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Line 21 Decoder 2,0x00600002,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.09.0000.0311
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PSISRNDR.AX,6.05.0001.0900
VBI Surface Allocator,0x00600000,1,1,VBISURF.AX,5.03.0000.0900
MPEG-2 Demultiplexer,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
MPEG-2 Splitter,0x005fffff,1,0,MPG2SPLT.AX,6.05.0001.0900
AC3 Parser Filter,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,MPEG2DATA.AX,6.05.0001.0900
WST Decoder,0x00600000,1,1,WSTDECOD.DLL,5.03.0000.0900
MMAR,0x00200000,1,0,MSV2CMAR.AX,2.01.0000.0305
MMVR,0x00200000,1,0,MSV2CMVR.AX,2.01.0000.0305
Indeo® video 4.3 Decompression Filter,0x00640000,1,1,IR41_32.AX,4.31.0016.0002
Indeo® video 4.3 Compression Filter,0x00200000,1,1,IR41_32.AX,4.31.0016.0002
Voxware MetaSound Audio Decoder,0x00999999,1,1,VOXMSDEC.AX,1.00.0000.0012
Voxware MetaVoice Audio Decoder,0x00999998,1,1,VOXMVDEC.AX,1.00.0000.0011
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,QDV.DLL,6.05.0001.0900
Indeo® video 5.04 Compressiefilter,0x00100000,1,1,IR50_32.DLL,5.1026.0015.0041
MJPEG Compressor,0x00200000,0,0,QUARTZ.DLL,6.05.0001.0902
Indeo® video 5.04 - Compressiefilter,0x00100000,1,1,IR50_32.DLL,5.1026.0015.0041
Cinepak Codec door Radius,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
VDOnet VDOWave,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
MPEG-4 video hoge-snelheidscompressie (MT),0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Vivo H.263 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
TrueMotion® RT 2.0 by Duck,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
ClearVideo,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Indeo® video 5.04,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,QCAP.DLL,6.05.0001.0900
Audio Compressors:
WMAudio Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
PCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 8 kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 12 kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 16 kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
VivoActive G.723.1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
VivoActive Siren,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware MetaVoice ,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Voxware MetaSound ,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
IAC2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
ACELP.net,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
GSM 6.10,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Audio Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Midi Renderers:
Microsoft GS Wavetable SW Synth,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Creative MPU401,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
WDM Streaming Capture Devices:
Creative Sound Blaster PCI,0x00200000,2,2,,4.90.3010.0900
Creative MPU401,0x00200000,2,2,,4.90.3010.0900
WDM Streaming Communication Transforms:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,4.90.3010.0900
WDM Streaming Data Transforms:
Microsoft Kernel DRM-decoderingsfilter,0x00200000,1,1,,4.90.3010.0900
Microsoft Kernel GS Wavetable-synthesizer,0x00200000,1,1,,4.90.3010.0900
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,4.90.3010.0900
WDM Streaming Mixer Devices:
Microsoft Kernel-audiomixer,0x00200000,2,2,,4.90.3010.0900
WDM Streaming Rendering Devices:
WDM Streaming Tee/Splitter Devices:
WDM Streaming System Devices:
Creative Sound Blaster PCI,0x00200000,10,2,,4.90.3010.0900
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,4.90.3010.0900
BDA Receiver Component:
BDA MPE Filter,0x00600000,1,1,,4.90.3010.0900
BDA Slip De-Framer,0x00600000,1,1,,4.90.3010.0900
WDM Streaming VBI Codecs:
CC Decoder,0x00200000,2,1,,4.90.3010.0900
NABTS/FEC VBI Codec,0x00200000,2,1,,4.90.3010.0900
WST Codec,0x00200000,1,1,,4.90.3010.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PSISRNDR.AX,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,MPEG2DATA.AX,6.05.0001.0900
Let vooral hierop:
Display Devices
Chip type:
DAC type:
WHQL Logo'd: No
VDD: *vdd
Vendor ID: 0x10DE
Device ID: 0x0185
Revision ID: 0x00C1
Revision ID: 0x00C1
Video Accel:
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Let vooral hierop:
en hierop:
(het is een 128MB kaart, die het in een andere PC wél doet, ook met direct3d)
Iemand enig idee?
PS: Ik heb de nieuwste tot de oudste videokaart drivers geprobeerd! (ben begonnen met degene van de CD).
in totaal 4 drivers geprobeerd.
System Information
BIOS: Award
Memory: 192MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Chip type:
DAC type:
WHQL Logo'd: No
VDD: *vdd
Vendor ID: 0x10DE
Device ID: 0x0185
Revision ID: 0x00C1
Revision ID: 0x00C1
Video Accel:
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
Gameport Devices
PS/2 Devices
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 3.7 GB
Total Space: 4.9 GB
File System: FAT32
Model: n/a
Drive: D:
Model: n/a
Drive: E:
Free Space: 49.1 GB
File System: FAT32
Model: n/a
Drive: F:
Free Space: 1.0 GB
Total Space: 1.0 GB
File System: FAT
Model: n/a
Drive: G:
Free Space: 0.5 GB
Total Space: 0.5 GB
File System: FAT
Model: n/a
Drive: H:
Free Space: 40.0 GB
File System: FAT32
Model: n/a
Drive: I:
Free Space: 10.0 GB
File System: FAT32
Model: n/a
Drive: J:
Free Space: 19.7 GB
File System: FAT32
Model: n/a
Drive: K:
Free Space: 4.6 GB
Total Space: 4.6 GB
File System: FAT32
Model: n/a
Drive: L:
DirectX Components
Driver: nvdisp.drv
Driver: wdmaud.drv
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Audio Renderers:
Midi Renderers:
Let vooral hierop:
Display Devices
Chip type:
DAC type:
WHQL Logo'd: No
VDD: *vdd
Vendor ID: 0x10DE
Device ID: 0x0185
Revision ID: 0x00C1
Revision ID: 0x00C1
Video Accel:
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Let vooral hierop:
en hierop:
Iemand enig idee?
