DirectX crash
19hunter91
14 jan 2009
Beste,
Betreft Battlefield3.
Zodra ik een server join, crashed het spel en komt er een DirectX error naar voren.
Na zo'n 3x Rejoin te klikken, start het spel eindelijk op en kan ik gewoon spelen.
DirectX 11 update gedaan.
Videodrivers update gedaan.
Weet iemand hoe ik deze error kan verhelpen?
Mvg,
Hunter
Edit: net gemerkt dat het bij Crysis ook naar voren komt.
Specs:
Processor Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz (8 CPUs), ~2.9GHz
Memory 12GB RAM
Hard Drive 1 TB Total
Motherboard ASUS P7P55-M
Operating System Windows 7 Professional 64-bit
Video Card NVIDIA GeForce GTX 460
Monitor HP x22LED
Speakers PROVISION Cinema + Subwoofer / GXT-26 headset
Keyboard Razer BlackWindow Ultimate
Mouse Logitech G5
Computer Case Aerocool Vx-9 Pro Limited Edition
Er lijken nogal wat personen te zijn die hetzelfde probleem hebben.
Mogelijke oplossingen:
(1) I was having the same problem and here's how I got it to work...
Go to and open with notepad C:\Users\User Name\Documents\Battlefield 3\settings\PROF_SAVE_profile
GstRender.ResolutionHertz <---find and delete this entry, including the number following it. Remember that the beginning of the next entry starts with Gst, there's no space between them. The game placed the entry back in there with a 0 behind it. I don't know it you could just change the number to 0 or not. I just deleted, saved, and the game ran fine.
(2) If you have Ambx running kill the process. Kill any processes that use DirectX. If your using multiple monitors try switching to a single monitor and see if it launches.
My problem was my AmbxFXGen.exe running. There are some other threads about this already so search the forums for more help.
Bron: http://battlelog.battlefield.com/bf3/forum/threadview/2832654624696132578/
1. Exit the BF3.exe
2. press, WINDOWS R on your keyboard.
3. Type DXDIAG, enter
4. Run other 3D game ( i usually just start Trine, it fast boot) then exit.
5. Run BF3 again.
Bron: http://game.bramantya.org/fix-battlefield-3-directx-dxgi-dll-error/
Bedankt voor de snelle reactie!
schijnt het opgelost te hebben. :)
