DISM error 0x800f081f
thenan
22 nov 2011
Na de opdracht dism /online /cleanup-image /restorehealth krijg ik de volgende foutmelding:
dism error 0x800f081f The source could not be found.
Dit is de dism log file:
HTML:
2020-04-21 13:43:44, Info                  DISM   PID=672 TID=9392 Scratch directory set to 'C:\Users\GEBRUI~1\AppData\Local\Temp\'. - CDISMManager::put_ScratchDir
2020-04-21 13:43:44, Info                  DISM   PID=672 TID=9392 DismCore.dll version: 10.0.18362.1 - CDISMManager::FinalConstruct
2020-04-21 13:43:44, Info                  DISM   Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2020-04-21 13:43:44, Info                  DISM   PID=672 TID=9392 Successfully loaded the ImageSession at "C:\Windows\System32\Dism" - CDISMManager::LoadLocalImageSession
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2020-04-21 13:43:44, Info                  DISM   DISM.EXE:
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Host machine information: OS Version=10.0.18363, Running architecture=amd64, Number of processors=4
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Dism.exe version: 10.0.18362.1
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Executing command line: "C:\Windows\System32\Dism.exe" /online /cleanup-image /restorehealth
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 physical location path: C:\ - CDISMManager::CreateImageSession
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Event name for current DISM session is Global\{863D6017-9D56-4D70-A01B-921AEF9E17A7} - CDISMManager::CheckSessionAndLock
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Create session event 0x1f0 for current DISM session and event name is Global\{863D6017-9D56-4D70-A01B-921AEF9E17A7}  - CDISMManager::CheckSessionAndLock
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Successfully loaded the ImageSession at "C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD" - CDISMManager::LoadRemoteImageSession
2020-04-21 13:43:44, Info                  DISM   DISM Image Session: PID=6620 TID=5048 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM OS Provider: PID=6620 TID=5048 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM OS Provider: PID=6620 TID=5048 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2020-04-21 13:43:44, Warning               DISM   DISM Provider Store: PID=6620 TID=5048 Failed to load the provider: C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2020-04-21 13:43:44, Info                  DISM   DISM Manager: PID=672 TID=9392 Image session successfully loaded from the temporary location: C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD - CDISMManager::CreateImageSession
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Target image information: OS Version=10.0.18363.657, Image architecture=amd64
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Image session version: 10.0.18362.1
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  CSI    00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-04-21 13:43:44, Info                  CSI    00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.772_none_5f13f94c58ff41d3\wcp.dll' : got STATUS_SUCCESS
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Driver Manager: PID=6620 TID=5048 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Warning               DISM   DISM Provider Store: PID=6620 TID=5048 Failed to load the provider: C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\SysprepProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM Transmog Provider: PID=6620 TID=5048 Current image session is [ONLINE] - CTransmogManager::GetMode
2020-04-21 13:43:44, Info                  DISM   DISM Transmog Provider: PID=6620 TID=5048 Audit Mode: [No] - CTransmogManager::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Transmog Provider: PID=6620 TID=5048 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2020-04-21 13:43:44, Info                  DISM   DISM Transmog Provider: PID=6620 TID=5048 Product Type: [WinNT] - CTransmogManager::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Transmog Provider: PID=6620 TID=5048 Product Type ServerNT : [No] - CTransmogManager::Initialize
2020-04-21 13:43:44, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Connecting to the provider located at C:\Users\GEBRUI~1\AppData\Local\Temp\FA15FA53-89DB-430B-AB44-DC669B97B4AD\SetupPlatformProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: OSServices
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: MsiManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IntlManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IBSManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DriverManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SmiManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AppxManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: ProvManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AssocManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: GenericManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: OfflineSetupManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SysprepManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: SysprepManager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Edition Manager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SetupPlatformManager
2020-04-21 13:43:44, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler::Private_ValidateCmdLine
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2020-04-21 13:43:44, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 CBS session options=0x40100! - CDISMPackageManager::Internal_Finalize
2020-04-21 13:53:29, Info                  DISM   DISM Package Manager: PID=6620 TID=2168  Error in operation: source for package or file not found, ResolveSource() unsuccessful. (CBS HRESULT=0x800f081f) - CCbsConUIHandler::Error
2020-04-21 13:53:29, Error                 DISM   DISM Package Manager: PID=6620 TID=5048 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f081f)
2020-04-21 13:53:29, Error                 DISM   DISM Package Manager: PID=6620 TID=5048 The source files could not be found; their location must be specified using the /source option to restore the feature. - GetCbsErrorMsg
2020-04-21 13:53:29, Error                 DISM   DISM Package Manager: PID=6620 TID=5048 Failed processing package changes with session option CbsSessionOptionRepairStoreCorruption - CDISMPackageManager::RestoreHealth(hr:0x800f081f)
2020-04-21 13:53:29, Error                 DISM   DISM Package Manager: PID=6620 TID=5048 Failed to restore the image health. - CPackageManagerCLIHandler::ProcessCmdLine_CleanupImage(hr:0x800f081f)
2020-04-21 13:53:29, Error                 DISM   DISM Package Manager: PID=6620 TID=5048 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2020-04-21 13:53:29, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Package Manager: PID=6620 TID=5048 Finalizing CBS core. - CDISMPackageManager::Finalize
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(SysprepManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: SysprepManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Finalizing the servicing provider(SetupPlatformManager) - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: SetupPlatformManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=6620 TID=5048 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Manager: PID=672 TID=9392 Closing session event handle 0x1f0 - CDISMManager::CleanupImageSessionEntry
2020-04-21 13:53:29, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.
2020-04-21 13:53:29, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2020-04-21 13:53:29, Info                  DISM   DISM Provider Store: PID=672 TID=9392 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
Ik heb inmiddels alle voorgestelde oplossingen van deze site doorlopen zonder resultaat.
Wie kan mij verder helpen?
DISM kan de bronbestanden niet vinden. Die moet je nog meegeven met "/source" in de commandoregel
Natuurlijk; maar als je de link had geopend, dan had je kunnen zien wat ik al gedaan had.
Dat heb je allemaal gedaan. In die dism log file staat meerdere malen failed. Staat daar niet iets bij wat jij herkent. In dat artikel gaat het ook over CBS.log
Helemaal aan het einde:
Method 6. Repair Windows 10.
If after applying all the above methods, you still receive the error "Source Files Could not be Found" in DISM, then I suggest to perform a Repair Installation of Windows 10.
Alleen door windows 10 opnieuw te installeren kon het probleem verholpen worden.
