Isabelle Sels
- 9 sep 2010
Hoe kan ik een loop laten lopen tot in bij de laatste record ben gekomen?
Private Sub Knop135_Click()
Dim Msg, Style, Title, Response, MyString, QueryName
Dim Check, Counter
Dim rst As Recordset
If IsNull(Me![GTOnderdeel]) Then
'Msg = "Wilt u Query uitvoeren?"
'Style = vbOKOnly + vbInformation + vbDefaultButton2
'Title = "Let op!"
'Response = MsgBox(Msg, Style, Title)
QueryName = "Gedragstest Onderdelen Toevoegen"
DoCmd.OpenQuery QueryName, acViewNormal, acEdit
DoCmd.Requery
Else
Msg = "Reeds uitgevoerd"
Style = vbOKOnly + vbCritical + vbDefaultButton2
Title = "Let op!"
Set rst = CurrentDb.OpenRecordset("Qry GT Honden")
If IsNull(Me![Subform GT Honden2]![GTSubOnderdeel]) Then
Do
Do While Not rst.EOF
'Do While Counter < 20
Counter = Counter + 1
'Msg = rst
'Title = "Let op!"
QueryName = "Gedragstest SubOnderdelen Toevoegen"
DoCmd.GoToRecord , , acNext
'rst.MoveNext
'If Counter = 10 Then
' Check = False
' Exit Do
'End If
Loop
Loop
DoCmd.GoToRecord , , acFirst
Else
Title = "Let op!"
Dim Check, Counter
'Title = "Let op!"
DoCmd.Requery
Else
Title = "Let op!"
Do
'Msg = rst
'Title = "Let op!"
'rst.MoveNext
' Check = False
' Exit Do
'End If
Loop
Loop
Else
Title = "Let op!"
Dim Check, Counter
'Title = "Let op!"
DoCmd.Requery
Else
Title = "Let op!"
Do
'Msg = Counter
Title = "Let op!"
If Counter = 7 Then
Check = False
Exit Do
Loop
Loop Until Check = False
Else
Title = "Let op!"
DoCmd.Requery
