DVD speler area code vrijmaken
helaas geen oplossing voor DVD speler XV-N5SL.dit is een DVD speler verbonden met de TV!
misschien heb je her wat aan kookabura:
Plugging the player while holding Play and Stop, does this :
"TEST --" then displays "TEST E"
When pushing the Choice key on the remote, it displays this :
"23 56 13"
Pushing again does this :
Again :
All LCDs lit
Again :
"CHECK"
Again :
"EXPERT"
When "EXPERT" lite, pressing 3D Phonic on the remote does this :
"0000 0000"
Then pressing Subtitle does this :
MJMO DEOF
Then when pressing Angle or Subtitle again we can simultaneously read :
"MJMO DE10", "MJMO DE09", "MJMO DE08"... and "MJMO DEOA", "MJMO DEOB"...
Pressing 3D Phonic again does this :
DATA 0000, then pressing Angle or Subtitle does things like "MJMO DEOD"
Pressing Menu does :
"0000 0000"
Now, pressing numbers button on the remote, changes 0000 0000 into many
different codes, at this moment I think it is better not to press Enter, some
wrong codes could be entered and I did not find how to enter 0000 0000 again.
When switching off and on again (without validing anything), the player keeps
its keys.
Well, I hope that this small discovery will help some us to eventually figure
out the hack for this player.
Succes!
Dank je wel voor je reactie.
Alles uitgeprint en geprobeerd,maar er gebeurde niets toen ik gelijkertijd Play and Stop in drukte,kan je me verder helpen ?
