Doet het wel maar foute Diangnostics
Weet niet wat er precies veranderd is maar doet het nu. Misschien stond de account bij Zon nog niet open of zo en nu wel. Alleen de diagnostic test blijft een foutmelding geven t.w.
Check IP connect to Ethernet
This test returns PASS if your DSL modem has been assigned a valid IP address by your service provider throught DHCP or your DSL modem is assigned a valid IP address statically.
If this test returns FAIL, run this test again a few minutes after this test is completed. If this test returns FAIL consistently and DHCP client is turned on in your DSL modem, check with your service provider. If this test returns FAIL consitently and your DSL modem is statically assigned an IP address, make sure the IP address is the correct one assigned by your service provider.
This test returns SKIPPED if "Ethernet connect to AAL5" test does not return PASS.
Weet iemand hoe hier mee om te gaan? Bedankt voor de hulp.
