Heb je in de link van Gezina gekeken en dit geprobeert?Geplaatst door Thetwins
mijn vraag is nog steeds niet opgelost
Bron; link Gezina.I contacted eAnthology and I got the instructions from them on how to remove all the files. Here are the steps as to what to do...
(I skipped to #3 and it worked)
To manually remove eAnthology programs, please follow the steps below:
1) Open eAnthology Manager, and deactivate all of the features:
- Click Start > Programs > eAnthology > eAnthology Manager.
- Click on the Stop Sign Icon.
- Click on all tabs to deactivate each feature.
- Close eAnthology Manager.
2) Press CTRL-ALT-DEL once to bring up Task Manager:
- For Windows 95/98/ME: Look for "defscangui.exe" and press "End
Task".
- For Windows XP/NT/2000: Click on "Processes" tab, search for
"defscangui.exe" and press "End Process".
***Note***
If defscangui.exe is not found, skip to number 3.
3) Click Start, then Settings, and then Control Panel.
(In XP: Click Start > Control Panel.)
4) Double-click Add/Remove Programs.
5) Under the Install/Uninstall(or Add/Remove) tab, click eAnthology.
- Click the Add/Remove button(Select the programs you wish to
uninstall for newer versions: ) and click OK to approve the uninstall.
6) Also repeat the above step for eAnthology Download Receiver.
7) Reboot your computer.
8) Click Start, Programs, and then right-click on eAnthology, and then
choose the "Delete" option. Click "Yes" to confirm deletion.
If you have any problems with the above directions, please send an
email to mailto:support@eacceleration.com for action.
Geplaatst door czorn
Heel erg verdacht:
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\EACDownload\rav_temp.exe -k
