Geachte mede accessers
Mijn vraag, kan ik via een knop direct een sub directory openen, ik kom er even niet uit.
Ik heb een directory genaamd DVD-films, en in een andere sub directory genaamd Covers.
Hier onder de code die ik nu heb:
Private Sub knpZoekAfbeelding_Click()
'Declare a variable as a FileDialog object.
Dim fd As FileDialog
'Create a FileDialog object as a File Picker dialog box.
Set fd = Application.FileDialog(msoFileDialogFilePicker)
'Declare a variable to contain the path
'of each selected item. Even though the path is a String,
'the variable must be a Variant because For Each...Next
'routines only work with Variants and Objects.
Dim vrtSelectedItem As Variant
'Use a With...End With block to reference the FileDialog object.
With fd
'Use the Show method to display the File Picker dialog box and return the user's action.
'The user pressed the action button.
If .Show = -1 Then
'Step through each string in the FileDialogSelectedItems collection.
For Each vrtSelectedItem In .SelectedItems
'vrtSelectedItem is a string that contains the path of each selected item.
'You can use any file I/O functions that you want to work with this path.
'This example simply displays the path in a message box.
Me.txtLocatie = vrtSelectedItem
Next vrtSelectedItem
'The user pressed Cancel.
Else
'Set the object variable to nothing.
Set fd = Nothing
Call Form_Current
Als u mij kunt helpen graag, alvast bedankt voor de moeite en tijd.
Groet Palmpje60
With fd
If .Show = -1 Then
Else
Set fd = Nothing
Call Form_Current
Groet Palmpje60
