Eigenschappen van SPRY menubalk
Geert77
25 mei 2007
Hallo allemaal,
Voor mijn website ben ik bezig met een menubalk. Nu heb ik in de CSS file enkele eigenschappen aangepast. Een aantal eigenschappen zoals textkleur neemt hij wel over, maar een aantal andere parameters niet.
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
 LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
	margin: 0;
	padding: 0;
	list-style-type: none;
	font-size: 100%;
	cursor: default;
	width: auto;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
	z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
	margin: 0;
	padding: 0;
	font-size: 100%;
	position: relative;
	text-align: left;
	cursor: pointer;
	width: 114.28px;
	float: left;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
	margin: 0;
	padding: 0;
	font-size: 100%;
	z-index: 1020;
	cursor: default;
	width: 8.2em;
	position: absolute;
	left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
	left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
	width: 8.2em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
	position: absolute;
	margin: -5% 0 0 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
	left: auto;
	top: 0;
 DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
	border: 1px solid #CCC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
	display: block;
	cursor: pointer;
	background-color: #FFF;
	padding: 0.5em 0.75em;
	color: #900;
	text-decoration: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
	background-color: #900;
	color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
	background-color: #33C;
	color: #FFF;
 SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
	background-image: ;
	background-repeat: no-repeat;
	background-position: 95% 50%;
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
	background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
	background-image: url(SpryMenuBarDownHover.gif);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
	background-image: url(SpryMenuBarRightHover.gif);
 BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
	position: absolute;
	z-index: 1010;
	filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
	ul.MenuBarHorizontal li.MenuBarItemIE
		display: inline;
		f\loat: left;
		background: #FFF;
Ik had hem zo ingesteld dat als je met de muis over een item gaat dat hij rood zou kleuren. Maar tijdens het testen blijft hij gewoon blauw.
Als ik hem lokaal eerst juist weer, maar als ik dan op de gele balk boven in beeld klik om de "activeX-besturingselementen" uit te voeren geeft hij ze weer in de kleur blauw.
Een voorbeeld van de site staat op http://test2.ttvwehl.nl
Weet iemand wat er hier aan de hand is?
Alvast bedankt voor jullie hulp,
Met vriendelijke groet,
Geert
Je bedoelt deze:
HTML:
   <ul id="MenuBar1" class="MenuBarHorizontal">
Verander in je css de code
color: #FFF;
naar:
HTML:
	background-color: #FF3366;
	color: #ffffff;
Dus 6 posities.
:cool:
Ik heb de bovenstaande oplossing geprobeerd:
@charset "UTF-8";
	margin: 0;
	padding: 0;
	font-size: 100%;
	cursor: default;
	width: auto;
ul.MenuBarActive
	z-index: 1000;
	margin: 0;
	padding: 0;
	font-size: 100%;
	position: relative;
	text-align: left;
	cursor: pointer;
	width: 114.28px;
	float: left;
	margin: 0;
	padding: 0;
	font-size: 100%;
	z-index: 1020;
	cursor: default;
	width: 8.2em;
	position: absolute;
	left: -1000em;
	left: auto;
	width: 8.2em;
	position: absolute;
	left: auto;
	top: 0;
	display: block;
	cursor: pointer;
	color: #900;
	color: #ffffff;
	color: #FFF;
	background-image: ;
	position: absolute;
	z-index: 1010;
		display: inline;
		f\loat: left;
		background: #FFF;
Maar helaas, het probleem is er nog steeds.
Hallo allemaal,
Nog steeds heb ik geen oplossing gevonden voor mijn probleempje.
Het gekke is dat als je bepaalde eigenschappen aanpast die het wel doen, maar deze blijft hetzelfde probleem vertonen.
Geert
