Elimineren van verboden karakters in twee strings
  • Onderwerp starter Onderwerp starter keb
keb
20 feb 2011
Ik wil e-mails opslaan met de filenaam "Datum Afzender Onderwerp.msg"
Zowel de afzender als onderwerp wil ik controleren op verboden karakters en vervolgens aanvullen/verkorten tot 20 karakters.
Kan ik deze controle met één subroutine doen?
Graag suggesties.
Hier mijn voorbeeld van het hele programma:
'status per 14 december 2023
Private Sub Commandbutton1_Click()
'Ref.: https://www.slipstick.com/developer/code-samples/save-selected-message-file/
    Dim myItem As Object
    Dim olMail As Outlook.MailItem
    Dim Selection As Selection
    Dim strSender As String 'Names will be shortened of extented to fix number of characters and checked on forbidden characters
    Dim strDate As String
    Dim strPath As String  'Will be picked up from a listbox
    Dim strSubject As String 'Subject will be shortened of extented to fix number of characters and checked on forbidden characters
    Dim sName As String
    strPath = ListBox2.List(ListBox2.ListIndex, 1)
    'MsgBox strPath
    'Action with loop for all selected e-mails
    Set myNamespace = Application.GetNamespace("MAPI")
    Set Selection = Application.ActiveExplorer.Selection
    For Each objItem In ActiveExplorer.Selection
        If objItem.MessageClass = "IPM.Note" Then
            Set oMail = objItem
            strSubject = oMail.Subject
            ReplaceCharsForFileName strSubject, "-"
            strSubject = Left(oMail.Subject & String(20, "_"), 20)
            strSender = oMail.Sendername
            ReplaceCharsForFileName strSender, "-"
            strSender = Left(oMail.Sender & String(20, "_"), 20)
            dtDate = oMail.ReceivedTime
            strDate = Format(dtDate, "yyyymmdd", vbUseSystemDayOfWeek, vbUseSystem) & Format(dtDate, "-hhnn", vbUseSystemDayOfWeek, vbUseSystem)
            Debug.Print strPath & strDate & " " & strSender & " " & strSubject & ".msg"
            oMail.SaveAs strPath & strDate & " " & strSender & " " & strSubject & ".msg", olMSG
        'Delete the selected e-mail
        'olMail.Delete
        Next  'Next mail
        Userform1.hide
Public Sub ReplaceCharsForFileName(strSender As String, sChr As String)
  strSender = Replace(strSender, "'", sChr)
  strSender = Replace(strSender, "*", sChr)
  strSender = Replace(strSender, "/", sChr)
  strSender = Replace(strSender, "\", sChr)
  strSender = Replace(strSender, ":", sChr)
  strSender = Replace(strSender, "?", sChr)
  strSender = Replace(strSender, Chr(34), sChr)
  strSender = Replace(strSender, "<", sChr)
  strSender = Replace(strSender, ">", sChr)
  strSender = Replace(strSender, "|", sChr)
  strSender = Replace(strSender, "&", sChr)
Private Sub UserForm_Initialize()
    'Read setup file/parameters for dropbox
    file = "D:\Setup.csv"
    i = 0
    Userform1.ListBox2.Clear
    Open file For Input As #1
    Do Until EOF(1)
        Line Input #1, strLine: 'Debug.Print strLine
        i = i + 1
        ListBox2.AddItem
        ListBox2.List(i - 1, 0) = Split(strLine, ";")(0)
        ListBox2.List(i - 1, 1) = Split(strLine, ";")(1)
    Loop
    Close #1
Waarom zou je dat willen? Ook al kan de functie korter? Wat denk je er mee te winnen?
Zelf gebruik ik hiervoor 1 string
Tekens welke niet in de string ToegestaneTekens voorkomen, worden verwijderd uit de string MijnStr
   ToegstaneTekens = "' áéíóúýÁÉÍÓÚÝâêîôûÂÊÎÔÛãñõÃÑÕäëïöüÿÄËÏÖÜŸ/\()[]1234567890abcdefghijklmnopqrstuvwxyz"
   For X = 1 To Len(MijnStr)
      If InStr(UCase(ToegstaneTekens), UCase(Mid(MijnStr, X, 1))) > 0 Then
         strCheckPath = strCheckPath & Mid(MijnStr, X, 1)
        Else
         strCheckPath = strCheckPath & " "
   Next X
alleen kleine en hoofdletters toegestaan:
CSS:
  For Each it In ActiveExplorer.Selection
    If it.MessageClass = "IPM.Note" Then
      c00 = it.Subject & it.Sendername
      For j = 1 To Len(c00)
        If Mid(c00, j, 1) Like "[!a-z !A-Z]" Then c00 = Replace(c00, Mid(c00, j, 1), "")
      Next
      it.SaveAs ListBox2 & Format(it.ReceivedTime, "yyyymmdd_hhmm_") & Left(c00 & Space(20), 20) & ".msg", olMSG
  Next
   Userform1.Hide
Function repChars(c As String) As String
 With CreateObject("vbscript.regexp")
   .Global = True
   .Pattern = "[\\/:\*\?""<>\|]"
   repChars = .Replace(c, "")
End Function
