rkwebdesign
- 14 apr 2001
mijn fout : Error #108: Partition didn't end on cylinder boundary.
ucEndHead expected to be 254, not 235.
dit is de fout die partition magic geeft, met partition inof krijg ik het volgende.
PowerQuest PartitionInfo 7.0 -- Windows 95/98/Me Version
Date Generated: 01/24/03 13:11:53
Copyright (c)1994-2001, PowerQuest Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way. All other rights are reserved.
PowerQuest, makers of PartitionMagic(r), Drive Image(tm), and DriveCopy(tm), can be reached at:
Voice: 801-437-8900
Fax: 801-226-8941
Web site: http://support.powerquest.com/support.html
E-mail: magic@powerquest.com
General System Information:
Total Physical Memory (bytes): 267,616,256
Used Physical Memory: (bytes): 196,587,520
Maximum Page File Size: (bytes): 1,879,863,296
Current Page File Size: (bytes): 95,588,352
Disk Geometry Information for Disk 1: 4865 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
WINDOWS 0 0 80 0 1 1 0B 764 235 63 63 12,288,465
0 1 00 764 236 1 0F 1023 254 63 12,288,528 65,867,697
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 1 00 764 236 1 0F 4864 254 63 12288528 65867697
Info: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 236.
NO NAME 12,288,528 0 00 764 237 1 0B 1023 254 63 12,288,591 32,934,384
Actual values are:
12288528 0 00 764 237 1 0B 2814 254 63 12288591 32934384
Error #105: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 237.
12,288,528 1 00 1023 0 1 05 1023 254 63 45,222,975 32,933,250
Actual values are:
12288528 1 00 2815 0 1 05 4864 254 63 45222975 32933250
NO NAME 45,222,975 0 00 1023 1 1 0B 1023 254 63 45,223,038 32,933,187
Actual values are:
45222975 0 00 2815 1 1 0B 4864 254 63 45223038 32933187
Disk Geometry Information for Disk 2: 1582 Cylinders, 255 Heads, 63 Sectors/Track
Info: EZ-Drive is installed on this drive.
0 0 80 1 0 1 0F 1023 254 63 16,065 25,398,765
Actual values are:
0 0 80 1 0 1 0F 1581 254 63 16065 25398765
DATA 2 16,065 0 00 1 1 1 0B 1023 254 63 16,128 25,398,702
Actual values are:
16065 0 00 1 1 1 0B 1581 254 63 16128 25398702
Partition Information for Disk 1: 38,162.2 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects UsedSects FreeSects
C:WINDOWS FAT32 Pri,Boot 6,000.2 0 0 63 12,288,465 12,288,465 0
ExtendedX Pri 32,161.10 0 1 12,288,528 65,867,697 65,867,697 0
EPBR Log 16,081.3 None -- 12,288,528 32,934,447 32,934,447 0
D:NO NAME FAT32 Log 16,081.2 12,288,528 0 12,288,591 32,934,384 32,934,384 0
EPBR Log 16,080.7 12,288,528 1 45,222,975 32,933,250 32,933,250 0
E:NO NAME FAT32 Log 16,080.7 45,222,975 0 45,223,038 32,933,187 32,933,187 0
Partition Information for Disk 2: 12,409.6 Megabytes
Unallocated Pri 7.8 None -- 63 16,002 0 16,002
ExtendedX Pri,Boot 12,401.7 0 0 16,065 25,398,765 25,398,765 0
EPBR Log 12,401.7 None -- 16,065 25,398,765 25,398,765 0
F
ATA 2 FAT32 Log 12,401.7 16,065 0 16,128 25,398,702 25,398,702 0
Boot Record for drive C: (Drive: 1, Starting sector: 63, Type: FAT32)
1. Jump: EB 58 90
2. OEM Name: MSWIN4.1
3. Bytes per Sector: 512
4. Sectors per Cluster: 8
5. Reserved Sectors: 36
6. Number of FAT's: 2
7. Reserved: 0x0000
8. Reserved: 0x0000
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 255 (0xFF)
13. Hidden Sectors: 63 (0x3F)
14. Big Total Sectors: 12288465 (0xBB81D1)
15. Big Sectors per FAT: 11978
16. Extended Flags: 0x0000
17. FS Version: 0
18. First Cluster of Root: 2 (0x2)
19. FS Info Sector: 1
20. Backup Boot Sector: 6
21. Reserved: 000000000000000000000000
22. Drive ID: 0x80
23. Reserved for NT: 0x00
24. Extended Boot Sig: 0x29
25. Serial Number: 0x23391CDB
26. Volume Name: WINDOWS
27. File System Type: FAT32
28. Boot Signature: 0xAA55
Boot Record for drive D: (Drive: 1, Starting sector: 12,288,591, Type: FAT32)
1. Jump: EB 58 90
4. Sectors per Cluster: 16
7. Reserved: 0x0000
8. Reserved: 0x0000
14. Big Total Sectors: 32934384 (0x1F689F0)
15. Big Sectors per FAT: 16066
17. FS Version: 0
22. Drive ID: 0x80
25. Serial Number: 0x9461F320
26. Volume Name: NO NAME
Boot Record for drive E: (Drive: 1, Starting sector: 45,223,038, Type: FAT32)
1. Jump: EB 58 90
2. OEM Name: MSDOS5.0
5. Reserved Sectors: 38
7. Reserved: 0x0000
8. Reserved: 0x0000
14. Big Total Sectors: 32933187 (0x1F68543)
15. Big Sectors per FAT: 16065
17. FS Version: 0
22. Drive ID: 0x80
25. Serial Number: 0x140F3FCE
Boot Record for drive F: (Drive: 2, Starting sector: 16,128, Type: FAT32)
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
13. Hidden Sectors: 16128 (0x3F00)
14. Big Total Sectors: 25398702 (0x1838DAE)
15. Big Sectors per FAT: 12390
17. FS Version: 0
22. Drive ID: 0x80
25. Serial Number: 0x151919F1
26. Volume Name: DATA 2
wie kan mij helpen?? om de fout weg te krijgen?
please reply on this.
Afz. SteZZz
Voice: 801-437-8900
Fax: 801-226-8941
Actual values are:
Actual values are:
Actual values are:
Actual values are:
Actual values are:
Actual values are:
F
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
17. FS Version: 0
22. Drive ID: 0x80
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
17. FS Version: 0
22. Drive ID: 0x80
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
17. FS Version: 0
22. Drive ID: 0x80
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
17. FS Version: 0
22. Drive ID: 0x80
Afz. SteZZz
