Ik begrijp precies wat je bedoelt, en wat ik al zei, daar heb je een database formule voor nodig. Helaas ben ik daar niet zo thuis in....
Dit is wat de helpfile van Excel bijvoorbeeld geeft:
DSUM
See Also
Adds the numbers in a column in a list or database that match conditions you specify.
For more information and examples, click .
Syntax
DSUM(database,field,criteria)
Database is the range of cells that make up the list or database. A database is a list of related data in which rows of related information are records and columns of data are fields. The first row of the list contains labels for each column.
Field indicates which column is used in the function. Field can be given as text with the column label enclosed between double quotation marks, such as "Age" or "Yield," or as a number that represents the position of the column within the list: 1 for the first column, 2 for the second column, and so on.
Criteria is the range of cells that contains the conditions you specify. You can use any range for the criteria argument, as long as it includes at least one column label and at least one cell below the column label for specifying a condition for the column.
Maar dat is alles wat ik ermee kan....
