O jee, alweer die *** Norton.
Proberen:
Error Message: "A fatal exception 0E has occurred at 0028:XX in VXD SYMEvent(0x) + XX"
Translation: This GPF may occur if you have an older version of a Symantec utility installed, such as Norton AntiVirus. Similar errors may stem from other virus protection programs, graphics software, and scanner utilities. If the message has a Details button, click it to identify the errant software.
Solution: The easiest and best solution may be reinstalling the program or upgrading to the latest version. If this doesn't help or an updated version isn't available, you may have to edit the Registry, which contains system information about your hardware and software. Don't edit the Registry unless you're confident in your skills and you perform a backup of files in the Registry first. To run the Registry Editor, click Start, Run, and type regedit.exe and then press OK or ENTER. If the following line appears in the Registry, delete it:
HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Services\VxD\SymEvnt
Run the System Editor by typing sysedit in the Run field. Pick System.ini from windows that appear. Click Find from the Search menu and locate the line containing "symevnt.386." Place a semicolon ( ; ) at the beginning of the line so Windows won't process it. Then save the change, exit, and restart your computer.
Zul je toch het register in moeten . . .
Op dit forum ben ik al zó veel Norton-ellende tegen gekomen; is eraf gooien geen optie? Wel zorgvuldig via de Symantic site, want Norton laat zich soms even moeilijk geheel verwijderen als het rottigste virus.
Goede en gratis alternatieven:
ZoneAlarm of Sygate als firewall
AVG, Antivir of Avast als antivirus
Deze nemen ook een flink stuk minder van je pc-vermogen in beslag.
Bron:
http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/l0706/08l06/08l06.asp
