FileSystemObject .AtEndOfStream merkt het einde v.d.tekst niet op
Tuurlijk Michel,
Ik heb wel gemerkt dat de variabele L niet herkend wordt omdat deze in de functie ImportFA() gedeclareerd is maar globaal declareren is toch rommelig programmeren? Nu zit ik hopeloos vast :(
Option Compare Database
Option Explicit
Private Const FaDelim As String = "|"
Private Const FaVelden As Byte = 11
Public Function ImportFA() As Boolean
    Dim fd As FileDialog, strBestand As String
    'Create a FileDialog object as a File Picker dialog box.
    Set fd = Application.FileDialog(msoFileDialogOpen)
    'Declare a variable to contain the path
    'of each selected item. Even though the path is a String,
    'the variable must be a Variant because For Each...Next
    'routines only work with Variants and Objects.
    'Dim varSelectedItem As Variant
    'Use a With...End With block to reference the FileDialog object.
    With fd
        'Set the initial path to the drive where the file exists.
        .InitialFileName = "K:\Ambertje\"
        'Don't allow the selection of multiple files.
        .AllowMultiSelect = False
        'Change the title of the dialog
        .Title = "Kies het FA bestand: "
        'Use the Show method to display the File Picker dialog box and return the user's action.
        'The user pressed the action button.
        Select Case .Show
            Case False
                Set fd = Nothing
                Exit Function
        End Select
            'Step through each string in the FileDialogSelectedItems collection
            'For Each varSelectedItem In .SelectedItems
            '    MsgBox "Bestand " & varSelectedItem & " is geselecteerd"
            '    Next varSelectedItem
            strBestand = .SelectedItems(1)
    Set fd = Nothing
    'Feitelijk inlezen van het bestand:
    Dim fso As FileSystemObject, f As TextStream, varData(), tmp As Variant
    Dim fts As Scripting.TextStream
    Dim L As Long
    Dim i As Integer, strLijn() As String
    'The following code illustrates how the FileSystemObject is used to return a TextStream object that can be read from or written to:
    Set fso = New FileSystemObject
    Set fts = fso.OpenTextFile(strBestand)
        'per record wordt de data veld per veld ingevuld
        'Store|FTT|Route|Stop|FSP|Aant_Pal|Sel_Method|Total_Volume|Total_Weight|Aant_Prod|Aant_Collis
        '10544|KKK|3702 | 1  |400|   1    |     S    |    0.239   |    74.70   |    26   |      28
        '10544|YYY|3702 | 1  |400|   1    |     S    |    0.487   |   135.36   |    41   |      56
        With fts
             Do Until .AtEndOfStream
                ReDim Preserve varData(0 To (FaVelden - 1), 0 To L)
                tmp = .ReadLine
                If Trim(tmp) = "" Then
                    Call ImporteerNaarTabel
                strLijn = VBA.Split(tmp, "|")
                For i = 0 To (FaVelden - 1)
                    varData(i, L) = strLijn(i)
                Next
                L = L + 1
            Loop
            .Close
    Set fts = Nothing
    Set fso = Nothing
End Function
Public Function ImporteerNaarTabel()
'Updaten van Tbl_Fa
Dim strSQL As String, rst As DAO.Recordset DBEngine.BeginTrans
    On Error GoTo FOUT
    strSQL = "DELETE * from Tbl_Fa"
    CurrentDb.Execute strSQL
    strSQL = "SELECT * from Tbl_Fa where 0 = 1"
    Set rst = CurrentDb.OpenRecordset(strSQL)
    With rst
        For L = LBound(varData, 2) To UBound(varData, 2)
            .AddNew
            .Fields("Store").Value = varData(0, L)
            .Fields("FTT").Value = varData(1, L)
            .Fields("Route").Value = varData(2, L)
            .Fields("Stop").Value = varData(3, L)
            .Fields("FSP").Value = varData(4, L)
            .Fields("Aant_Pal").Value = varData(5, L)
            .Fields("Sel_Method").Value = varData(6, L)
            .Fields("Total_Volume").Value = varData(7, L)
            .Fields("Total_Weight").Value = varData(8, L)
            .Fields("Aant_Prod").Value = varData(9, L)
            .Fields("Aant_Collis").Value = varData(10, L)
            .Update
        Next
    DBEngine.CommitTrans
    ImportFA = True
    MsgBox "Import pbl MSI succesvol"
    Exit Function
FOUT:
    DBEngine.Rollback
    MsgBox "Probleem met de import ! Niets geïmporteerd." + vbCrLf + _
            VBA.Err.Description
End Function
[/CODE
Groetjes,
Ambertje
Nu nog even de code opmaken met de code tag ;)
Zo.
Ik dacht dat ik dit gedaan had :o
Tuurlijk Michel,
[CODE]Option Compare Database
Option Explicit
    With fd
        Select Case .Show
            Case False
                Set fd = Nothing
                Exit Function
        End Select
    Set fd = Nothing
    Dim L As Long
        With fts
                tmp = .ReadLine
                Next
                L = L + 1
            Loop
            .Close
    Set fts = Nothing
    Set fso = Nothing
End Function
'Updaten van Tbl_Fa
    On Error GoTo FOUT
    With rst
            .AddNew
            .Update
        Next
    ImportFA = True
    Exit Function
FOUT:
    DBEngine.Rollback
            VBA.Err.Description
End Function
[/CODE
Hoi Michel,
Sorry dat ik je nogmaals lastigval, ik besef dat je nog hopen andere gebruikers van dit forum aan het helpen bent maar ik kom geen stap verder meer.
Heb je al kunnen zien waar het nu vastloopt?
Groetjes,
Ambertje
