Start the Registry Editor
Go to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Internet Settings
Select New > DWORD Value from the Edit menu
Name the new value MaxConnectionsPer1_0Server
Right-click the MaxConnectionsPer1_0Server value and choose Modify
Under Base, click the radio button next to Decimal
In the Value Data: box enter the number of simultaneous connections you want to set (for example 10 is a good value), and click OK
Repeat steps 3 - 7 using the new value MaxConnectionsPerServer
Exit the registry editor
