Hoi !
In Vista:
Hopelijk ken je Engels, anders indien nodig laten vertalen door Google:
Here is the answer to your problems. Go to your control panel under add and remove programs you will see a hot fix for kb929777. Uninstall this hot fix. Windows will tell you to reboot, do it. Download the kb929777 for the windows website not the auto update site, (if you do it will install the hot fix first before the kb929777 and then kb929777 will not install again). After successful update you will need to reboot. check for updates( there should be none and your history should show successful update on the kb929777. I also took out 3 gb of mem. before I did this but before it would still not download until I removed the hot fix, so I DO NOT KNOW IF YOU NEED TO REMOVE THE MEM. FIRST. But try it with the mem. in first and it may save you a step.
Je hoeft geen geheugen te verwijderen, zoals in het laatste deel wordt gesuggereerd.
Tenzij je met 8 Gig draait of zo....
Greetz,
Harry.
