Kan iemand hier zien wat er steeds fout gaat in Nero?
1A23-0609-9030-2446-3092-8825
1A42-0809-4030-2329-9503-7413
1A43-0609-4030-2312-3383-8659
1A44-0609-9130-2159-2652-6444
1A45-0609-9030-2448-3213-9734
1A47-0609-9030-2261-0221-1250
1A4A-0609-9130-2091-2397-1890
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-9-1999 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26-10-2004 18:35:34
Nero Version: 6.6.0.13
Internal Version: 6, 6, 0, 13c
Recorder: <_NEC DVD_RW ND-3520A> Version: 1.04 - HA 1 TA 0 - 6.6.0.13
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <_NEC DVD_RW ND-3520A >Version: 1.04 - HA 1 TA 0 - 6.6.0.13
=== Scsi-Device-Map ===
DiskPeripheral : ST340014A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3520A atapi Port 1 ID 0 DMA: Off
DiskPeripheral : Maxtor 6L160P0 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 2 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3520A D: CDRom0
AXV CD/DVD-ROM F: CDRom1
AXV CD/DVD-ROM G: CDRom2
AXV CD/DVD-ROM K: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522240kB)
Free physical memory: 45MB (46556kB)
Memory in use : 91 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
17.11.2006
Audio CD
19:11:10 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 08:24.06, Pause frames: 150, Filters: 0, Name: '210864_Waterfalls_feat__Jimi_Dred_Stephan_Luke_Fat_Free_Mix.mp3'.
Track 02: Length: 07:03.02, Pause frames: 150, Filters: 0, Name: '210437_Sex_Lele_Cecchini_Remix.mp3'.
Track 03: Length: 07:30.06, Pause frames: 150, Filters: 0, Name: '209540_Lovey_Dovey_Vocal_Mix_With_Less_Instruments.mp3'.
Track 04: Length: 08:35.53, Pause frames: 150, Filters: 0, Name: '207988_Something_To_Lose_Starkillers_Remix.mp3'.
Track 05: Length: 07:03.47, Pause frames: 150, Filters: 0, Name: '207986_Something_To_Lose_Cedric_Gervais_Remix.mp3'.
Track 06: Length: 09:21.00, Pause frames: 150, Filters: 0, Name: '207335_Empower__feat__Kareema_Castro_Barry_Huffine___Thomas_Penton_Rewurked_Mix.mp3'.
Track 07: Length: 07:25.11, Pause frames: 150, Filters: 0, Name: '204100_The_World_Progg_Mix.mp3'.
Track 08: Length: 07:19.67, Pause frames: 150, Filters: 0, Name: '200347_Let_It_Drop_Henrik_B_Remix.mp3'.
Track 09: Length: 07:19.06, Pause frames: 150, Filters: 0, Name: '198227_Come_Into_My_World_Original_Mix.mp3'.
Track 10: Length: 07:37.61, Pause frames: 150, Filters: 0, Name: '197610_The_Spirit_Of_Ecstasy_Original_Mix.mp3'.
Total size: 77:59.34
19:11:10 #2 Text 0 File Burncd.cpp, Line 2882
Buffer underrun protection activated
19:11:10 #3 Text 0 File Reader.cpp, Line 127
Reader running
19:11:10 #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
19:11:10 #5 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-3520A running
19:11:10 #6 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-At-Once, using CD-R/RW media
19:11:11 #7 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 350808 ( 77:59.33)
19:11:11 #8 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
19:11:11 #9 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: _NEC DVD_RW ND-3520A;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
19:11:11 #10 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
19:11:11 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (210864_Waterfalls_feat__Jimi_Dred_Stephan_Luke_Fat_Free_Mix.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 37806 (37806) = #37806/8:24.6
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 37806 blocks [_NEC DVD_RW ND-3520A]
1: TRM_AUDIO_NOPRE (210437_Sex_Lele_Cecchini_Remix.mp3)
original disc pos #0 + 31727 (31727) = #31727/7:3.2
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 31727 blocks [_NEC DVD_RW ND-3520A]
2: TRM_AUDIO_NOPRE (209540_Lovey_Dovey_Vocal_Mix_With_Less_Instruments.mp3)
original disc pos #0 + 33756 (33756) = #33756/7:30.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 33756 blocks [_NEC DVD_RW ND-3520A]
3: TRM_AUDIO_NOPRE (207988_Something_To_Lose_Starkillers_Remix.mp3)
original disc pos #0 + 38678 (38678) = #38678/8:35.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 38678 blocks [_NEC DVD_RW ND-3520A]
4: TRM_AUDIO_NOPRE (207986_Something_To_Lose_Cedric_Gervais_Remix.mp3)
original disc pos #0 + 31772 (31772) = #31772/7:3.47
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 31772 blocks [_NEC DVD_RW ND-3520A]
5: TRM_AUDIO_NOPRE (207335_Empower__feat__Kareema_Castro_Barry_Huffine___Thomas_Penton_Rewurked_Mix.mp3)
original disc pos #0 + 42075 (42075) = #42075/9:21.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 42075 blocks [_NEC DVD_RW ND-3520A]
6: TRM_AUDIO_NOPRE (204100_The_World_Progg_Mix.mp3)
original disc pos #0 + 33386 (33386) = #33386/7:25.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 33386 blocks [_NEC DVD_RW ND-3520A]
7: TRM_AUDIO_NOPRE (200347_Let_It_Drop_Henrik_B_Remix.mp3)
original disc pos #0 + 32992 (32992) = #32992/7:19.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 32992 blocks [_NEC DVD_RW ND-3520A]
8: TRM_AUDIO_NOPRE (198227_Come_Into_My_World_Original_Mix.mp3)
original disc pos #0 + 32931 (32931) = #32931/7:19.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 32931 blocks [_NEC DVD_RW ND-3520A]
9: TRM_AUDIO_NOPRE (197610_The_Spirit_Of_Ecstasy_Original_Mix.mp3)
original disc pos #0 + 34336 (34336) = #34336/7:37.61
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 34336 blocks [_NEC DVD_RW ND-3520A]
19:11:11 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD_RW ND-3520A] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 10:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 89272512, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 89272512 89625312 164247216, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 164247216 164600016 243994128, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 243994128 244346928 335317584, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 335317584 335670384 410398128, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 410398128 410750928 509711328, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 509711328 510064128 588588000, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 588588000 588940800 666537984, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 666537984 666890784 744344496, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 744344496 744697296 825455568, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
37806 | 2 | 0 | 0x21 | 0x00
37956 | 2 | 1 | 0x21 | 0x00
69683 | 3 | 0 | 0x21 | 0x00
69833 | 3 | 1 | 0x21 | 0x00
103589 | 4 | 0 | 0x21 | 0x00
103739 | 4 | 1 | 0x21 | 0x00
142417 | 5 | 0 | 0x21 | 0x00
142567 | 5 | 1 | 0x21 | 0x00
174339 | 6 | 0 | 0x21 | 0x00
174489 | 6 | 1 | 0x21 | 0x00
216564 | 7 | 0 | 0x21 | 0x00
216714 | 7 | 1 | 0x21 | 0x00
250100 | 8 | 0 | 0x21 | 0x00
250250 | 8 | 1 | 0x21 | 0x00
283242 | 9 | 0 | 0x21 | 0x00
283392 | 9 | 1 | 0x21 | 0x00
316323 | 10 | 0 | 0x21 | 0x00
316473 | 10 | 1 | 0x21 | 0x00
350809 | lead-out | 1 | 0x01 | 0x00
19:11:11 #13 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6.000 KB/s)
19:11:11 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:11:11 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #37956
19:11:11 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #69833
19:11:11 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #103739
19:11:11 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #142567
19:11:11 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #174489
19:11:11 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #216714
19:11:11 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #250250
19:11:11 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #283392
19:11:11 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #316473
19:11:11 #24 Text 0 File Mmc.cpp, Line 16689
StartDAO : CD-Text - On
19:11:11 #25 Text 0 File Mmc.cpp, Line 21469
Set BUFE: Buffer underrun protection -> ON
19:11:11 #26 Text 0 File Mmc.cpp, Line 16978
CueData, Len=176
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 08 1a 06
21 02 01 00 00 08 1c 06
21 03 00 00 00 0f 1f 08
21 03 01 00 00 0f 21 08
21 04 00 00 00 17 03 0e
21 04 01 00 00 17 05 0e
21 05 00 00 00 1f 28 43
21 05 01 00 00 1f 2a 43
21 06 00 00 00 26 2e 27
21 06 01 00 00 26 30 27
21 07 00 00 00 30 09 27
21 07 01 00 00 30 0b 27
21 08 00 00 00 37 24 32
21 08 01 00 00 37 26 32
21 09 00 00 00 3e 3a 2a
21 09 01 00 00 3f 00 2a
21 0a 00 00 00 46 13 30
21 0a 01 00 00 46 15 30
01 aa 01 01 00 4d 3b 22
19:12:40 #27 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03650000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x56 0x46 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x53 0xB1 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
19:12:40 #28 CDR -1135 File Writer.cpp, Line 311
Write error
19:12:40 #29 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:12:41 #30 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:12:41 #31 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 40x (6.000 KB/s)
19:12:42 #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
19:12:42 #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17-8-2001 23:07:32
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10-9-1999 12:06:00
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 12-6-2003 0:00:00
File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 23-9-2004 2:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 3-8-2004 23:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
17.11.2006
Audio CD
Burn mode: DAO,
CD Text: On,
Reader running
ATIP Data:
DAO infos:
MCN: " "
Tracks 1 to 10:
DAO layout:
CueData, Len=176
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Existing drivers:
Registry Keys:
