Heb een moederbord op marktplaats gezien, die interessant lijkt. Weet alleen niet of die bij de rest past. Het gaat om:
MSI K8N Neo-FSR
CPU
• Supports 64-bit AMD® Athlon™ 64 processor (Socket 754)
• Supports up to 3200+, 3400+, 3700+ or higher CPU
Chipset
• nVIDIA® nForce3 250Gb Chipset
- Supports Athlon™ 64 processor (Socket 754), 800MHz Hypertransport interface.
- Supports single memory channels, DDR 400/333/266 without ECC support.
- Supports external AGP 4X/8X
- Integrated Serial ATA interface: dual channel 4 S-ATA RAID controller and dual channel
ATA 133/100/66/33 master mode EIDE controller.
- Integrated an nVIDIA MAC for Gigabit LAN.
- Supports 8 high speed USB2.0 ports.
- AC'97 2.3 compliance.
Main Memory
• Supports 3 slots for 184-pin DDR SDRAM DIMM modules.
• Supports DDR 400/333/266.
• Supports a maximum memory size of 2GB for DDR400
• Supports a maximum memory size of 3GB for DDR333
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 250Gb chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Support 2 S-ATA RAID controller and dual channel ATA 133/100/66/33 master mode EIDE controller.
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• nVIDIA® nForce3 NV Gigabit LAN controller
- Integrated Fast Ethernet MAC and PHY in one chip.
- Supports 10Mb/s, 100Mb/s and 1000Mb/s auto-negotiation operation.
- Compliant with PCI v2.2.
- Supports ACPI Power Management.
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 6 audio ports
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 1 RJ45 LAN jack
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your
mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Kan iemand beoordelen of deze geschikt is voor bij de rest van mijn spullen?
