hallo,
als ik mijn pc opstart dan zegd die:
We apologize for the inconvenience,but windows did not start successfull. A recent hardware or sofware cha eo might have caused this.
if your computer stopped. respondint, restarted unexpectedly was automatically shut down to protect ykr files and folders, choose last know good confriguration to revert to the most recent settings that worked.
If a previous startup attempt was interrupted deu to power failure or because the power or reset button was pressend, or if you aren't sure what caused the problem choosestart windows normaly, waar ik aleen uit kan kiezen is:
safe mode
Safe mode with networking
Safe mode with command prompt
Last known good cood configuration( your most recent settings that worked)
Use the up and down arrow keys to move the highlight your choice.
ik kan aleen naar bededenen omhoog gaan andwoord of ik antwoord ,1 ,2, of 3 wil.
iemad een idee?
safe mode
iemad een idee?
