help ...win waanzin
materna
11 jun 2003
hallo allemaal
ik doe het in engels want mijn nederlands niet zo goed is.
i installed a program to manage my boot operations since i wanted to install xp besides my win98.
but i accidentily set the boot option to start from a diskette.
now when i start my pc, it just asks me to place startup disk of the program, which i don't have..
when it finishes i can't run windows from c or use my cd rom to reinstall it.
i just get "bad command or file name" when type win.
i've tried setting boot to startup from cd rom on my bios but that doesn't help either.
i read somewhere that you can change the settings in msdos.sys but when i open it with edit.exe it tells me it's read only document...
i'm getting pretty desperate is there anyone who can help me?
i live in den haag and if the soloution is complicated i need a techie..
thanks in advance
ron
