super dus samenvattend, dit kan ik niet veranderen, omdat dit hardcore is, maar ik kan deze aan duidingen wel weghalen:
qoute van
http://answers.microsoft.com/en-us/...n/b42d61fd-9f5b-41d3-939a-83724aabab71?page=1
Petru Maxian replied on:
Hey there,
As far as I can see, you (like me) have more like a visual problem with those nasty red bars than a functional one. Hence, I could suggest you to look at the problem from a new perspective in order to solve the problem.
OK, you can't change the percentage because it's hardcoded...well, just get rid of those bars and voila - problem solved.
1. Run REGEDIT as administrator
2. Open HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Drive
3. Change the values for both TileInfo and PreviewDetails keys (double click on the keys) by removing the phrase "System.PercentFull;", without the quotes.
The TileInfo key:
Before: prop:*System.PercentFull;System.Computer.DecoratedFreeSpace;System.Volume.FileSystem
After: prop:*System.Computer.DecoratedFreeSpace;System.Volume.FileSystem
The PreviewDetails key:
Before: prop:*System.PercentFull;System.FreeSpace;System.Capacity;System.Volume.FileSystem;*System.Volume.BitLockerProtection
After
rop:*System.FreeSpace;System.Capacity;System.Volume.FileSystem;*System.Volume.BitLockerProtection
4. Open My Computer, you should be able to see the absence of the color bars. If you still see them, just restart windows explorer, or, if you don't know how to do this, just restart Windows.
5. Enjoy !!!
Hope it helps someone, it surely helped me get less unnecessary "red color" on my screen
