Sub jec()
Dim ar As Variant, iso As Variant
Dim dict As Object, i As Long
ar = Sheets(1).Cells(5, 1).CurrentRegion
Set iso = GetObject("C:\Users\xxx\Downloads\ISO codes (Open top- en flat containers).xls").Sheets(1).Cells(1, 1).CurrentRegion
Set dict = CreateObject("scripting.dictionary")
For i = 1 To UBound(ar)
If Application.CountIf(iso.Columns(1), ar(i, 3)) = 0 And ar(i, 31) <> "" And ar(i, 31) <> "-" Or ar(i, 7) = "Arrived" Then
dict(ar(i, 2)) = Array(ar(i, 2), ar(i, 3), ar(i, 5), ar(i, 6), ar(i, 7), ar(i, 31), ar(i, 40))
Next
With Sheets(1)
.UsedRange.Clear
.Cells(1, 1).Resize(dict.Count, 7) = Application.Index(dict.items, 0, 0)
.Cells(1, 1).CurrentRegion.AutoFilter
.Cells(1, 1).CurrentRegion.Columns.AutoFit
iso.Parent.Parent.Close 0
Sub jec()
Set iso = GetObject("G:\APMTR Data-EDI Center\Data-EDI\Documentation\ISO Codes Open Top en Flat containers\ISO codes (Open top- en flat containers).xls").Sheets(1).Cells(1, 1).CurrentRegion
Next
With Sheets(1)
.UsedRange.Clear
Range("A2").Select
ActiveWindow.FreezePanes = True
