icoon erbij gekomen
joyrider
21 jul 2001
ik heb een icoon erbij gekregen en ik kan bij msconfig niet vinden welke ik uit moet vinken..als ik de muis op het icoon zet staat er * Hardware veilig verwijderen* welke zou ik uit moeten zetten .. dit is mijn startup list ....
StartupList report, 13-2-2003, 12:49:29
Detected: Windows XP SP1 (WinNT 5.01.2600)
* Using default options
Running processes:
F:\WINDOWS\System32\smss.exe
F:\WINDOWS\system32\winlogon.exe
F:\WINDOWS\system32\services.exe
F:\WINDOWS\system32\lsass.exe
F:\WINDOWS\system32\svchost.exe
F:\WINDOWS\System32\svchost.exe
F:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
F:\Program Files\Norton Internet Security\NISUM.EXE
F:\WINDOWS\Explorer.EXE
F:\WINDOWS\system32\spoolsv.exe
F:\Program Files\Netropa\Multimedia Keyboard\MMKeybd.exe
F:\Program Files\Common Files\Symantec Shared\ccApp.exe
F:\Program Files\Lavasoft\Ad-aware 6\Ad-watch.exe
F:\Program Files\BulletProofSoft.com\SpywareRemover\SpyWatch.exe
F:\Program Files\Messenger\msmsgs.exe
F:\WINDOWS\System32\ctfmon.exe
F:\Program Files\Netropa\Multimedia Keyboard\TrayMon.exe
F:\Program Files\Netropa\Onscreen Display\OSD.exe
F:\Program Files\BulletProofSoft.com\SpywareRemover\C12860.DLL
F:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe
F:\Program Files\Norton Internet Security\ccPxySvc.exe
F:\Program Files\Norton AntiVirus\navapsvc.exe
F:\Program Files\G6 FTP Server\G6FTPSrv.exe
F:\Program Files\No-IP\DUC20.exe
F:\WINDOWS\System32\DllHost.exe
F:\Program Files\Internet Explorer\iexplore.exe
F:\Documents and Settings\XP\Bureaublad\Nieuwe map\StartupList.exe
Checking Windows NT UserInit:
[HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
UserInit = F:\WINDOWS\system32\userinit.exe,
Autorun entries from Registry:
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
MULTIMEDIA KEYBOARD = F:\Program Files\Netropa\Multimedia Keyboard\MMKeybd.exe
SiSUSBRG = F:\WINDOWS\SiSUSBrg.exe
ccApp = F:\Program Files\Common Files\Symantec Shared\ccApp.exe
ccRegVfy = F:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe
Ad-watch = F:\Program Files\Lavasoft\Ad-aware 6\Ad-watch.exe
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
SPYWATCH = F:\Program Files\BulletProofSoft.com\SpywareRemover\SpyWatch.exe /STARTUP
MSMSGS = "F:\Program Files\Messenger\msmsgs.exe" /background
ctfmon.exe = F:\WINDOWS\System32\ctfmon.exe
File association entry for .EXE:
HKEY_CLASSES_ROOT\exefile\shell\open\command
(Default) = "%1" %*
File association entry for .COM:
HKEY_CLASSES_ROOT\comfile\shell\open\command
(Default) = "%1" %*
File association entry for .BAT:
HKEY_CLASSES_ROOT\batfile\shell\open\command
(Default) = "%1" %*
File association entry for .PIF:
HKEY_CLASSES_ROOT\piffile\shell\open\command
(Default) = "%1" %*
File association entry for .SCR:
HKEY_CLASSES_ROOT\scrfile\shell\open\command
(Default) = "%1" /S
File association entry for .HTA:
HKEY_CLASSES_ROOT\htafile\shell\open\command
(Default) = F:\WINDOWS\System32\mshta.exe "%1" %*
Enumerating Active Setup stub paths:
HKLM\Software\Microsoft\Active Setup\Installed Components
[>{22d6f312-b0f6-11d0-94ab-0080c74c7e95}]
StubPath = F:\WINDOWS\INF\unregmp2.exe /ShowWMP
[>{26923b43-4d38-484f-9b9e-de460746276c}]
StubPath = %systemroot%\system32\shmgrate.exe OCInstallUserConfigIE
[>{881dd1c5-3dcf-431b-b061-f3f88e8be88a}]
StubPath = %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
[{2C7339CF-2B09-4501-B3F3-F3508C9228ED}]
StubPath = %SystemRoot%\system32\regsvr32.exe /s /n /i:/UserInstall %SystemRoot%\system32\themeui.dll
[{306D6C21-C1B6-4629-986C-E59E1875B8AF}]
StubPath = "F:\WINDOWS\System32\rundll32.exe" "F:\Program Files\Messenger\msgsc.dll",ShowIconsUser
[{44BBA840-CC51-11CF-AAFA-00AA00B6015C}]
StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
[{7790769C-0471-11d2-AF11-00C04FA35D02}]
StubPath = "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
[{89820200-ECBD-11cf-8B85-00AA005B4340}]
StubPath = regsvr32.exe /s /n /i:U shell32.dll
[{89820200-ECBD-11cf-8B85-00AA005B4383}]
StubPath = %SystemRoot%\system32\ie4uinit.exe
Checking for EXPLORER.EXE instances:
F:\WINDOWS\Explorer.exe: PRESENT!
C:\Explorer.exe: not present
F:\WINDOWS\Explorer\Explorer.exe: not present
F:\WINDOWS\System\Explorer.exe: not present
F:\WINDOWS\System32\Explorer.exe: not present
F:\WINDOWS\Command\Explorer.exe: not present
Checking for superhidden extensions:
.lnk: HIDDEN! (arrow overlay: yes)
.pif: HIDDEN! (arrow overlay: yes)
.exe: not hidden
.com: not hidden
.bat: not hidden
.hta: not hidden
.scr: not hidden
.shs: HIDDEN!
.shb: HIDDEN!
.vbs: not hidden
.vbe: not hidden
.wsh: not hidden
.scf: HIDDEN! (arrow overlay: NO!)
.url: HIDDEN! (arrow overlay: yes)
.js: not hidden
.jse: not hidden
Enumerating Browser Helper Objects:
*Registry value not found* - c:\nieuwe loads\dos\Reader\ActiveX\AcroIEHelper.ocx - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}
*Registry value not found* - c:\AdShield.dll - {7559B76E-0222-4d77-9499-CCE9EB4EDC2F}
NAV Helper - F:\Program Files\Norton AntiVirus\NavShExt.dll - {BDF3E430-B101-42AD-A544-FADC6B084872}
Enumerating Task Scheduler jobs:
1 Copernic Intra-Daily ~XP-5IV53Y0D6WC8 XP.job
2 Copernic Daily ~XP-5IV53Y0D6WC8 XP.job
3 Copernic Weekly ~XP-5IV53Y0D6WC8 XP.job
4 Copernic Monthly ~XP-5IV53Y0D6WC8 XP.job
Norton AntiVirus - Mijn computer scannen.job
Symantec NetDetect.job
Enumerating Download Program Files:
[sys Class]
InProcServer32 = F:\WINDOWS\Downloaded Program Files\PCPitStop.dll
CODEBASE = http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
[Cult3D ActiveX Player]
InProcServer32 = F:\WINDOWS\System32\Cult3D\IECult.dll
CODEBASE = http://www.cult3d.com/download/cult.cab
[Java Plug-in 1.3.1]
InProcServer32 = F:\Program Files\JavaSoft\JRE\1.3.1\bin\npjava131.dll
CODEBASE = http://java.sun.com/products/plugin/1.3.1/jinstall-131-win.cab
[{8E65B894-C2E9-11D5-BCD3-00E018987517}]
CODEBASE = http://195.57.118.137/17/cabs/akifondos283nl.cab
[Update Class]
InProcServer32 = F:\WINDOWS\System32\iuctl.dll
CODEBASE = http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?37656.440150463
[Shockwave Flash Object]
InProcServer32 = F:\WINDOWS\System32\macromed\flash\Flash.ocx
CODEBASE = http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
End of report, 8.215 bytes
Report generated in 0,080 seconds
StartupList version: 1.31.0
Started from: F:\Documents and Settings\XP\Bureaublad\Nieuwe map\StartupList.EXE
Command line options:
/verbose - to add additional info on each section
/complete - to include empty sections and unsuspicious data
/force9x - to include Win9x-only startups even if running on WinNT
/forcent - to include WinNT-only startups even if running on Win9x
/forceall - to include all Win9x and WinNT startups, regardless of platform
/history - to list version history only
Heb jij een apparaat (scanner, muis etc.) op je usb poort zitten?
dat icoon is van aangekoppelde externe hardware.
camera of zo .
pe.
Als je niks aan je USB of een firewirepoort hebt hangen gooi dan die SiSUSBrg.exe maar uit je opstartlijst.
Groetjes,
Pieter
klopt ...ik heb een infarood oog en printer USB erop zitten ..
