Java probleem
keestramper
10 mei 2005
Gisteren is tot 3 keer toe java gecrashed op mijn pc waarna er een log is achter gelaten op mijn buroblad. Hieronder staat het log. Moet ik Java opnieuw installeren?
Met vr groet Kees Tramper
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x69651fa7, pid=1744, tid=3332
# JRE version: 6.0_30-b12
# Java VM: Java HotSpot(TM) Client VM (20.5-b03 mixed mode windows-x86 )
# Problematic frame:
[error occurred during error reporting (printing problematic frame), id 0xc0000005]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x1a5e4000): JavaThread "Thread-13" daemon [_thread_in_native, id=3332, stack(0x1bfc0000,0x1c010000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x00000000
Registers:
EAX=0x00000481, EBX=0x00000000, ECX=0x40896cc8, EDX=0x00000000
ESP=0x1c00ef00, EBP=0x00000000, ESI=0x00000001, EDI=0x00000000
EIP=0x69651fa7, EFLAGS=0x00210246
Top of Stack: (sp=0x1c00ef00)
0x1c00ef00: 00000000 218f76e4 40896cc8 219002cc
0x1c00ef10: 00000000 00000002 00000000 696524d1
0x1c00ef20: 230c70d8 00000001 218b7530 218f76e4
0x1c00ef30: 2daf4c28 00000021 00000000 69652762
0x1c00ef40: 218f7530 00000001 00000000 218f7530
0x1c00ef50: 696550c4 218f76e4 218b2fb0 00000004
0x1c00ef60: 00000000 6965dce5 00000001 218b2fb0
0x1c00ef70: 00000001 00000004 1c00efa8 6928c29a
Instructions: (pc=0x69651fa7)
0x69651f87: 7f 08 ff 44 b1 08 8b 9c 81 18 fc ff ff 2d 00 01
0x69651f97: 00 00 85 db 74 06 89 7c b3 04 eb 23 8b 5c 24 10
0x69651fa7: 89 02 89 7c b2 04 83 cf ff 89 7c 9a 04 8b 5c 24
0x69651fb7: 14 89 7c 9a 04 89 54 81 18 ff 41 04 83 c2 10 8b
Register to memory mapping:
EAX=0x00000481 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x40896cc8 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x1c00ef00 is pointing into the stack for thread: 0x1a5e4000
EBP=0x00000000 is an unknown value
ESI=0x00000001 is an unknown value
EDI=0x00000000 is an unknown value
Stack: [0x1bfc0000,0x1c010000], sp=0x1c00ef00, free space=315k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting (printing native stack), id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J jaggl.OpenGL.glLightfv(II[FI)V
J wva.U()V
J wva.a(I[Ljava/lang/Object;)V
J ko.a(Ljava/lang/Object;Ljava/lang/Object;[Ljava/lang/Object;)V
J ko.a(Ljava/lang/Object;Z[[[BIBI)V
J ko.a(Ljava/lang/Object;IIII[[[B[I[I[I[I[IIBIIZZIZ)V
j ci.a(IIIIIZ)V+4946
j leb.a(IIZIZIII[Ljava/lang/Object;II)V+2291
j leb.a(IIZIZIII[Ljava/lang/Object;II)V+6664
J fla.a(IIBIIIIII)V
J wka.a(I)V
J client.f(Z)V
J client.d(I)V
J ht.a(B)V
J ht.c(Z)V
j ht.run()V+10
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x1a5e4c00 JavaThread "Thread-24" daemon [_thread_blocked, id=4008, stack(0x1d230000,0x1d280000)]
0x1a5e2000 JavaThread "Thread-23" daemon [_thread_in_native, id=2072, stack(0x1d1a0000,0x1d1f0000)]
0x18db8800 JavaThread "Thread-19" daemon [_thread_blocked, id=2656, stack(0x20130000,0x20180000)]
0x18db8400 JavaThread "Java Sound Event Dispatcher" daemon [_thread_blocked, id=2304, stack(0x1fdf0000,0x1fe40000)]
0x1a5e4400 JavaThread "Thread-15" daemon [_thread_blocked, id=1904, stack(0x1c0d0000,0x1c120000)]
0x1a5e2c00 JavaThread "Thread-14" daemon [_thread_blocked, id=3820, stack(0x1bc70000,0x1bcc0000)]
=>0x1a5e4000 JavaThread "Thread-13" daemon [_thread_in_native, id=3332, stack(0x1bfc0000,0x1c010000)]
0x1a5e3800 JavaThread "Thread-12" [_thread_in_native, id=2756, stack(0x1bf30000,0x1bf80000)]
0x1a5e2800 JavaThread "Thread-11" [_thread_blocked, id=3000, stack(0x1bea0000,0x1bef0000)]
0x1a5dfc00 JavaThread "Thread-10" daemon [_thread_blocked, id=2244, stack(0x1bbe0000,0x1bc30000)]
0x1a5e0c00 JavaThread "thread applet-Rs2Applet.class-1" [_thread_blocked, id=3848, stack(0x1afb0000,0x1b000000)]
0x1a5e1800 JavaThread "AWT-EventQueue-2" [_thread_blocked, id=2140, stack(0x1bac0000,0x1bb10000)]
0x1a5e1400 JavaThread "JVM[id=0]-Heartbeat" daemon [_thread_blocked, id=2340, stack(0x1ba30000,0x1ba80000)]
0x1a5e0800 JavaThread "Applet 1 LiveConnect Worker Thread" [_thread_blocked, id=480, stack(0x1ae90000,0x1aee0000)]
0x1a5e0000 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=3436, stack(0x1b8d0000,0x1b920000)]
0x1a5df400 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=2700, stack(0x1b160000,0x1b1b0000)]
0x1a5dec00 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=3448, stack(0x1b0d0000,0x1b120000)]
0x1a5b6c00 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=2820, stack(0x1b040000,0x1b090000)]
0x18dbf800 JavaThread "SysExecutionTheadCreator" daemon [_thread_blocked, id=932, stack(0x1a990000,0x1a9e0000)]
0x1a5b1000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=3836, stack(0x1af20000,0x1af70000)]
0x1a5b0000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3048, stack(0x1ae00000,0x1ae50000)]
0x1a5aa400 JavaThread "AWT-Shutdown" [_thread_blocked, id=972, stack(0x1ad70000,0x1adc0000)]
0x1a5a9c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2896, stack(0x1ac70000,0x1acc0000)]
0x1a584800 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=3932, stack(0x1aa20000,0x1aa70000)]
0x18dbf000 JavaThread "Timer-0" [_thread_blocked, id=2080, stack(0x1a4a0000,0x1a4f0000)]
0x18d7f000 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=780, stack(0x1a310000,0x1a360000)]
0x18d57400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2424, stack(0x1a1f0000,0x1a240000)]
0x18d54800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3588, stack(0x1a160000,0x1a1b0000)]
0x18d54000 JavaThread "Attach Listener" daemon [_thread_blocked, id=3948, stack(0x19fd0000,0x1a020000)]
0x18d53800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2128, stack(0x19f40000,0x19f90000)]
0x18d51000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=3008, stack(0x19eb0000,0x19f00000)]
0x18d28000 JavaThread "Finalizer" daemon [_thread_blocked, id=1960, stack(0x19e20000,0x19e70000)]
0x18d24400 JavaThread "Reference Handler" daemon [_thread_blocked, id=3464, stack(0x19d90000,0x19de0000)]
0x00bba000 JavaThread "main" [_thread_blocked, id=3120, stack(0x00430000,0x00480000)]
Other Threads:
0x18d21400 VMThread [stack: 0x19d00000,0x19d50000] [id=3688]
0x18d5c800 WatcherThread [stack: 0x1a280000,0x1a2d0000] [id=3728]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 29504K, used 4891K [0x04a90000, 0x06a90000, 0x06a90000)
eden space 26240K, 13% used [0x04a90000, 0x04e0d590, 0x06430000)
from space 3264K, 40% used [0x06760000, 0x068a9840, 0x06a90000)
to space 3264K, 0% used [0x06430000, 0x06430000, 0x06760000)
concurrent mark-sweep generation total 229376K, used 154763K [0x06a90000, 0x14a90000, 0x14a90000)
concurrent-mark-sweep perm gen total 35888K, used 21301K [0x14a90000, 0x16d9c000, 0x18a90000)
Code Cache [0x02770000, 0x03f20000, 0x04770000)
total_blobs=3265 nmethods=2973 adapters=227 free_code_cache=8724992 largest_free_block=256
Dynamic libraries:
[error occurred during error reporting (printing dynamic libraries), id 0xc0000005]
VM Arguments:
jvm_args: -D__jvm_launched=293960171 -Xbootclasspath/a:C:\\PROGRA~2\\Java\\jre6\\lib\\deploy.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\javaws.jar;C:\\PROGRA~2\\Java\\jre6\\lib\\plugin.jar -Dsun.awt.warmup=true -Xmx256m -Xincgc -XX:+UseConcMarkSweepGC -Dsun.java2d.noddraw=true -Dsun.plugin2.jvm.args=-D__jvm_launched=293960171 "-Xbootclasspath/a:C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\deploy.jar;C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\javaws.jar;C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\lib\\\\plugin.jar" "-Djava.class.path=C:\\\\PROGRA~2\\\\Java\\\\jre6\\\\classes" -Dsun.awt.warmup=true --- -- -Xmx256m -Xincgc -XX:+UseConcMarkSweepGC -Dsun.java2d.noddraw=true
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid2544_pipe3,read_pipe_name=jpi2_pid2544_pipe2
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Internet Explorer;;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\jZip;C:\Program Files\Internet Explorer
USERNAME=Gebruiker
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 26 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 8379512k(5173452k free), swap 16757176k(13142104k free)
vm_info: Java HotSpot(TM) Client VM (20.5-b03) for windows-x86 JRE (1.6.0_30-b12), built on Nov 10 2011 01:51:00 by "java_re" with MS VC++ 7.1 (VS2003)
time: Sun Feb 05 16:00:07 2012
elapsed time: 5348 seconds
dit probleem heb ik ook wel eens gehad, maar dan met minecraft (spel, via java) gewoon even een nieuwere versie downloaden of opnieuw installeren
gr. Maurice
