joomla position template klopt niet
  • Onderwerp starter Onderwerp starter spicy
spicy
22 feb 2012
Dit is er allemaal mogelijk
HTML:
<?php
 * @license Commercial/Proprietery - released under a commercial license
 * design by: Joomlaplates
defined('_JEXEC') or die;
/* The following line loads the MooTools JavaScript Library */
JHTML::_('behavior.mootools');
/* The following line gets the application object for things like displaying the site name */
$app = JFactory::getApplication();
<!DOCTYPE html>
<html xml:lang="<?php echo $this->language; ?>" lang="<?php echo $this->language; ?>" >
<head>
<jdoc:include type="head" />
<link rel="stylesheet" href="<?php echo $this->baseurl; ?>/templates/system/css/general.css" type="text/css" />
<!-- Loads Template Layout CSS -->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/layout.css" type="text/css" />
<!-- Loads Joomla base/default classes-->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/template.css" type="text/css" />
<!-- Loads left main right -->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/<?php echo $this->params->get('template_layout'); ?>.css" type="text/css"/>
<!-- Loads left right menu-->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/menu.css" type="text/css" />
<!-- Loads Suckerfish -->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/suckerfish.css" type="text/css"/>
<!-- Loads Module Styles -->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/css/module.css" type="text/css" />
<!-- Loads Typo Styles -->
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/jp_typo.css" type="text/css" />
<?php if($this->params->get('cssThree') == 1) : ?>
<!-- Loads CSS3 file with some nice modern effects-->
  <link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/css3.css" type="text/css" />
<?php endif; ?>
<!--[if IE 7]>
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/ie7.css" type="text/css" media="screen, projection, print">
<![endif]-->
<?php if($this->params->get('slimbox') == 1) : ?>
<script type="text/javascript" src="templates/<?php echo $this->template ?>/js/slimbox.js"></script>
<?php endif; ?>
<?php if($this->params->get('fonts') == 1) : ?>
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/fonts/fonts.css" type="text/css" />
<?php endif; ?>
<?php if($this->countModules('header1 or header2 or header3 or header4 or header5 or header6 or header7 or header8 or header9 or header10 or header11 or header12')) : ?>
<!--Starting Slider Script-->
<script type="text/javascript" src="templates/<?php echo $this->template ?>/js/slide.js"></script>
  window.addEvent('domready',function(){
    var nS4 = new noobSlide({
      box: $('box'),
      items: $$('#box .slide'),
      <?php if($this->params->get('sliderAuto') == 1) : ?>autoPlay: true,<?php endif; ?>
      interval: <?php echo $this->params->get('sliderTime'); ?>,
      size: <?php echo $this->params->get('slider_width'); ?>,
      addButtons: {
        previous: $('prev'),
        play: $('play'),
        stop: $('stop'),
        next: $('next')
  </script>
<?php endif; ?>
<?php if($this->countModules('header + header1 + header2 + header3 + header4 + header5 + header6 + header7 + header8 + header9 + header10 + header11 + header12') == 0) { ?>
<style type="text/css" media="screen">
  /* .wrapper { background:url(templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/images/wrapper_no_header.png) top left repeat-x}*/
</style>
<?php } ?>
<?php if($this->countModules('language + topmenu') == 0) { ?>
   .function_outer { display:none; }
</style>
<?php } ?>
<?php if($this->countModules('breadcrumbs + search') == 0) { ?>
   .pathway_outer { display:none }
</style>
<?php } ?>
   #left, #right  { width:<?php echo $this->params->get('module_width'); ?>; }
   .template_width { width:<?php echo $this->params->get('template_width'); ?>; }
</style>
<?php if($this->countModules('user1 and user2 and user3') == 1) { ?>
   .usertop { width:33.33%}
</style>
<?php } ?>
<?php if($this->countModules('user1 xor user2 xor user3') == 0) { ?>
   .usertop { width:50%}
</style>
<?php } ?>
<?php if($this->countModules('user4 and user5 and user6') == 1) { ?>
   .userbottom1 { width:33.33%}
</style>
<?php } ?>
<?php if($this->countModules('user4 xor user5 xor user6') == 0) { ?>
   .userbottom1 { width:50%}
</style>
<?php } ?>
<?php if($this->countModules('user7 and user8 and user9') == 1) { ?>
   .userbottom2 { width:33.33%}
</style>
<?php } ?>
<?php if($this->countModules('user7 xor user8 xor user9') == 0) { ?>
   .userbottom2 { width:50%}
</style>
<?php } ?>
<!-- Add slider height via CSS and primary color-->
<style type="text/css">
/*Adding height from template config to header box and mask*/
#box div, .mask1{width:<?php echo $this->params->get('slider_width'); ?>px;height:<?php echo $this->params->get('sliderHeight'); ?>px;}
</style>
<!--Starting Suckerfish Script-->
<?php if($this->params->get('showSuckerfish') == 1) : ?>
<script type="text/javascript" src="templates/<?php echo $this->template ?>/js/moomenu.js"></script>
  $('suckerfish').MooDropMenu({
    onOpen: function(el){
      el.fade('in')
    onClose: function(el){
      el.fade('out');
    onInitialize: function(el){
      el.fade('hide').set('tween',{duration:500});
</script>
<?php endif; ?>
<!--Suckerfish Script End-->
<!--Loads FavIcon-->
<link rel="shortcut icon" href="templates/<?php echo $this->template ?>/images/favicon.ico" />
</head>
<body>
<div class="function_outer"> <!-- This container includes the whole function area-->
  <div class="function_inner template_width">
      <?php if($this->countModules('language')) : ?>
        <div class="language">
          <jdoc:include type="modules" name="language" style="raw" />
        </div>
      <?php endif; ?>
      <?php if($this->countModules('topmenu')) : ?>
        <div class="topmenu">
          <jdoc:include type="modules" name="topmenu" style="raw" />
        </div>
      <?php endif; ?>
  <div class="jpclear"></div><!--AUTO HEIGH FIX FOR FIREFOX -->
  </div> <!-- div.function_inner ends here-->
</div> <!-- div.function_outer ends here-->
<div class="wrapper">
<div class="wrapper_inner template_width">
  <div class="top_inner template_width">
    <div class="logo">
      <h1 style="text-align:center"><a href="<?php echo $this->baseurl;?>"><img src="templates/<?php echo $this->template ?>/styles/<?php echo $this->params->get('background'); ?>/images/logo.gif" alt="<?php echo $app->getCfg('sitename'); ?>"  /></a></h1>
    </div>
<!--BEGINN SUCKERFISH -->
    <?php if($this->countModules('suckerfish')) : ?>
    <div id="suckerfish" class="dropdown"><jdoc:include type="modules" name="suckerfish" style="raw" /></div>
    <div class="menu_shadow"></div>
    <?php endif; ?>
<!--END SUCKERFISH -->
  </div> <!-- div.top_inner ends here-->
<div class="pathway_outer"> <!-- This container includes the pathway and search module-->
  <div class="pathway_inner template_width">
      <?php if($this->countModules('breadcrumbs')) : ?>
        <div class="breadcrumbs">
          <jdoc:include type="modules" name="breadcrumbs" style="raw" />
        </div>
      <?php endif; ?>
      <?php if($this->countModules('search')) : ?>
        <div class="jpsearch">
          <jdoc:include type="modules" name="search" style="raw" />
        </div>
      <?php endif; ?>
  </div> <!-- div.pathway_inner ends here-->
</div> <!-- div.pathway_outer ends here-->
<!-- ****************** Header Area with Header image, top modules etc. ****************** -->
<?php if($this->countModules('header or header1 or header2 or header3 or header4 or header5 or header6 or header7 or header8 or header9 or header10 or header11 or header12 or header')) : ?>
<div class="header_outer"> <!-- This container includes header area-->
  <div class="header_inner template_width">
      <!-- Including header area -->
      <?php require_once('includes/header.php'); ?>
  </div>
  <!-- div.header_inner ends here-->
  <div class="header_shadow"></div>
</div> <!-- div.header_outer ends here-->
<?php endif; ?>
 </div><!-- div.wrapper_inner ends here-->
</div><!-- div.wrapper ends here-->
<!-- ****************** Main Area with all main content ****************** -->
<div class="main_outer">
  <div class="main_inner template_width" >
    <div class="main">
          <div class="container">
          <?php if($this->countModules('user1 or user2 or user3')) : ?>
          <!-- Including top content area -->
          <?php require_once('includes/top_module.php'); ?>
          <?php endif; ?>
          <!-- Including inner content area -->
          <?php require_once('includes/innercontent.php'); ?>
          <?php if($this->countModules('user4 or user5 or user6')) : ?>
          <!-- Including bottom content area-->
          <?php require_once('includes/bottom_module1.php'); ?>
          <?php endif; ?>
          <?php if($this->countModules('user7 or user8 or user9')) : ?>
          <?php require_once('includes/bottom_module2.php'); ?>
          <?php endif; ?>
          </div>
    </div><!-- div.main ends here-->
  </div> <!-- div.main_inner ends here-->
</div> <!-- div.main_outer ends here-->
<?php if($this->countModules('footer')) : ?><div id="footer"><jdoc:include type="modules" name="footer" style="rounded" /></div><?php endif; ?>
<jdoc:include type="modules" name="debug" style="" />
</body>
</html>
Misschien dat iemand in main template ziet wat ik verkeerd doe
Hier ziet u dat ik de juiste position top van de template genaamd •jp_exquisite (Top)
selecteer
Maar als u kijkt op www.familyrestauranthuahin.com verschijnt er niet zo'n mooie navagatie bar
kan iemand me helpen met het oplossen van dit probleem
