Ik had hetzelfde met Shareaza. Service pack 2 beperkt het aantal verbindingen dat je computer kan maken. Hieronder staat een hack om dat te verwijderen. Shareaza werkt nu weer normaal. Wat jij hebt zal ook wel daardoor komen.
"The more recent versions of Shareaza detect the presence of Service Pack 2 in the settings wizard, and will modify certain variables to improve performance and reliability.
You can download a recent version of Shareaza here:
http://www.shareaza.com/?id=download
Then run the Quickstart Wizard in the tools menu. You should see a confirmation that your system has been configured.
http://www.anenga.com/images/shareazasp2.gif
That's all you need to do to get up and running under Windows XP, service pack 2!
Note that users of XP service pack 2 may have real trouble getting connected to multiple networks- Generally, it works best sticking to the default settings. Most users find that attemting to run more than two networks will cause problems, so be careful if you plan to enable other protocols.
If you are an advanced user and don't mind messing with your operating system, several people have reported success modifying system files. This may allow you to improve performance.
Warning:
Hacking system files is dangerous. You could mess up Windows if you do something wrong, and possibly lose data. We do not offer support for this operation, and you should not try it unless you know what you are doing.
Here is a hack to remove the SP2 limit:
http://www.lvllord.de/4226fix/4226fix-en.htm
(Not created or tested by the Shareaza team)
Once this hack has been applied, the SP2 limits should have been removed. It would then be safe to modify some advanced settings in Shareaza to reflect this:
Downloads.MaxConnectingSources can be set to 20. (This is the most important change)
Gnutella.ConnectFactor can be increased to 4 or 5 to improve connect speed. (Modem or low bandwidth users may want to keep it at 3)
Downloads.ConnectThrottle should be set to 250 - 500, depending on your connection. (If you router regualarly gives you trouble, you might want to increase this.)
Downloads.MaxFileSearches should be set between 1 and 4. (1 for low bandwidth users, 3 for high.)
Another Warning:
Be certain you have removed the SP2 limit before changing these settings. If you make these changes, and have not modified the system files, then Shareaza is likely to run very, very badly.
Meld misbruik in dit bericht
