w00tare
- 10 jul 2009
Hallo Helpmij Leden.
Ik heb een progamma gemaakt wat eingelijk simpel task processen killt (sluit),
Maar ik heb de functie ;
Werk ook helemaal perfect.
Maar nu de Shutdown/Kill code :
Hij geeft een error, dat die een process niet kan omzetten in een string.
Als iemand hier een oplossing voor weet,
Graag.
Btw; voel vrij om de codes te gebruiken
ListBox1.Items.Clear()
ListBox1.DisplayMember = "ProcessName"
Dim p As System.Diagnostics.Process
For Each p In System.Diagnostics.Process.GetProcesses
ListBox1.Items.Add(p)
Next
Private Sub cmdSendCloseMessage_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles cmdSendCloseMessage.Click
Dim target_hwnd As Integer
' Get the target's window handle.
target_hwnd = FindWindow(vbNullString, ListBox1.SelectedItem)
If target_hwnd = 0 Then
MsgBox("Error finding target window handle")
Exit Sub
' Send the application the WM_CLOSE message.
PostMessage(target_hwnd, WM_CLOSE, 0, 0)
cmdTerminate.Enabled = True
cmdSendCloseMessage.Enabled = False
' Terminate the process.
Private Sub cmdTerminate_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles cmdTerminate.Click
Dim target_process_id As Integer
Dim target_process_handle As Integer
Exit Sub
' Get the process ID.
GetWindowThreadProcessId(target_hwnd, target_process_id)
If target_process_id = 0 Then
MsgBox("Error finding target process ID")
Exit Sub
' Open the process.
target_process_handle = OpenProcess(SYNCHRONIZE Or PROCESS_TERMINATE, 0, target_process_id)
If target_process_handle = 0 Then
MsgBox("Error finding target process handle")
Exit Sub
If TerminateProcess(target_process_handle, 0) = 0 Then
MsgBox("Error terminating process")
Else
MsgBox("Process terminated")
' Close the process.
CloseHandle(target_process_handle)
cmdSendCloseMessage.Enabled = True
cmdTerminate.Enabled = False
Graag.
