Bruce The Boss
- 14 aug 2002
Ik wil even tijdelijk Joomla 1.5 op mijn computer installeren d.m.v. Xampp maar het wil niet lukken.
Ik heb de onderstaande stappen doolopen:
Xampp gedownload en geïnstalleer
Apache / MySql en Filezilla aangezet (zijn alle drie groen)
in de map c:\xampp\htdocs\joomla\ de bestanden van Joomla 1.5 uitgepakt
Als ik nu naar http://localhost/joomla ga gaat hij door naar http://localhost/joomla/installation/index.php maar dan krijg ik de onderstaande meldingen:
Strict Standards: Non-static method JLoader::import() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 29
Strict Standards: Non-static method JLoader::register() should not be called statically in C:\xampp\htdocs\joomla\libraries\loader.php on line 71
Strict Standards: Non-static method JLoader::import() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 32
Strict Standards: Non-static method JLoader::load() should not be called statically in C:\xampp\htdocs\joomla\libraries\loader.php on line 161
Strict Standards: Non-static method JLoader::register() should not be called statically in C:\xampp\htdocs\joomla\libraries\loader.php on line 138
Strict Standards: Non-static method JRequest::clean() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 33
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 463
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 464
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 465
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 466
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 467
Strict Standards: Non-static method JRequest::_cleanArray() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\environment\request.php on line 468
Strict Standards: Non-static method JLoader::import() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 35
Strict Standards: Non-static method JLoader::import() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 38
Strict Standards: Non-static method JLoader::import() should not be called statically in C:\xampp\htdocs\joomla\libraries\joomla\import.php on line 39
En zo nog veeeeeeele meer.
Doe ik iets fout of vergeet ik iets?
