Labels BackColor
DutchOirs
30 sep 2009
Goedenavond,
Zit weer met een vraagje.
Gebruik Labels om bepaalde gegevens te tonen.
Gebruik hierbij ook kleuren voor de BackColor van de Labels.
Vroeg me af of er geen betere manier is met een loop of lus om al deze Labels weer hun standaard kleur te geven (grijs)
Heb nu het volgende:
Private Sub Kleuren2TB()
  If Label1 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label2 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label3 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label4 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label5 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label6 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label7 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label8 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label9 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label10 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label11 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label12 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label13 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label14 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label15 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label16 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label17 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label18 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label19 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label20 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label21 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label22 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label23 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label24 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label25 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label26 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label27 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label28 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label29 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label30 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label31 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label32 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label33 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label34 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label35 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label36 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label37 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label38 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label39 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label40 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label41 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label42 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label43 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label44 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label45 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label46 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label47 <> "" Then Label1.BackColor = RGB(192, 192, 192)
  If Label48 <> "" Then Label1.BackColor = RGB(192, 192, 192)
met de optie
 For i = 1 To 3
   Label(i).BackColor = RGB(192, 192, 192)
 Next i
werkt dus niet.
ff een vb-tje bijgevoegd..
Vr. Gr.
Dutch
Deze dan:
    Dim i As Integer
    For i = 1 To 48
        If Controls("Label" & i) <> "" Then _
           Controls("Label" & i).BackColor = RGB(192, 192, 192)
    Next i
Of wat je ook vaak ziet.
Private Sub WrkBut_Click()
    Dim i As Integer
    For i = 1 To 48
        If [COLOR="#FF0000"]Me[/COLOR]("Label" & i) <> vbNullString Then _
           [COLOR="#FF0000"]Me[/COLOR]("Label" & i).BackColor = RGB(192, 192, 192)
    Next i
Dat gebruik van Me kende ik nog niet. Weer wat geleerd :)
Goedemorgen beidde,
Druk weekend geweest en niet veel tijd in VBA gestopt :-(
Ga ermee aan de slag en je hoort nog van me..
Wel een vraag aan warm bakkertje: wat is het verschil/voordeel om Me te gebruiken?
Thanks
Vr. Gr.
Dutch
Me("objectnaam") verwijst naar een object op het actieve bronobject. Meestal is dat een formulier of een rapport. In Access is het behoorlijk gebruikelijk om met Me naar de verschillende objecten zoals tekstvakken en recordsource te verwijzen. In Excel kan dat ook.
Of
  For j = 1 To 48
    Me("Label" & j).BackColor = iif(Me("Label" & j).caption="",Me("Label" & j).backcolor,RGB(192, 192, 192))
  Next
maar mijn voorkeur
  For j = 1 To 48
    Me("Label" & j).visible=Me("Label" & j).caption<>""
  Next
@Edmoor
Zet in de macromodule van Thisworkbook:
Sub M_snb()
   MsgBox Me.Name
Zet in de macromodule van een werkblad:
Sub M_snb()
   MsgBox Me.Name
Zet in een userform
Private sub Userform_initialize()
   MsgBox Me.Name
Dan zie je dat Me een relatief begrip is: een verwijzer naar de container (hoogste 'parent') van de macro in dit geval.
ja, ik weet wat het is. Kende alleen het gebruik ervan in plaats van het door mij gebruikte Controls niet.
Dank je :)
