Features that are unavailable in shared workbooks
Show All
Hide All
You can access the following features only if you stop sharing the workbook.
You cannot use shared workbooks (shared workbook: A workbook set up to allow multiple users on a network to view and make changes at the same time. Each user who saves the workbook sees the changes made by other users.) on Web servers.
Unavailable feature Alternatives
Create lists (list: A series of rows that contains related data or a series of rows that you designate to function as a datasheet by using the Create List command.) None
Work with XML data, including:
Import, refresh, and export XML data
Add, rename, or delete XML maps
Map cells to XML elements
Use the XML source task pane, XML toolbar, or XML commands on the Data menu
None
Insert or delete blocks of cells You can insert entire rows and columns.
Delete worksheets None
Merge cells or split merged cells None
Add or change conditional formats Existing conditional formats continue to appear as cell values change, but you can't change these formats or redefine the conditions.
Add or change data validation Cells continue to be validated when you type new values, but you can't change existing data validation settings.
Create or change charts or PivotChart reports You can view existing charts and reports.
Insert or change pictures or other objects You can view existing pictures and objects.
Insert or change hyperlinks Existing hyperlinks continue to work.
Use drawing tools You can view existing drawings and graphics.
Assign, change, or remove passwords (password: A way to restrict access to a workbook, worksheet, or part of a worksheet. Excel passwords can be up to 255 letters, numbers, spaces, and symbols. You must type uppercase and lowercase letters correctly when you set and enter passwords.) Existing passwords remain in effect.
Protect or unprotect worksheets or the workbook Existing protection remains in effect.
Create, change, or view scenarios None
Group or outline data You can continue to use existing outlines.
Insert automatic subtotals You can view existing subtotals.
Create data tables (data table: A range of cells that shows the results of substituting different values in one or more formulas. There are two types of data tables: one-input tables and two-input tables.) You can view existing data tables.
Create or change PivotTable reports You can view existing reports.
Write, record, change, view, or assign macros You can run existing macros that don't access unavailable features. You can record shared workbook operations into a macro stored in another nonshared workbook.
Add or change Microsoft Excel 4 dialog sheets None
Change or delete array formulas (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) Existing array formulas continue to calculate correctly.
Use a data form to add new data You can use a data form to find a record.
