Mailbox kiezen bij verzenden
chiellebeest
5 jan 2010
Ik heb een macro waarmee ik een overzicht mail. Ik heb in Outlook meerdere emailadressen, ik heb in de macro aangeven welk adres er gebruikt moet worden, helaas gebeurd dit niet.
' Works in Excel 2000, Excel 2002, Excel 2003, Excel 2007, Excel 2010, Outlook 2000, Outlook 2002, Outlook 2003, Outlook 2007, and Outlook 2010.
    Dim fso As Object
    Dim ts As Object
    Dim TempFile As String
    Dim TempWB As Workbook
    TempFile = Environ$("temp") & "/" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
    ' Copy the range and create a workbook to receive the data.
    rng.Copy
    Set TempWB = Workbooks.Add(1)
    With TempWB.Sheets(1)
        .Cells(1).PasteSpecial Paste:=8
        .Cells(1).PasteSpecial xlPasteValues, , False, False
        .Cells(1).PasteSpecial xlPasteFormats, , False, False
        .Cells(1).Select
        On Error Resume Next
        .DrawingObjects.Visible = True
        .DrawingObjects.Delete
        On Error GoTo 0
    ' Publish the sheet to an .htm file.
    With TempWB.PublishObjects.Add( _
         SourceType:=xlSourceRange, _
         Filename:=TempFile, _
         Sheet:=TempWB.Sheets(1).Name, _
         Source:=TempWB.Sheets(1).UsedRange.Address, _
         HtmlType:=xlHtmlStatic)
        .Publish (True)
    ' Read all data from the .htm file into the RangetoHTML subroutine.
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
    RangetoHTML = ts.readall
    ts.Close
    RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
                          "align=left x:publishsource=")
    ' Close TempWB.
    TempWB.Close savechanges:=False
    ' Delete the htm file.
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
    Set TempWB = Nothing
End Function
    Function GetOutlookAccount(objOutlook As Object, strEmailId As String) As Object
Dim objOAccount As Object
    For Each objOAccount In objOutlook.Session.Accounts
     If objOAccount.DisplayName = strEmailId Then
       Set GetOutlookAccount = objOAccount
       Exit For
    Next objOAccount
End Function
Function GetBoiler(ByVal sFile As String) As String
    Dim fso As Object
    Dim ts As Object
    Set ts = fso.GetFile(sFile).OpenAsTextStream(1, -2)
    GetBoiler = ts.readall
    ts.Close
End Function
Sub Create_Mail_List()
    Dim OutApp As Object
    Dim OutMail As Object
    Dim rng As Range
    Dim cell As Range
    Dim strto As String
    Dim strbody As String
    Dim SigString As String
    Dim mailaccount As Object
    Dim objOutlook As Object
    Dim objoutlookaccount As Object
    For Each cell In ThisWorkbook.Sheets("Blad1").Range("e2:e50")
    If cell.Value Like "?*@?*.?*" Then
        strto = strto & cell.Value & ";"
Next cell
If Len(strto) > 0 Then strto = Left(strto, Len(strto) - 1)
    Set rng = Nothing
    Set rng = Sheets("Blad1").Range("f2:f3").SpecialCells(xlCellTypeVisible)
    On Error GoTo 0
    If rng Is Nothing Then
        MsgBox "The selection is not a range or the sheet is protected. " & _
               vbNewLine & "Please correct and try again.", vbOKOnly
        Exit Sub
    With Application
        .EnableEvents = False
        .ScreenUpdating = False
  strbody = "<BODY style=font-size:11pt;font-family:Calibri>Hallo allemaal,</BODY>"
  SigString = Environ("appdata") & _
                "\Microsoft\Signatures\Chiel.htm"
    'Change only Mysig.htm to the name of your signature
    'de map signatures heet soms handtekeningen
                "\Microsoft\Handtekeningen\Chiel.htm"
    If Dir(SigString) <> "" Then
        Signature = GetBoiler(SigString)
    Else
        Signature = ""
                Set objOutlook = CreateObject("Outlook.Application")
                Set objoutlookaccount = GetOutlookAccount(objOutlook, "Chiel@chiel.nl")
                With objOutlook.CreateItem(0)
                Set .sendusingaccount = objoutlookaccount
                .display
                .BCC = strto
                .Subject = Range("H2")
                .HTMLbody = strbody & RangetoHTML(rng) & .HTMLbody
                .display  'Or use send.
            On Error GoTo 0
            Set OutMail = Nothing
cleanup:
    Set OutApp = Nothing
[/CODE]
With CreateObject("Outlook.Application").createitem(0)
    Set .SendUsingAccount = .session.accounts.Item("[COLOR=#3E3E3E]Chiel@chiel.nl[/COLOR]")
        .BCC = strto
Bedankt, ik heb dit stukje vervangen onderin de code. Helaas is het van emailadres nog steeds verkeerd.
Klik eens op het vakje 'Account' en kijk met welk mailadres het wordt verzonden.
Anders heb ik hier genoeg aan.
      .SentOnBehalfOfName = "[COLOR=#3E3E3E][COLOR=#3E3E3E]Chiel@chiel.nl[/COLOR][/COLOR][COLOR=#3E3E3E]"[/COLOR]    'Van
      .BCC = strto
Dank je wel!
.SentOnBehalfOfName doet het wel! Nu wordt het juiste emailadres gekozen.
