maximale geheugen
mitchell
20 nov 2000
Kan iemand mij vertellen wat het maximale geheugen is voor een
dell optiplex gx240 p4 1600 mhz!
De handleiding van Dell................
http://support.dell.com/support/edocs/systems/opgx240/en/index.htm
Memory
You can increase memory up to 1 gigabyte (GB) by using synchronous dynamic random-access memory (SDRAM) dual in-line memory modules (DIMMs). The system board illustration shows the location of the DIMM sockets on the system board. (DIMMs may either be error checking and correction [ECC] or non-error checking and correction [non-ECC]. However, all DIMMs must be the same type of memory—either ECC or non-ECC.)
When you add memory, you may install DIMMs in either socket. For optimum operation, Dell recommends that you install a DIMM in socket A first (closest to the processor) before installing a DIMM in socket B.
