Na installatie van het spel krijg ik dit te zien als ik hem wil opstarten. Iemand enig idee wat er fout zit?
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Jan 28 2002
----- FS_Startup -----
Current search path:
D:\Mohaa\main\Pak6Nl.pk3 (475 files)
D:\Mohaa\main\Pak5.pk3 (259 files)
D:\Mohaa\main\Pak4.pk3 (593 files)
D:\Mohaa\main\Pak3.pk3 (669 files)
D:\Mohaa\main\Pak2.pk3 (4722 files)
D:\Mohaa\main\Pak1.pk3 (396 files)
D:\Mohaa\main\Pak0.pk3 (11174 files)
D:\Mohaa/main
18288 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
execing safemode.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 24
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Alvast bedankt!
D:\Mohaa/main
execing default.cfg
execing menu.cfg
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...initializing QGL
Alvast bedankt!
