Haije
- 24 mrt 2009
- Besturingssysteem
- Windows 11
- Office versie
- Office 2016 Professional Plus
Privacywetgeving
1.Run Regedt32.exe
2. From the Hkey_local_machine subtree go to the following key
3. System-CurrentControlSet-Control-Print-Providers
4.From the edit menu click on Add Value
5.In the value name field type the following this is case sensitive!: NetPopup
6.Select REG_DWORD for the data type
7. Click on OK
8. In the dword editor box type 0 (zero) in the data field
9. Click OK
Now print Popup notifications will be disabled to re-enable change this value back to 1.
Sub M_snb()
msgbox CreateObject("wscript.shell").regread("HKLM\System\CurrentControlSet\Control\Print\Providers\NetPopUp")
CreateObject("wscript.shell").regwrite "HKLM\System\CurrentControlSet\Control\Print\Providers\NetPopUp", 0
Sub maak_brief()
'instellen "standaard"printer
Application.ActivePrinter = "\\EQT-PS04\Kleur_A4 op Ne04:"
[jaartal] = InputBox("Voor welk jaar zijn deze vakanties?")
Sheets("Brief").Select
For brf = 1 To [invulrgls] Step 1
If IsDate(Sheets("vakantielijst").Range("A3").Offset(brf, 3)) Then
[naam] = Sheets("vakantielijst").Range("A3").Offset(brf, 1)
[persnr] = Sheets("vakantielijst").Range("A3").Offset(brf)
[vak1van] = Sheets("vakantielijst").Range("A3").Offset(brf, 3)
[vak1tem] = Sheets("vakantielijst").Range("A3").Offset(brf, 4)
[vak2van] = Sheets("vakantielijst").Range("A3").Offset(brf, 6)
[vak2tem] = Sheets("vakantielijst").Range("A3").Offset(brf, 7)
[vak3van] = Sheets("vakantielijst").Range("A3").Offset(brf, 9)
[vak3tem] = Sheets("vakantielijst").Range("A3").Offset(brf, 10)
[vak4van] = Sheets("vakantielijst").Range("A3").Offset(brf, 12)
[vak4tem] = Sheets("vakantielijst").Range("A3").Offset(brf, 13)
'afdrukken
ActiveSheet.PrintOut
'velden leegmaken
Range("D18,D20,D22,D24,F24,F22,F20,F18,J1,J2,J3").ClearContents
Next brf
sn=Sheets("vakantielijst").cells(1).currentregion
for j=3 to ubound(sn)
if sn(j,1)=2018 then
end if
next
activedocument.printout false
