ocatie
- 21 feb 2007
Ik ben nu bezig met een map te maken voor Medal of Honor. mMaar steeds als ik mijn map wil compile geeft ie een error.
Running bsp command...
q3map -v -gamedir ../mohaa/ C:\Documents and Settings\Ocatie\Bureaublad\MOHAATools\mohradiant\lol.map
C:\Documents and Settings\Ocatie\Bureaublad\MOHAATools\mohradiant>q3map -v -gamedir ../mohaa/ C:\Documents and Settings\Ocatie\Bureaublad\MOHAATools\mohradiant\lol.map
---- q3map ----
verbose = true
************ ERROR ************
Q3MAP Version 1.34
-info - get information about the map
-light - get taunted
-vis - perform vising on the map
BSP options
-threads [num] - specify how many threads to use
-v - verbose
-nowater
-nofill
-nodetail
-nohint
-fulldetail
-onlyents
-onlytextures
-nosubdivide
-leaktest
-verboseentities
-nocurves
-notjunc
-expand
-detailterrainborders - force terrain mesh boundaries to be flagged max detail
-tmpout
-fakemap
-all
-fast
-nomerge
-snapdistance [distance] - vertex coordinates within [distance] of a grid point
will get snapped to the grid. Default = 0.1
-lightmapdensity [density]
-smoothangle [angle] - vertex angles less than this will get smoothed
-gamedir [gamedir] - file path to the game executable
-moddir [moddir] - mod subdirectory of gamedir
-blocksize [size] - bsp chopped up into blocks of size [blocksize].
blocksize 0 disables this option. Default = 1024
-chopblocklast - do blocksize chops after other chops
-nomanvis - disable manual vis
-nostatic - disables The Addition of Static Collision Masks to the scene
-visiblestatic - makes the Static Collision Masks use a visible shader
completed.
Run time was 0 hours, 0 minutes and 1 seconds
weet iemand hoe ik dit kan oplossen?:thumb:
---- q3map ----
verbose = true
Q3MAP Version 1.34
BSP options
-v - verbose
-nowater
-nofill
-nodetail
-nohint
-fulldetail
-onlyents
-onlytextures
-nosubdivide
-leaktest
-verboseentities
-nocurves
-notjunc
-expand
-tmpout
-fakemap
-all
-fast
-nomerge
completed.
