EDIT: SORRY!!! HEB VERKEERDE FOUTMELDING GEGEVEN IN TITEL!! DIT IS DE FOUTMELDING: Error:\nCannot connect TRF.
Hoi ik heb de NEC ND-1300A en als ik een dvd-R wil branden lukt het niet.. Mijn brander ondersteund dit wel.. Ik heb het probleem eerder gehad en toen is het opgelost maar weet niet meer hoe (heb nu pc geformat enzo)
Heb al ge-upgrade naar versie 1.0B van de Firmware..
Hieronder log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2-11-2004 12:54:32
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder: <_NEC DVD_RW ND-1300A> Version: 1.0B - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-1300A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : ATAPI DVD-ROM 16XMax atapi Port 0 ID 1 DMA: On
DiskPeripheral : Maxtor 6L080M0 BACE viamraid Port 2 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y120M0 YAR5 viamraid Port 2 ID 2 DMA: Off
CdRomPeripheral : IN6842E RDC343S 2.0B vaxscsi Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-1300A F: CDRom0
ATAPI DVD-ROM 16XMax G: CDRom1
IN6842E RDC343S H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047024kB)
Free physical memory: 705MB (722556kB)
Memory in use : 30 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.5.2006
NeroAPI
13:19:32 #1 Phase 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
13:19:32 #2 Phase 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
13:19:32 #3 Phase 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
13:19:32 #4 NEROAPI 7 File Burncd.cpp, Line 3095
13:19:32 #5 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
13:19:32 #6 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Hieronder log:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
1.5.2006
NeroAPI
Existing drivers:
Registry Keys:
