Bij deze het logfile (abracadabra voor mij dan :shocked: )
Rudie
1C80-002M-19E5-M22X-4021-84XM-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2-11-2004 13:54:32
NT-SPTI used
Nero Version: 7.5.1.1
Internal Version: 7, 5, 1, 1
Recorder: <SONY DVD RW DW-Q58A> Version: UYS3 - HA 1 TA 0 - 7.5.1.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <OU1722M MUM721X >Version: 1.0 - HA 1 TA 1 - 7.5.1.1
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST950212A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-Q58A atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : OU1722M MUM721X 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q58A D: CDRom0
OU1722M MUM721X E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 32505856 (0) Byte
BUFE : 0
Physical memory : 191MB (196080kB)
Free physical memory: 43MB (44464kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.10.2006
DVD-image branden
20:54:07 #1 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 31744KB of Memory
20:54:07 #2 Text 0 File Reader.cpp, Line 126
Reader running
20:54:07 #3 Text 0 File Writer.cpp, Line 123
Writer D: SONY DVD RW DW-Q58A running
20:54:08 #4 Text 0 File Burncd.cpp, Line 3443
Turn on Disc-At-Once, using DVD media
20:54:09 #5 Text 0 File DlgWaitCD.cpp, Line 300
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2290215 (508:56.15, 4473MB)
20:54:09 #6 Text 0 File DlgWaitCD.cpp, Line 312
Write in overburning mode: NO (enabled: CD)
20:54:09 #7 Text 0 File DlgWaitCD.cpp, Line 2851
Recorder: SONY DVD RW DW-Q58A, Media type: DVD-R
Disc Manufacturer: DAXON0 - 08S
Disc Application Code: 64, Disc Physical Code: 193
20:54:09 #8 Text 0 File DlgWaitCD.cpp, Line 484
>>> Protocol of DlgWaitCD activities: <<<
20:54:09 #9 Text 0 File ThreadedTransferInterface.cpp, Line 863
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2290216 (2290216) = #2290216/508:56.16
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2290066 blocks [D: SONY DVD RW DW-Q58A]
20:54:09 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1079
Prepare recorder [D: SONY DVD RW DW-Q58A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4690362368, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2290216 | 2290066 | 0x00
0 | 1 | 1 | 0x41 | 2290216 | 2290066 | 0x00
2290216 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
20:54:09 #11 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
20:54:09 #12 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
20:54:09 #13 Text 0 File Burncd.cpp, Line 4274
Cache writing successful.
20:54:09 #14 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
20:54:09 #15 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 1x (1.385 kB/sec)
20:54:10 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
20:54:10 #17 Text 0 File DVDR.cpp, Line 2969
Recording mode: Sequential Recording Mode
20:54:10 #18 Text 0 File DVDR.cpp, Line 3125
Start write address at LBA 0
DVD high compatibility mode: Yes
20:54:10 #19 Text 0 File Cdrdrv.cpp, Line 9215
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
20:54:11 #20 SPTI -1 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x27
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 27
Buffer x09700000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20:54:11 #21 CDR -1 File Writer.cpp, Line 312
Unspecified Recorder Error
20:54:11 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
20:54:12 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
20:54:13 #24 Text 0 File DVDR.cpp, Line 3341
EndDAO: Last written address was -1
20:54:13 #25 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 1x (1.385 kB/sec)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17-8-2001 23:07:32
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 24-7-2006 3:00:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.40a, size=36528 bytes, created 24-7-2006 3:00:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 4-8-2004 15:00:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
