Inhoud link-1:
IE6 opens blank (empty) windows
Try disabling *all* other programmes, including virus scanners, to see if there is an improvement. If not, proceed as follows:
You probably have a broken entry in file associations.
Go to my computer, view/folder options/file types (or control panel, folder options depending on your operating system).
Scroll down to the URL:Hypertext Transfer Protocols, click edit twice and make sure the following is in the application used to perform action box:
"C:\PROGRAM FILES\INTERNET EXPLORER\iexplore.exe" -nohome
The same applies for URL:Gopher
DDE should be set to: "%1",,-1,0,,,,
Application should say: IExplore
DDE application not running should be blank
Topic should be: WWW_OpenURL
Mike Burgess MVP was kind enough to point out to me the other day that 'open in new window' is dependent on the following files, therefore you should ensure they are the correct version for your system, and correctly registered.
Run the following commands from start/run. Run each line individually. After each run, you should see a short message stating the command was successful. The first command is the one most likely to work.
regsvr32 Urlmon.dll
regsvr32 Shdocvw.dll
regsvr32 Shell32.dll (only applicable to Windows ME, Windows 2000 and XP - if using an earlier operating system, run regsvr32 shdoc401.dll)
regsvr32 Oleaut32.dll
regsvr32 Actxprxy.dll
regsvr32 Mshtml.dll
It has been noted that replacing OLEAUT32.dll will work when all else has failed. Do that by following using Fix1 or Fix2 below:
Fix 1: Microsoft Office 2000 or an Office 2000 Component Is Installed on Your Computer
If Office 2000 or or an Office 2000 component is installed on your computer, obtain and install the Office 2000 Service Release 1 (SR-1). For information about how to do so, please visit the following Microsoft Web site:
http://www.microsoft.com/office/previous/default.htm
Fix 2: Microsoft Office 2000 or an Office 2000 Component Is Not Installed on Your Computer
If Office 2000 or or an Office 2000 component is not installed on your computer, obtain and install the Mcrepair.exe tool. To do so, please visit the following Microsoft Web site, save the Mcrepair.exe file to the desktop, and then run Mcrepair.exe:
http://download.microsoft.com/download/msninvestor/patch/1.0/win98/en-us/mcrepair.exe
Note: If the IE repair tool is available to you (control panel, add/remove programs, highlight IE, select add/remove) - running a repair will often fix the above associations automatically.
Further note:
I thought installing Mozilla 0.9.2 (which, may I say, is damned SLOW to start up) was quite a polite event, especially considering the fact that I didn't allow it to take over any defaults as part of the install.
But still, I discovered that hyperlinks in emails weren't working properly anymore - IE was opening, but just to a blank window. No attempt to access the URL was made.
Somehow or other, WWW_OpenURL disappeared out of 'topic' in the default open action for the URL:Hypertext Transfer protocols and Gopher - nothing else was out of whack - go figure :-/
Some knowledge base articles addressing the blank window problem are:
Browser Window Is Blank After You Install First Aid 98 [Q182038]
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q182038
Current Web Page Is Blank After Opening an Outlook:// URL [Q257136]
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q257136
New window is blank or nothing happens when you click on a link - Q281679
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q281679
Finally, BHODemon is an excellent troubleshooting programme, available at
http://www.definitivesolutions.com/bhodemon.htm. It does not need installing - simply unzip and run the EXE programme. It is very easy to use.
Also, you may like to use a programme called BHOCop available here:
http://www.pcmag.com/article2/0,4149,2023,00.asp
Inhoud link-2:
You Cannot Open New Internet Explorer Window or Nothing Happens After You Click a Link
The information in this article applies to:
Microsoft Internet Explorer version 6 for Windows XP
Microsoft Internet Explorer version 6 for Windows 2000
Microsoft Internet Explorer version 6 for Windows NT 4.0
Microsoft Internet Explorer version 6 for Windows Millennium Edition
Microsoft Internet Explorer version 6 for Windows 98 Second Edition
Microsoft Internet Explorer 5.5 for Windows 2000
Microsoft Internet Explorer 5.5 for Windows NT 4.0
Microsoft Internet Explorer 5.5 for Windows Millennium Edition
Microsoft Internet Explorer 5.5 for Windows 98 Second Edition
Microsoft Internet Explorer 5.5 for Windows 95
Microsoft Internet Explorer 5.01 for Windows 2000
Microsoft Internet Explorer 5.01 for Windows NT 4.0
Microsoft Internet Explorer 5.01 for Windows 98 Second Edition
Microsoft Internet Explorer 5.01 for Windows 95
Microsoft Internet Explorer 5.0 for Windows NT 4.0
Microsoft Internet Explorer 5.0 for Windows 98 Second Edition
Microsoft Internet Explorer 5.0 for Windows 95
This article was previously published under Q281679
SYMPTOMS
When you click a hyperlink in an e-mail message or on a Web page, or right-click a hyperlink on a Web page and then click Open in New Window, you may experience one or more of the following symptoms:
Nothing happens.
The new window may be blank.
You may receive a scripting error message.
When you use the Print command or the Print Preview command in Internet Explorer, nothing may happen.
When you try to connect to Web folders, you may receive the following error message:
The current operation could not be completed because an unexpected error has occurred.
CAUSE
This behavior may occur for any of the following reasons:
The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file:
[HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]
[HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]
[HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]
This may occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0.
The following registry key is missing or damaged:
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
One or more of the following files is missing, damaged, or improperly registered:
Url.dll
Mshtml.dll
Actxprxy.dll
Oleaut32.dll
Shell32.dll
Shdocvw.dll
RESOLUTION
To resolve this problem in Internet Explorer, follow these steps:
Quit all programs that are running.
Click Start, and then click Run.
Type regsvr32 urlmon.dll, and then click OK.
When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.
If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below):
Shdocvw.dll
Msjava.dll
Actxprxy.dll
Oleaut32.dll
Mshtml.dll
Browseui.dll
Shell32.dll (Windows XP and Windows 2000 only)
If the problem is still not resolved, verify that the following registry values are present and correct:
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Groetjes,
Bennie
