Office to Outlook agenda" kleine" wijziging in code
Fuser149
13 feb 2012
Ik heb een code gekoppeld aan een knop om een access record automatisch in outlook agenda op te slaan. Dit lukt perfect al wil ik bij reminder niet enkel in minuten weergeven maar ook in uren dagen en weken... Kan ik mijn code aanpassen zodat dit lukt?
Private Sub Outlook_Check()
If Me!AddedToOutlook = True Then
        MsgBox "This appointment already added to Microsoft Outlook"
        Exit Sub
    Else
        Dim olApp As Outlook.Application
        Dim OutAppt As Outlook.AppointmentItem
        If isAppThere("Outlook.Application") = False Then            ' Outlook is not open, create a new instance
        Set outobj = CreateObject("Outlook.Application")
        Else            ' Outlook is already open--use this method
            Set olApp = GetObject(, "Outlook.Application")
        Set OutAppt = olApp.CreateItem(olAppointmentItem)
Private Sub AddAppt_Click()
' Save record first to be sure required fields are filled.
DoCmd.RunCommand acCmdSaveRecord
' Exit the procedure if appointment has been added to Outlook.
Exit Sub
' Add a new appointment.
Else
Dim outobj As Outlook.Application
Set outobj = CreateObject("outlook.application")
Set OutAppt = outobj.CreateItem(olAppointmentItem)
With OutAppt
.Start = Me!ApptDate & " " & Me!ApptTime
.Duration = Me!ApptLength
.Subject = Me!Appt
If Not IsNull(Me!ApptNotes) Then .Body = Me!ApptNotes
If Not IsNull(Me!ApptLocation) Then .Location = _
Me!ApptLocation
If Me!ApptReminder Then
.ReminderMinutesBeforeStart = Me!ReminderMinutes
.ReminderSet = True
.Save
' Release the Outlook object variable.
Set outobj = Nothing
' Set the AddedToOutlook flag, save the record, display a message.
MsgBox "Appointment Added!"
Exit Sub
AddAppt_Err:
MsgBox "Error " & Err.Number & vbCrLf & Err.Description
Exit Sub
Alvast bedankt
groeten
