openGL ofzow..:S:S
zulfikar
14 okt 2008
Hallo Helpmij.nl'ers
ik ben vandaag net lid op help-mij.nl, ik heb een vraag. ik probeer steeds Soldie of Fortune te openen, maar ik krijg een foutmelding, iets met OpenGL ofzow...:S:S
SOF2MP V1.02t win-x86 Apr 5 2002
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\PROGRA~1\SOLDIE~1/base/MP
0 files in pk3 files
Running in restricted demo mode.
C:\PROGRA~1\SOLDIE~1/demo/MP
C:\PROGRA~1\SOLDIE~1\demo\assets.pk3 (1703 files)
1703 files in pk3 files
execing sof2mp_default.cfg
couldn't exec sof2mp.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
OS: Microsoft WinXP Service Pack 2 (NT)
CPU Detected: Pentium IV
Pentium IV
---------- Input Initialization ----------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
WARNING: tess.xyz not 16 byte aligned
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
R_Terrain: Shutting down RENDERER terrain.....
GLW_StartOpenGL() - could not load OpenGL subsystem
------------- Input Shutdown -------------
dit is het LOG ik weet niet wat ik moet doen kan er iemand helpen ??
alvast heel erg bedankt
Welkom op Helpmij.
Je vraag is verplaatst naar Spellen --> Spel werkt niet (meer)
Je geeft niet aan wat voor hardware er in je pc zit, maar enkele verklaringen zijn mogelijk.
- Je beeldschermresolutie wordt niet ondersteund (...failed to find an appropriate PIXELFORMAT)
- Je grafische kaart wordt niet ondersteund (...WARNING: missing Glide installation, assuming no 3Dfx available)
