opengl werkt niet help plz!!
thijs840
27 aug 2007
hallo
ik heb gisteren wolfenstein enemy territory geinstaleert.
toen ik alles had gedaan starte ik het op maar kreeg ik dit:
ET 2.56 win-x86 Sep 5 2003
----- FS_Startup -----
Current search path:
C:\PROGRA~1\WOLFEN~1\etmain\pak1.pk3 (10 files)
C:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files)
C:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (4 files)
C:\PROGRA~1\WOLFEN~1/etmain
3739 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
ik weet aleen dat het aan me openGL dinges ligt..
en ik heb iets van 4 forums gelezen
bij deze forums gaven mensen hun video kaart info dus bij deze:
zover ik begreep uit de andere forums ligt het niet aan de driver
ik heb wel een driver geinstaleert
Je drivers zijn dus wel goed geïnstalleerd.
Heb je misschien een breedbeeld scherm? Want deze melding valt mij op:
Probeer anders eens een lagere resolutie (als dat mogelijk is). Misschien heeft het spel daar een probleem mee.
NB. je vraag is verplaatst naar de Spel werkt niet sectie.
