hallo,
ik zocht voor een linkensysteem, en die heb ik gevonden er stond dat er een admin bij was.
Maar welke link is voor admin? danku! dit is het script:
PHP:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<title>Easylinks</title>
<META NAME="Robots" CONTENT="NOINDEX,NOFOLLOW">
<style type="text/css">
a {text-decoration:none}
a:hover {text-decoration:underline}
</style>
</head>
<body bgcolor="#ffffff" link="#333333" alink="#999999" vlink="#000000" text="#333300">
<table border=0 cellpadding=0 cellspacing=1 bgcolor="#000000" width="100%">
<tr>
<td>
<table border=0 cellpadding=10 cellspacing=0 width=100%>
<tr>
<td bgcolor="#cccc99">
<font color="#000000">
<pre>
Runescape ClanDatabase
</pre>
</font>
<font face="verdana,arial" size=2>
// General display variables
# File that contains the data
$filelocation="boomarks.txt";
# Name of this document here
$boardname="easylinks.php";
# Password for the admin section
$pass="secret";
# The message to display when someone entered data $name is the name then
$thanksmessage="<br><br><b>Thank you for your entry!</b><br>";
# The message to display, if there is an error
$errormessage="<br><br><b>Oops! You seem to have forgotten either the name, the url or the message!</b><br>";
# Replace special characters with their html equivalents like > to > (0/1)
$specialchars=1;
# Convert Ascii linebreaks to html linebreaks <br> (0/1)
$linebreaks=1;
# Entrytext, displayed above the links
$entrytext = '';
# Rules, displayed when you enter some text...
$rules = 'Enter your link data here, please make sure to check the links before entering.';
# display (1) or hide (0) the dropdowns/textlinks above and below the links (navigation)
$dropdown_up=1;
$dropdown_down=0;
$textlinks_up=0;
$textlinks_down=1;
# Text to be displayed when a category has no data yet.
$no_link_yet="Sorry, there is no link yet";
// Display templates, the data in %% will be replaced by the real content.
// do not use ' !!!
# detailed link display
# possible variables are %url% %name% and %message%
$detail_display='
<b><a href="%url%" target="_blank">%name%</a></b><br>%message%<br><br>
# compact link display
# possible variables are %url% and %name%
$compact_display='
# category header
# possible variables are %category%
$cat_display='
<table width=100% border=0 cellspacing=0 cellpadding=1>
<tr>
<td bgcolor="#000000">
<tr>
<td bgcolor="#999966">
<font face="verdana,arial" size=2 color="#ffff99">
<b>%category%</b>
</font>
</td>
</tr>
</table>
</td>
</tr>
</table>
# text links template
# possible variables are %links%
$text_links_display = '
<div align="center">
<table width=50% border=0 cellpadding=1 cellspacing=0 bgcolor="#000000">
<tr>
<td>
<table width=100% border=0 cellspacing=0 cellpadding=5>
<tr>
<td bgcolor="#ffff99" align="center">
%links%
</font>
</td>
</tr>
</table>
</td>
</tr>
</table>
</div>
# dropdown template
# possible variables are %dropdown%
$dropdown_display = '
<table width=50% border=0 cellpadding=1 cellspacing=0 bgcolor="#000000" align="center">
<tr>
<td>
<tr>
<font face="verdana,arial" size=2 color="#000000">
%dropdown%
</font>
</td>
</tr>
</table>
</td>
</tr>
</table>
# Add link template, please ensure to use both %% expressions, otherwise the link
# will not be closed!!!
# possible variables are %addlinkstart% and %addlinkend%</
$addlink_display = '
<table width=20% border=0 cellpadding=1 cellspacing=0 bgcolor="#000000">
<tr>
<td>
<tr>
%addlinkstart%
Add your link
%addlinkend%
</font>
</td>
</tr>
</table>
</td>
</tr>
</table>
</div>
<br>
// The categories, split them with a, do not use spaces after the comma
$categories = "Clans,Hulpsites";
$categories = split(",",$categories);
sort($categories);
if (!$pw || $pw != $pass){ // no admin
Introduction Screen when there is no data from the form
if ($action != "view" && $action !="new" && $edit !="yes"){echo $entrytext;$action="view";$compact="yes";}
if ($dropdown_up==1){ // display upper dropdown
$dropdownchunks=split("%dropdown%",$dropdown_display);
echo "<form method=post>".$dropdownchunks[0];
echo "Kies catogorie:
<select name=\"cat\"><option value=\"all\">Alles</option>";
for ($i=0;$i<sizeof($categories);$i++):
echo "<option value=\"$categories[$i]\"";
if ($categories[$i] == $cat){echo "selected";}
echo">$categories[$i]</option>";
endfor;
echo "</select><input type=\"hidden\" value=\"view\" name=\"action\"> <input type=\"checkbox\" name=\"compact\" value=\"yes\"";
if ($compact=="yes") echo "checked";
echo"> Verberg details <input type=\"submit\" value=\"Laat zien\">".$dropdownchunks[1]."</form>";
if ($textlinks_up==1){ // diplay upper textlinks
$textchunks=split("%links%",$text_links_display);
echo $textchunks[0];
for ($x=0;$x<sizeof($categories);$x++):
if ($categories[$x] != $cat){echo "<a href=\"$boardname?action=view&compact=$compact&cat=$categories[$x]\">$categories[$x]</a> ";}
else {echo "<b>$categories[$x]</b> ";}
endfor;
echo "<br>";
if ($cat != "all"){echo "<a href=\"$boardname?action=view&compact=$compact&cat=all\">all</a>";}
else echo "<b>all</b>";
if ($compact=="yes"){$viewdisp="<a href=\"$boardname?action=view&cat=$cat\">show</a> <b>hide</b></a> details.";}
if ($compact!="yes"){$viewdisp="<b>show</b> <a href=\"$boardname?action=view&compact=yes&cat=$cat\">hide</a> details.";}
echo " (".$viewdisp.")".$textchunks[1];
Display the links
if ($action=="view"){
// if there is no category, display all...
if ($cat == "") $cat="all";
echo $entrytext;
$lines=get_data($filelocation); // reads datafile
if ($cat == "all"){
// loop over all categories
// take template and put data in
$cat_display_now = $cat_display;
$cat_display_now=eregi_replace("%category%",$categories[$x],$cat_display_now);
echo stripslashes($cat_display_now);
$f=0;
$found=0; // trigger for no link found
while($f < sizeof($lines)){
$user = explode("#",$lines[$f]);
if ($user[2] == $categories[$x]){
$found=1; // there is a link here
// if there is no http, add it
if (substr($user[3],0,7)!= "http://"){$user[3]="http://".$user[3];}
if ($compact != "yes"){// display with details
$detail_display_now = $detail_display;
$detail_display_now=eregi_replace("%url%",$user[3],$detail_display_now);
$detail_display_now=eregi_replace("%name%",$user[1],$detail_display_now);
$detail_display_now=eregi_replace("%message%",$user[4],$detail_display_now);
echo stripslashes($detail_display_now);
else { // display without details
$compact_display_now = $compact_display;
$compact_display_now=eregi_replace("%url%",$user[3],$compact_display_now);
$compact_display_now=eregi_replace("%name%",$user[1],$compact_display_now);
echo stripslashes($compact_display_now);
$f++;
// no link in category, display message
if ($found==0)echo $no_link_yet;
endfor;
// display category
else {
// put data in template
$cat_display_now=eregi_replace("%category%",$cat,$cat_display_now);
$f=0;
$found=0; // trigger if there is a link
if ($user[2] == $cat){
$found=1;// link found!
if ($compact != "yes"){ // display with details
$f++;
// if there is no link in this category, say so
// Display add link template
$addlink_display=eregi_replace("%addlinkstart%","<a href=\"$boardname?action=new&cat=$cat\">",$addlink_display);
$addlink_display=eregi_replace("%addlinkend%","</a>",$addlink_display);
echo $addlink_display;
Adding a new entry to the data file
if ($edit == "yes"){
// When there is missing data, display the errormessage and reprint the form
if ($name == "" || $message =="" || $url==""){
echo $errormessage."\n";
echo "
<form method=post>
<dl>
<dt>Name:</dt>
<dd><input type=\"text\" name=\"name\" value=\"$name\" size=30></dd>
<dt>Category:</dt>
<dd><select name=\"category\">";
// loop over possible categories
for ($i=0;$i<sizeof($categories);$i++){
if ($categories[$i] == $category){echo "selected";}
echo"
</select></dd>
<dt>url:</dt>
<dd><input type=\"text\" name=\"url\" value=\"$url\" size=30></dd>
<dt>Message:</dt>
<dd><textarea name=\"message\" cols=30 rows=5>".$message."</textarea></dd>
</dl>
<div align=\"center\">
<input type=\"hidden\" name=\"edit\" value=\"yes\">
<input type=\"submit\" value=\"Add your link!\" border=0>
</div>
</form>
// If all the entries are correct, display thanksmessage add to datafile
else {
echo $thanksmessage."\n";
// Change % and # to percent and no, to avoid wrong splitting of the data.
$message = eregi_replace("#","no.",$message);
$message = eregi_replace("%","percent",$message);
$name = eregi_replace("#","no.",$name);
$name = eregi_replace("%","percent",$name);
// When specialchars are to be replaced...
if ($specialchars==1){$message=htmlentities($message);}
// When ASCII Linebreaks should become <br>s
if ($linebreaks==1){$message = nl2br($message);}
$counter = sizeof($lines);
$newfile = fopen($filelocation,"a+");
$add = "%".$counter."#".$name."#".$category."#".$url."#".$message."\n";
fwrite($newfile, $add);
fclose($newfile);
Add a new entry to the links, display the rules and show the form.
if ($action == "new" && $edit != "yes"){
echo "$rules<br>\n
<form method=post>
<dl>
<dt>Name:</dt>
<dd><input type=\"text\" name=\"name\" size=30></dd>
<dt>Category:</dt>
// loop over categories
if ($cat == $categories[$i]) echo "selected";
echo">$categories[$i]</option>";;
echo"
</select></dd>
<dt>url:</dt>
<dd><input type=\"text\" name=\"url\" size=30></dd>
<dt>Message:</dt>
<dd><textarea name=\"message\" cols=30 rows=5></textarea></dd>
</dl>
</div>
</form>
Admin Section!
if ($pw == $pass){
// Display entries with delete / edit buttons
if (!$del && !$edit & !$add){
echo $entrytext;
// load data from file
// Display all the entries
for ($f=1;$f<sizeof($lines);$f++):
// get display template, display it with data
echo '<table border=0><tr><td><form method=post><input type="hidden" name="pw" value="'.$pw.'"><input type="hidden" name="del" value="'.$user[0].'"><input type="submit" value="delete"></form></td><td><form method=post><input type="hidden" name="pw" value="'.$pw.'"><input type="hidden" name="edit" value="'.$user[0].'"><input type="submit" value="edit"></form></td></tr></table>';
endfor;
// edit entry
if ($edit){
// read data
// loop over entries
while(list($key)= each ($lines)){
// when the entry is the one to be edited, split in and display the form with the data
if ($key == $edit){$user = explode("#",$lines[$key]);}
echo "
<form method=post>
<dl>
<dt>Handle:</dt>
<dd><input type=\"text\" name=\"name\" value=\"".$user[1]."\" size=30></dd>
<dt>category:</dt>
// loop over categories, highlight selected
if ($categories[$i] == $user[2]){echo "selected";}
echo"
</select></dd>
<dt>url:</dt>
<dd><input type=\"text\" name=\"url\" value=\"".$user[3]."\" size=30></dd>
<dt>Message:</dt>
<dd><textarea name=\"message\" cols=30 rows=5>".$user[4]."</textarea></dd>
</dl>
<input type=\"hidden\" name=\"add\" value=\"".$user[0]."\"><input type=\"hidden\" name=\"pw\" value=\"$pw\">
<input type=\"submit\" value=\"save changes\" border=0>
</div>
</form>
// Add the changed data to the datafile
if ($add){
// exchange invalid characters
$newdatas="";
// when the entry is not the one to be changed...
if ($key != $add){
// when it's not the first entry, don't add a % (prevents blank entry)
if ($key != 0){$newdatas .= "%";}
// else simply put in the old data
$newdatas .= $lines[$key];
// if the entry is the one that was changed, insert the new data
else {$newdatas .= "%".$add."#".$name."#".$category."#".$url."#".$message;}
// overwrite the old data file...
$newfile = fopen($filelocation,"w+");
fwrite($newfile, $newdatas);
fclose($newfile);
// display linkbutton back
echo "<div align=\"center\">The data of entry ".$name." has been changed!<form method=post><input type=\"hidden\" name=\"pw\" value=\"$pw\"><input type=hidden name=action value=view><input type=submit value=\"see changes\"></form></div>";
// Delete entry
if ($del){
// reset datavariable
$newdatas="";
// read in old data
// reset new entry counter
$count=0;
// when the entry is not the one to be deleted...
if ($key != $del){
// divide into data chunks
// add new counter and add the data
if ($key != 0){$newdatas .= $count."#".$user[1]."#".$user[2]."#".$user[3]."#".$user[4];}
// increase counter
$count++;
// replace old data file
fclose($newfile);
echo "<div align=\"center\">The entry has been deleted<form method=post><input type=hidden name=action value=view><input type=\"hidden\" name=\"pw\" value=\"$pw\"><input type=submit value=\"see changes\"></form></div>";
// Display dropdown and links below
if ($dropdown_down==1){
// get template, add data in it
echo "Choose category:
<select name=\"cat\"><option value=\"all\">Display all</option>";
endfor;
if ($compact=="yes")echo "checked";
echo"> hide details <input type=\"submit\" value=\"show\">".$dropdownchunks[1]."</form>";
if ($textlinks_down==1){
endfor;
echo "<br>";
// Function for reading and preparing the data...
function get_data($filelocation){
// check for the datafile, if it isn't there create blank one
if (!file_exists($filelocation)) {
fclose($newfile);
$newfile = fopen($filelocation,"r");
$content = fread($newfile, filesize($filelocation));
fclose($newfile);
$lines = explode("%",$content);
return $lines;
echo"<br><div align=\"right\"><font face=\"verdana,arial,helvetica\" size=2>Created with <a href=\"http://www.onlinetools.org/easylinks/\" target=\"_blank\">EasyLinks</a> 1.0, get it for free.</font></div>";
</font>
</td>
</tr>
</table>
</td>
</tr>
</table><br><br>
<font face="verdana" size="-2">
This is a link for all page, there is no quality control of the submitted data, and the owner of this server does not take responsibility for the displayed links.
</font>
</div>
</body>
</html>
