nog een optie.
Outlook Express Inbox Corruption
Download the DBXtract utility to your desktop. Download.
http://chattanooga.net/~scochran/DBXtract.exe
** Make sure that Outlook Express is closed and not running **
Create a folder that you want to recover the emails from on your desktop. For example, c:\windows\desktop\emails
Double click on the DBXtract.exe that is located on your desktop. It should detect where your inbox.dbx file (which contains all of the emails that you want to recover).
Under the path box located under OUTPUT, click the browse button to browse to the emails folder that you created in step #2 and highlight it. Click the OK button.
Click the Extract button. All of the emails that were in the inbox will then be extracted into the folder created in step #2. Each email will be represented by a .eml file.
Once all of the emails are extracted, open Outlook Express. Open the emails folder on your desktop.
Highlight all of the .eml files in your emails folder and drag them to one of the folders in Outlook Express. The emails will be reappear in Outlook Express. Verify that your emails are there, then you may delete the folder you created in step #2.
pe.
