TransferID domains. 20-04-2009 16:57:07
Hello,
I need the autorisationcode from my domains to transfer it.
The new hoster needs it to transfer my domains to them.
Greetings,
Platzii
Re: TransferID domains. 20-04-2009 17:01:37
We told you this several times now, you will receive them once the transfers are initiated.
Re: TransferID domains. 20-04-2009 17:33:43
Yes, but they can't do anything withouth transferid :/
Re: TransferID domains. 21-04-2009 17:45:47
Re: TransferID domains. 21-04-2009 17:55:46
How have I not been clear?
I can only give them to you once the transfer has been initiated.
Re: TransferID domains. 21-04-2009 21:52:23
Voor het verhuizen van dit domein is een verhuiscode nodig. Deze kun je opvragen bij de huidige provider.
Re: TransferID domains. 21-04-2009 21:53:33
Translation: To move the domain, you need a transfercode. You can ask it at your current provider.
I AM ASKING IT NOW...
Re: TransferID domains. 21-04-2009 21:58:40
This is the final time I'll tell you:
We will only be able to give you the code once the transfer has been initiated, we can't get the code without you initiating the transfer.
Re: TransferID domains. 21-04-2009 22:05:58
This is the final time I'll tell YOU!:
I can't initiate without transferID!!!
Re: TransferID domains. 21-04-2009 22:14:17
This is unfortunaly your problem.
Re: TransferID domains. 22-04-2009 13:35:37
Je kunt de verhuizing aanvragen met de EPP-code 'request', dan kun je waarschijnlijk wel een EPP-code ontvangen en dan voeren wij deze in om de verhuizing nogmaals te starten met de nieuwe code.
Translation:
You can request the move with the EPP-Code Request, than you can recieve the EPP-Code so we can initiate the move.
So, I would like to have the EPP-Code.
Re: TransferID domains. 22-04-2009 13:44:28
Re: TransferID domains. 22-04-2009 13:55:08
And how can I do that?
Re: TransferID domains. 22-04-2009 14:04:26
We can't support you transfering your domain, that's up to you.
Re: TransferID domains. 22-04-2009 14:10:31
Why not, just say what do I have to do and where I have to do it?
Re: TransferID domains. 22-04-2009 14:10:52
I'll repeat myself: We can't support you transfering your domain, that's up to you.
Re: TransferID domains. 22-04-2009 14:38:54
How do I have to know how your domaintransfersystem works?
Re: TransferID domains. 22-04-2009 14:43:28
It works just like any other domain provider, there are no exceptions possible.
Re: TransferID domains. 22-04-2009 15:00:03
By other domainproviders, they give the ID...
Re: TransferID domains. 22-04-2009 15:03:23
So do we, but we (and they) can only give it to you once the transfer has been initiated.
Re: TransferID domains. 22-04-2009 15:32:00
And how do I do that? :+
Re: TransferID domains. 22-04-2009 15:34:18
Final time:
Contacting us again about it will result in a ban from our support system.
