Redhat 8.0 en OpenLDAP installatie
serge2
27 nov 2000
Hi,
Problemen tijdens het opstarten van LDAP onder linux
1.Ik haalde de software van de openldap website
2.Plaatse deze op mijn linux server onder /usr/local/openldap
3.Unzipte deze en kreeg /usr/local/openldap/openldap-2.1.14
4.In deze dirrectory deed ik ./configure
Het resultaat was :
Copyright 1998-2003 The OpenLDAP Foundation, All Rights Reserved.
Restrictions apply, see COPYRIGHT and LICENSE files.
Configuring OpenLDAP 2.1.14-Release ...
checking host system type... i686-pc-linux-gnuoldld
checking target system type... i686-pc-linux-gnuoldld
checking build system type... i686-pc-linux-gnuoldld
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for mawk... no
checking for gawk... gawk
checking whether make sets ${MAKE}... yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... missing
checking for gnutar... no
checking for gtar... gtar
checking configure arguments... done
checking for cc... no
checking for gcc... no
configure: error: Unable to locate cc(1) or suitable replacement. Check PATH or set CC.
De directory is
-rw-rw-r-- 1 2000 2000 2529 Feb 9 00:28 acconfig.h
-rw-rw-r-- 1 2000 2000 510 Jan 4 2002 acinclude.m4
-rw-rw-r-- 1 2000 2000 129943 Dec 21 22:37 aclocal.m4
-rw-rw-r-- 1 2000 2000 3319 Oct 6 02:56 ANNOUNCEMENT
drwxrwxr-x 2 2000 2000 4096 Feb 28 22:39 build
-rw-rw-r-- 1 2000 2000 9731 Feb 28 18:22 CHANGES
drwxrwxr-x 3 2000 2000 4096 Feb 28 22:39 clients
-rw-r--r-- 1 root root 239 Mar 9 12:55 confdefs.h
-rw-r--r-- 1 root root 950 Mar 9 12:55 config.log
-rwxrwxr-x 1 2000 2000 617867 Feb 28 18:06 configure
-rw-rw-r-- 1 2000 2000 79784 Feb 15 20:17 configure.in
drwxrwxr-x 5 2000 2000 4096 Feb 28 22:39 contrib
-rw-rw-r-- 1 2000 2000 1354 Jan 3 19:09 COPYRIGHT
drwxrwxr-x 7 2000 2000 4096 Feb 28 22:39 doc
drwxrwxr-x 3 2000 2000 4096 Feb 28 22:39 include
-rw-rw-r-- 1 2000 2000 3529 Feb 14 17:04 INSTALL
drwxrwxr-x 11 2000 2000 4096 Feb 28 22:39 libraries
-rw-rw-r-- 1 2000 2000 2216 Sep 8 2001 LICENSE
-rw-rw-r-- 1 2000 2000 891 Feb 13 2002 Makefile.in
-rw-rw-r-- 1 2000 2000 2432 Oct 6 02:56 README
drwxrwxr-x 4 2000 2000 4096 Feb 28 22:39 servers
drwxrwxr-x 5 2000 2000 4096 Feb 28 22:39 tests
-rw-r--r-- 1 root root 0 Mar 9 13:08 test.txt
Een idee wat er fout is
Alvast bedankt
Serge
Misschien moet je eens op de vereisten gaan letten?
